Question regarding 144hz monitor (AOC G2460FQ)
1 Dec 2014
Hello. Let me first start off by saying I am a massive Counter Strike : Global Offensive player, and i currently own a BenQ benq rl2455hm ( http://benq.co.uk/product/monitor/rl2455hm/ ).
I am looking to get a 120 / 144 hz monitor, as playing CS:GO with this monitor, I feel like after messing and trying all the settings, there's a lot of Ghosting, and it's fairly hard with the 60hz to see clearly when moving fast (For example).
I'm looking for a new monitor anyway as my second monitor (32" TV) is starting to die, so I figure i'll grab a 144hz monitor and use this BenQ as a second.
I've recently come across this. http://www.************/products/24-aoc-g2460fq-144hz-gaming-monitor-1920x1080-displayport-hdmi-dvi-vga-350cd-m2-80m1-speakers
It seems really cheap, and is 144 hz. it is also apparently the same as this except for missing ports ( http://www.************/products/24-aoc-g2460pqu-144hz-monitor-1920x1080-displayport-hdmi-dvi-vga-350cd-m2-80m1-1ms-speakers ).
My question is. Is this a decent 144hz monitor?. As i see most are a lot more expensive, but i'm not that good with monitors so, looking at specs of these 3, First of all is the FQ a better monitor in general over my current BenQ?, And spec wise is the FQ a better or equal monitor to the PQU?. I can't spend much more than that at all at the moment which is why i'm interested in it, But has anyone experienced this monitor?, there's very little about the FQ i can find.
Thanks in advance, Chris
Hello,
hopefully this helps somewhat.
https://forum.pcmonitors.info/topic/aoc-g2460pqu-or-lg-24gm77/
i posted the topic and they have a lot of experience with monitors.
i did decide to go against his advice though and bought the LG but as you can see the G2460FQ is a great 144hz screen.
