There are no reviews and very little information on them available. I guess you are going to have to find out and tell the world!!![]()
Well i own Matt's old 1000w sf platinum, and iirc he stated that it tripped out at 1300w. Thankfully its having an easy life now running a 4.7ghz 4790k and mainly stock gtx 780's in sli. But id bet with the right mobo, (yes i want a maximus 6 extreme) it would handle tri sli 780's no bother. Iirc two cards oc'd pulled 740w max running firestrike, even then it was only for a few seconds on the combined test. Btw that includes my old 24" monitor in sig.It's the same size as your old SF unit according to the specs.
I'll take a punt on 1900w before it taps out![]()
I've had mine over 1700w![]()
Nope, had them side by side. Definitely a fair bit longer than my 1300W Leadex/SF gold.
The test of doom claims another victim...
Looks like my prediction was way off and it just goes to show how relatively awesome Superflower units are.
Btw, since I grabbed this 3970 off you, I haven't dared to attempt benching Sleeping Dogs with high clocks given how much more the CPU draws compared to a 2600k. I should probably have kept one of my spare psu's tbh... Oh well.
I guess you could look at it as at least with the P2, you know you're not running it way above spec if that helps soften the blow?.
