I agree that the difference is amazing on AMD GPU's in BF4 using mntle and DX, the question is why is AMD's DX so poor in bf4 compared to Nvidia dx in BF4.
woops dummys in lads....
i own an r9 290 my brother has the gtx 970 but wants to swap for mine...... hence i have both here.. i have run both on bf4 and for me and my set up the 290 had a better fps and yes i used mantle.... thanks humbug.
I have to agree with this, on dx a 780/290 are very similair at 1080p, higher res yes the 290 with more ram helps. But bring mantle into the mix and the 290 does do a good bit better, especially in bf4 which is an amd optimized game. But, i play it a lot and it is by no means bad on nv cards. Moreso now since new patches.It isn't, DX for AMD is exactly the same as it is For Nvidia, Mantle is simply much better than DX.
So after all that the GTX 970 doesn't help with your FPS.
Your welcome
@ Ian Evey, i used Mirillis Action to record that, in the post i made that Video for i made it clear that there is at least a 20% Drop off in performance because of it, i have to use that as its the only thing that will record Mantle and only in Boaderless mode. The Frame rates i see are not far to yours in that vid with DX, about 60 absolute minimum, i get more than 80 With Mantle which are higher than yours and you are running a faster CPU.
I can also see stuttering in your Vid, its quite noticeable. and your average frame rates look to be about 100 compared to my 140
http://forums.overclockers.co.uk/showpost.php?p=27129058&postcount=3
A 3570k at 3.8 in bf4 is not as good as a 8350 at 4.5?
Not sure how you judge an average fps when the fps are very similar, i can see why people like mantle but making a comparison which shows dx on amd on bf4 to be a pile of junk and then saying its the same on nvidia is not even a little bias?
it's pretty obvious a 290 with Mantle is going to be better than a 970 on DX in yours or OP's situation.
The A 3570k at 3.8 is better than the 8350 at 4.5 in DX in BF4, the 8350 at 4.5 in Mantle is better than the A 3570k at 3.8 in DX BF4, IF the A 3570k at 3.8 was running Mantle then it would be better than the 8350 at 4.5 running Mantle.
Simple's.
SNIP
You do realise Ian made that video to show that DX isn't anywhere near as bad for him as it is for you in your video, it's pretty obvious a 290 with Mantle is going to be better than a 970 on DX in yours or OP's situation. His video isn't as smooth as the Mantle side of yours but it's a hell of a lot better than the DX side. Yes I realise his CPU will of helped with that.
The stuttering you mention looks like rubberbanding which could be down to the server.
Who else matters?. You've been poking Humbug continuously throughout this thread for handbag reasons at best. What Humbug is saying is correct for his and the OP's system so your input is confusing tbh. Well, if you carry a Nvidia flag around with you, then I understand.
