Hi there
Quite a unique product this one, shall leave the rest to you guys:
Gigabyte 3-Way GeForce GTX 980 "Water Force" Gaming Graphics Card Kit **UK Exclusive** @ £2,499.95 inc VAT
With the exclusive 3-way SLI closed loop water cooling system, it can dissipate the heat of GPU, memory and MOSFET. The intuitive control panel can let gamers to check the performance of the 3 graphics cards from the panel and separately adjust the fan and pump speed for uniform temperature of the cards.
GIGABYTE Flex display technology(patent-pending) can automatically detect any connected monitors and achieve multi-display gaming up to 4 monitors at the same time by using various output groups. Users could enjoy the best gaming experience in ultra HD resolution with extended flexibility in arranging monitor configurations and making future system upgrade extremely easy.
With GPU Gauntlet™ Sorting, the Gigabyte SOC graphics card guarantees the higher overclocking capability in terms of excellent power switching.
Features:
- WATERFORCE :3-WAY SLI Water Cooling System
- Real-Time Display and Control
- Flex Display Technology
- Powered by NVIDIA GeForce GTX 980 GPU
- Integrated with 4GB GDDR5 memory 256-bit memory interface(Single Card)
- Features Dual-link DVI-I / DVI-D / HDMI / DisplayPort*3(Single Card)
- BASE: 1228 MHz / BOOST: 1329 MHz
- System power supply requirement: 1200W(with six 8-pin external power connectors)
Specification:-
- GeForce GTX 980
- GPU: GeForce GTX 980 (GM204)
- Core Base Clock: 1228MHz
- Core Boost Clock: 1329MHz
- Memory Clock: 7010MHz
- Memory Size: 4096MB GDDR5
- Bus Type: PCI Express 3.0
- Memory Bus: 256-bit
- CUDA Cores: 2048
- DirectX 12: Yes
- DVI Port: 1x Dual-Link DVI, 1x DVI, 3x DisplayPort & 1x HDMI
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Dimensions: L=312mm, W=129mm, H=43mm
- Power: 2x 8-Pin
- 600W PSU Required
- 220W TDP
- Warranty: 3yr
Only £2,499.95 inc VAT.
ORDER NOW
Features:
Specification:-
- GeForce GTX 980
- CUDA Cores: 2048
- DirectX 12: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 2x 8-Pin
- 600W PSU Required
- 220W TDP
- Warranty: 3yr
ORDER NOW
