** CYBER MONDAY THE DEALS STILL GO ON!! **
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
All of our Black Friday deals are still running and some items which sold out can still be ordered on pre-order at Black Friday pricing.
Here are some highlights:
NVIDIA Shield 8" Tegra K1 2.20GHz, 2GB DDR3, 32GB Storage, 1920x1200 IPS WiFi/LTE Tablet - Android 4.40 KitKat with FREE Controller @ £299.99 inc VAT
Only £299.99 inc VAT - WITH FREE CONTROLLER UPTO 5pm today!!!
ORDER NOW
SteelSeries 4H Gaming Headset - Black (61022) @ £9.95 inc VAT
SteelSeries 4H is a simplified version of the award-winning SteelSeries 5H v2 headset. SteelSeries 4H features 40mm drivers to deliver clear in-game sounds and an optimized uni-directional microphone for in-game chats and VoIP. SteelSeries 4H also features XL-sized ear cushions that gently fit around the ears and reduce background noise while providing maximum wearing comfort.
Cord Length (m) - 1.8
Cord Length (ft) - 5.9
Wireless - No
Connection Type - 3.5 mm jack
Documentation Type - Promo Flyer
Sample of Documentation - Attached
Type of Ear Cushion - Cloth
Dismantle for Travel - No
Headphone Style - Over the Head
Frequency Response (Hz) - 16 - 28000
Magnet Type - Neodymium
Microphone Frequency Response (Hz) 75 - 16000
Microphone Pick-up Pattern - Uni-directional
Microphone Sensitivity (dB) -38
Microphone Impedance (Ohm) - 2000
Headphone Impedance (Ohm) - 40
Was [£19.99] Inc. VAT
Only £9.95 inc VAT.
ORDER NOW
Powercolor Radeon R9 290 PCS+ OC 4096MB GDDR5 PCI-Express Graphics Card @ £199.99 inc VAT
PCS+ Version features Powercolor's amazing tri-fan cooler, for much lower noise levels whilst offering superior cooling. Along with a great overclock out the box, this card runs at 1040MHz core and 5400MHz memory.
AMD Radeon R9 290 is a new graphics card powered by the latest AMD Radeon™ R9 290 graphics-processing unit (GPU). 4GB of super-fast GDDR5 memory for the best gaming experience at the highest resolutions including 4k and incorporates AMD Eyefinity and TrueAudio technologies to enable expansive multi-display setups and more accurate environmental sounds. R9 290 also includes support for both DirectX® 11.2 and AMD's new Mantle application programming interface (API) for great handling of even the most-demanding PC games.
Specification:
- Radeon R9 290
- Coil Whine Reduction Technology (Exclusive to Powercolor)
- GPU: Hawaii Pro
- Litecoin Hash Rate: 800-950
- Stream Processors: 2560
- Core Speed: 1040MHz
- Memory Speed: 5400Mhz
- Memory interface: 512-Bit
- Memory capacity: 4096MB GDDR5
- Cooling: 2-Slot Blower Fan
- PCI-Express X16 lane required
- 750W or greater PSU required
- Power Connectors: 8-pin + 6-pin required
- Display Outputs: 2x Dual Link DVI, 1x HDMI, 1x DisplayPort
- Warranty: 2yr
Was [£221.99] Inc. VAT
Only £199.99 inc VAT.
ORDER NOW
EVGA GeForce GTX 970 SC ACX 2.0 4096MB GDDR5 PCI-Express Graphics Card (04G-P4-2974-KR) @ £251.99 inc VAT
The new NVIDIA GeForce GTX 980/970 is powered by the next generation NVIDIA Maxwell Architecture, giving you incredible performance, unmatched power efficiency, and cutting-edge features.
Maxwell is the most advanced GPU architecture ever made, designed to be the engine of next generation gaming. Inspired by light, it was designed to solve some of the most complex lighting and graphics challenges in visual computing. For the first time, gaming GPU's can dynamically render indirect light using the new VXGI (Voxel Global Illumination technology). Scenes are significantly more lifelike as light interacts more realistically in the game environment.
The GTX 980 is the worlds fastest GPU and the GTX 970 offers the most advanced performance in its class. Each delivers 2x the performance of previous-generation card, bringing new gaming experiences to virtual reality, and ultra resolution 4k displays.
Enable the detail of 4k monitors, on a 1080P display. DSR produces smoother images by rendering a game at a high resolution, then downscaling it to the native resolution of the display using advanced filtering.
GeForce GTX 980 and 970 cards support tear-free, super-fast NVIDIA G-Sync monitor display technology including 4k. Together, these technologies provide the most immersive and competitive gaming experiences possible.
Features:-
- EVGA ACX 2.0 Cooling: With optimized swept fan blades, double ball bearing and an extreme low power motor, EVGA ACX 2.0 delivers more airflow with less power, unlocking additional power for the GPU.
- Voxel Global Illumination Technology (VXGI)
- NVIDIA® Super Resolution technology
- NVIDIA® GameWorks technology
- NVIDIA® GameStream technology
- NVIDIA® TXAA Technology
- NVIDIA GPU Boost 2.0
- NVIDIA PhysX® Technology
- NVIDIA FXAA Technology
- NVIDIA Adaptive Vertical Sync
- NVIDIA Surround
- Support for four concurrent displays including: Two dual-link DVI, HDMI and DisplayPort 1.2
- Microsoft DirectX 12
- NVIDIA® 3D Vision® Ready
- NVIDIA SLI® Ready Technology
- NVIDIA CUDA® technology
- PCI Express 3.0 support
- OpenGL 4.4 support
- OpenCL support
- NVIDIA SHIELD Ready
- NVIDIA G-Sync Ready
Specification:-
- GeForce GTX 970
- GPU: GeForce GTX 970 (GM204)
- Core Base Clock: 1165MHz
- Core Boost Clock: 1317MHz
- Memory Clock: 7010MHz
- Memory Size: 4096MB GDDR5
- Bus Type: PCI Express 3.0
- Memory Bus: 256-bit
- CUDA Cores: 1664
- DirectX 12: Yes
- DVI Port: 2x Dual-Link DVI, 1x DisplayPort & 1x HDMI
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 2x 6-pin
- 450W PSU Required
- 170W TDP
- Warranty: 3yr
Was [£277.99] Inc. VAT
Only £251.99 inc VAT.
ORDER NOW
Asus GeForce GTX 970 DirectCU II OC Strix 4096MB GDDR5 PCI-Express Graphics Card @ £287.99 inc VAT
Features:-
- NVIDIA Surround
- OpenCL support
Specification:-
- GeForce GTX 970
- Core Base Clock: 1114MHz
- Core Boost Clock: 1253MHz
- CUDA Cores: 1664
- DirectX 12: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 1x 8-Pin
- 450W PSU Required
- 225W TDP
- Warranty: 3yr
Was [£307.99] Inc. VAT
Only £287.99 inc VAT.
ORDER NOW
MSI Radeon R9 295 X2 8192MB GDDR5 PCI-Express Graphics Card @ £499.99 inc VAT
No matter what the game or the resolution you can now select the maximum settings even at 4k resolution and enjoy fluid ultimate smooth framerates in latest games such as Titanfall, Diablo 3, Watchdogs and even potential upcoming games such as GTA V and Half Life 3 should they surface.
Featuring a pair of 290X Hawaii GPU's fused onto a single PCB with an advanced PLX chip along with only requiring 2x 8-Pin power connectors.
The other major feature of the 295 X2 is its cooling solution which truly does keep the cards temperatures around 60c even after gaming for hours and it also manages to do this in more or less silence with zero throttling of the cores themselves. Making it one of the smoothest, quietest and easily most powerful graphics card on the market today. If you really crave the most powerful and have or are considering a 4k monitor for gaming then the 295 X2 is the card for you.
If your demands are truly the most powerful experience possible then these cards work great in Crossfire (4 GPU's) and you will be able to smash benchmarks to pieces and have no slow downs in games.
Specification:-
- GPU: 2x Hawaii XT
- Hybrid Liquid Cooling
- Litecoin Hash Rate: 1600-2000
- Stream Processors: 5632
- ROPS: 128
- Core Speed: 1018MHz
- Memory Speed: 5000Mhz
- Memory interface: 1024-Bit (2x 512-Bit)
- Memory capacity: 8192MB GDDR5
- 850W or greater PSU required with genuine 8-Pin PCI-E cables such as Silverstone 1500W
- Case capable of fitting such a long card and support for a 120mm radiator
- Dimensions: Card is 307x111x65mm and Cooler is 153x120x63mm
- Power Connectors: 2x 8-pin
- Display Outputs: 1x Dual Link DVI, 4x Mini-DisplayPort
- Warranty: 3yr
Was [£699.95] Inc. VAT
Only £499.99 inc VAT.
ORDER NOW
Zotac GeForce GTX 780Ti AMP "GHz Edition" 3072MB GDDR5 PCI-Express Graphics Card (ZT-70503-10P) @ £299.99 inc VAT
Put your gaming experience into overdrive with the insanely fast and powerful ZOTAC GeForce GTX 780 Ti AMP! Edition. The ZOTAC GeForce GTX 780 Ti AMP! Edition amplifies the stellar series with elevated clocks for that extra performance boost in demanding gaming situations.
NVIDIA 3D Vision Surround technology enables the ZOTAC GeForce GTX 780 Ti AMP! Edition to drive up to three displays for high-quality triple display gaming with immersive stereoscopic 3D effects. NVIDIA 3-Way SLI readiness lets the most demanding enthusiast gamers combine up to three ZOTAC GeForce GTX 780 Ti AMP! Edition graphics cards for up to a 280-percent performance boost.
Specification:-
- GeForce GTX 780Ti
- GPU: GeForce GTX 780Ti (GK110)
- Core Base Clock: 1006MHz
- Core Boost Clock: 1072MHz
- Memory Clock: 7200MHz
- Memory Size: 3072MB GDDR5
- Memory Bus: 384-bit
- CUDA Cores: 2880
- DirectX 11.2: Yes
- DVI Port: DVI-I /DVI-D
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- FREE Splinter Cell Compilation
- Review: http://forums.overclockers.co.uk/showthread.php?t=18629948
- Warranty: 5yr (2yr +3yr FREE when you register the product with Zotac within 28 days of purchase)
Was [£389.99] Inc. VAT
Only £299.99 inc VAT.
ORDER NOW
Samsung SyncMaster S24D390HL 24" Widescreen Slim Bezel LED Monitor - Black @ £99.95 inc VAT
Samsung’s newest Touch of Colour design is sure to command attention. Upholding Samsung’s ToC design legacy, the SD390 was crafted to catch the light of its surroundings in various beautiful ways, but brings a narrow bezel, slim and sleek black body and transparent neck to create a sophisticated and tasteful look that’s finished off perfectly with a subtle hint of soft pure blue along the bezel – making this unique monitor illuminate light and stand out in a way you’ve never seen before.
On or off, the stylish SD390 is sure to stand out wherever it is. Its narrow bezel design lets you see more of the screen while illuminating a subtle hint of soft pure blue that sets an elegant glow around the monitor. Its transparent crystal neck gently gleams in the light with a beautiful touch of blue and raises the screen to the perfect viewing level. The tilt feature increases your field of vision and maximises your viewing comfort. The SD390 will no doubt fulfill your every design desire.
Get perfect viewing for games with just one touch of a button. Game Mode adjusts your monitor’s settings instantly to give you an optimised gaming experience. Game Mode smartly detects the changes in scenes, enhances the colour and alters the screen’s contrast to make dark spots darker and light spots lighter so you can see all the action at all times. There is less lag thanks to a faster video response time that ensures that the picture keeps up with action and won’t let you down.
Get the best view from any angle with the SD390. Unlike conventional monitors, your Samsung LED Monitor has an extra-wide viewing angle of 178 degrees, vertically and horizontally. This means great picture quality from even more perspectives – whether you’re sitting down low and playing games or if several people are sitting around the monitor to watch a video. Whatever the situation, you can enjoy great viewing.
Magic Upscale improves image quality to such a level that you will only receive a better picture. Enjoy enhanced image quality no matter what the original picture quality is. Magic Upscale prevents image degradation when scaling up and gives only brilliant and pristine colours and images. And it also makes images on the monitor appear clearer and sharper than on a notebook. Shine with the SD360.
The Samsung SD390 monitor gives you all the connections you need to make the most of all your entertainment and other content. HDMI compatibility gives you access to games consoles, Blu-ray players and other AV devices, while a D-Sub connection mean you can plug in most PCs. You can easily connect your devices and use the monitor for working, gaming, viewing content and more.
Specification:-
- Screen Size: 23.6"
- Aspect Ratio: 16:9
- Panel Type: PLS
- BLU Type: LED
- Brightness (Typical): 250cd/m²
- Peak Luminance Ratio: 99%
- Contrast Ratio: 1000:1
- Dynamic Contrast Ratio: Mega
- Resolution: 1920 x 1080
- Response Time: 5ms (GTG)
- Viewing Angle (H/V): 178° / 178°
- Color Support: 16.7M
- Connectivity: 1x Analogue & 1x HDMI
- Warranty: 2yr
Was [£129.95] Inc. VAT
Only £99.95 inc VAT.
ORDER NOW
Acer Predator XB270H 27" 144hz Gaming Widescreen LED Monitor - Black/Red @ £275.99 inc VAT
A rapid 144 Hz refresh rate and a blazing-fast 1 ms response time deliver ultra-smooth motion scenes. The lower latency and immersive graphics will vastly improve your gaming experience. The Acer ErgoStand lets the XB0 series pivot, tilt, swivel and move up or down, so you can find the most comfortable view to focus on dodging your foes. Acer ComfyView technology enables you to stay in the battle longer by reducing glare to provide less eye strain.
Features:-
- The 27" Full HD display featured 144Hz refresh rate and 1ms response time for the smoothest gaming experience like never experienced before
- Flicker-less technology reduced the screen flicker, providing you a comfortable viewing experience
- Adjust your screen's dim in dark environment through Low dimming technology
- The Ergostand design came with adjustable tilt, swivel, pivot and height
Specification:-
- Flicker-less Technology
- Height Adjust stand with tilt, swivel and pivot
- Display Screen Size: 27"
- Aspect ratio: 16:9
- Panel Type: TN
- Brightness: 300cd/m2
- Contrast Ratio: 1000:1 (Typ)
- Dynamic Contrast Ratio: 10,000,000
- Resolution: 1920x1080 144Hz
- Response Time: 1ms (GTG)
- Colurs: 16.7M
- Bits: 8 bits
- Viewing Angle (H / V ): 170 ° / 160 °
- Connectivity: 1x DisplayPort 1.2 (144Hz), 1x DVI (144Hz), 1x Analogue, 1x HDMI
- USB Hub 3.0: Yes (1up, 4down)
- VESA: 100x100mm
- Speakers: Yes
- Warranty: 2yr
Was [£319.99] Inc. VAT
Only £275.99 inc VAT.
ORDER NOW
Samsung 32D850D 32" Widescreen LED Professional/Gaming Slim Bezel Monitor - Black @ £379.99 inc VAT
Samsungs latest flagship monitor ideal for gamers, professionals and photography experts.
Specification:-
- Screen Size: 32"
- Panel Type: VA
- Backlight: LED
- Contrast Ratio: 10,000,000:1
- Resolution: 2560x1440
- Pixel Pitch (HxV): 0.27675mmx0.27675mm
- Response Time: 4ms
- Viewing Angles: 178/178
- Colour Support: 1.07b
- Connectivity: Dual Link DVI, DisplayPort, HDMI, USB Hub
- Speakers: No
- Stand Type: Height Adjustable (130mm), Tilt, Swivel & Pivot
- VESA: 100x100
- Set Dimension with Stand (WxHxD): MAX:741.3×630×280, MIN:741.3×500×280mm
- Set Dimension without Stand (WxHxD): 741.3×441×68.5mm
- Review: http://www.trustedreviews.com/samsung-s32d850t-review-image-quality-uniformity-input-page-2
- Warranty: 3yr
Was [£479.99] Inc. VAT
Only £379.99 inc VAT.
ORDER NOW
Acer Predator 4k2k XB280HK 28" G-Sync Gaming Widescreen LED Monitor - Black/Red @ £499.99 inc VAT
Acer XB280HK gaming monitor as the world’s first 4k2k display featuring NVIDIA® G-SYNC™ technology to provide stunning, ultra-smooth, tear-free imagery and rich colors for outstanding gaming experiences. It features Acer’s flicker-less, low-dimming and ComfyView technologies that reduce strain on the eyes for smooth and comfortable extensive viewing.
The Acer XB280HK is intended to be paired with enthusiast PCs for immersive, ultra high-end gaming. It features a spacious 28-inch LED backlit display with 4k2k Ultra HD (3840 x 2160 pixels) that’s four times the resolution of 1080p Full HD, and presents stunning high quality images for outstanding visual enjoyment.
With a GeForce® GTX™-powered PC, NVIDIA® G-SYNC™ display technology synchronizes the display’s refresh rates to the GPU to eliminate screen tearing and minimize display stutter and input lag to deliver smoother, faster, more breathtaking gaming experiences. Scenes appear instantly, objects look sharper and more vibrant, and gameplay is more fluid and responsive providing gamers with significant performance advantages.
The Acer XB280HK features 170/170 degree viewing angles so that brilliantly-colored images can be seen from almost every angle. DisplayPort™ v1.2 transmits video signals and four USB 3.0 ports are conveniently located at the side and bottom of the display for connecting to keyboard, mouse or mobile devices.
The Acer XB280HK monitor is made with post-consumer recycled plastic and features a distinctive red ring on the base stand. The multi-functional ErgoStand allows the screen to tilt from -5° to 35° to ensure the best viewing angle; the base rotates 120° from left or right for easy screen sharing; the panel height can be raised by up to 150 mm for optimum comfort; and the screen pivots from horizontal to vertical for more viewing perspectives.
This eco-friendly monitor features a mercury- and arsenic-free panel, LED backlighting for reduced power consumption, and is ENERGY STAR®(1) qualified.
Features:
- Flicker-less technology – stable power supply eliminates screen flicker particularly beneficial for heavy users by helping to reduce eye strain.
- Low dimming technology – adjust to as low as 15 percent brightness in low light environments to make it easy on the eyes. Standard monitor settings start at 30 percent brightness level.
- ComfyView technology – the non-glare panel reduces reflection from light source.
Specification:
- G-Sync Technology
- Display Screen Size: 28" (70.8cm)
- Panel Type: TN
- Resolution: 3840x2160 (Only over DisplayPort at 60Hz)
- Colurs: 16.7M
- Bits: 8 bits+HiFRC
- Connectivity: 1x DisplayPort 1.2 (60Hz)
- VESA: 100x100mm
- Speakers: No
- Warranty: 2yr
Was [£569.99] Inc. VAT
ORDER NOW
AOC U2868PQU 28" 4K 60Hz 1MS Gaming Widescreen LED Monitor - Black @ £329.99 inc VAT
The U2868PQU from AOC is designed for gamers as it features a rapid 1ms response TN panel with a staggering resolution of 3840x2160. Your games will never have looked so good, but bear in mind to play the latest games at 4k resolutions you will need a minimum of 780Ti or 290X and ideally a pair running crossfire/SLI to play at 4k with maximum details with 60fps or more. This monitor is also 60Hz at 3840x2160 when connected via DisplayPort.
Featuring great connectivity with VGA, DVI, HDMI and DisplayPorts along with a full height adjust, pivot and swivel stand with VESA 100x100 support. Making the AOC U2868PQU ideal for eye-finity/surround setups. The monitors also includes stereo speakers and USB Hub as well.
Specification:-
- Size with stand (W x H x D ) : 658.9x560.6x245 (mm)
- Without stand (W x H x D ): 658.9x395.8x50 (mm)
- Panel Type: TN
- Dynamic Contrast Ratio: 80,000,000
- Connectivity: 1x HDMI, 1x DisplayPort, 1x DVI, 1x VGA, 1x USB Hub
- Stand: Height adjust, pivot & Swivel
- USB Hub: Yes
- Speakers: Yes
- Warranty: 3yr
Only £329.99 inc VAT.
ORDER NOW
Samsung S27A850TS 27" Widescreen Ultra Thin LED Professional PLS Monitor - Matte Black @ £269.99 inc VAT
nonl2br
Engineered with the ecologically responsible homeowner in mind, the Samsung monitor reduces power consumption by 40%;, making it much more efficient than conventional monitors. By reducing the number of LED and defaulting to standby power, which requires less than 0.3W as opposed to the typical 1.0W, the Samsung monitor is poised to make a difference. How big a difference? If your monitor saves 120W each day, that’s the annual equivalent of eliminating 10.8kg of CO2 emitted from an oil-burning power plant—which produces the same effect as planting four pine trees.<br /><br />
Choose a monitor that allows you to reduce financial and environmental costs as well as increasing productivity. The Samsung SA850 LED Business Monitor is designed to use less power, so you can cut bills and be kinder to the planet. A high 2560 x 1440 pixel resolution also makes sure you’ve got screen space for all your work and lets you see it all in greater detail. You’ll see images and video with stunningly natural colour thanks to sRGB support, and a 178 degree viewing angle gives great viewing from a wider range of perspectives, so it’s perfect for sharing presentations and more.<br /><br />
The Samsung SA850 Monitor showcases an astounding WQHD display with 2560 x 1440 pixel resolution, which is four times the resolution of HD (720p). It is perfect for businesses and industries that rely on access to extremely fine monitor detail. The wide screen, which features dual link DVI and display port, allows for more detail to be viewed and is ideal for work places such as hospitals, clinics and studios. The enhanced screen resolution provides greater efficiency and quality, and really is the must-have business tool. <br /><br />
Whether it’s video from an HD camcorder or photos from your digital camera, sRGB support makes sure that nature looks just as natural on your Samsung Monitor as it did when you shot it or filmed it. No matter what digital device the image was captured on, it’s as picture perfect on screen as Mother Nature intended it to be. So you can view, edit, and save images in their original format with no picture quality degradation whatsoever — which translates to 100%; pure digital satisfaction.<br /><br />
Provide employees with an optimal viewing experience in the office with the reasonably priced Samsung Business Monitor. While conventional monitors have a viewing angle of 170 degrees horizontally, the Samsung monitor has an extra wide viewing angle of 178 degrees. The additional 8 degrees is particularly useful when sharing on-screen information with one or more coworkers or presenting your ideas to clients. The Samsung Business Monitor has improved its vertical viewing angles by 18 degrees, making it the perfect display for giving presentations in front of a large audience or when viewing other content such as a video. <br /><br />
Maximise your viewing experience with Samsung’s superior PLS technology (Plane to Line Switching). Regular screens suffer from what is called Colour Shift, which reduces the picture quality and colour when viewed from an acute angle. The SA850, which can cover an amazing 178° viewing angle both vertically and horizontally, boasts a crisp and detailed picture by maintaining true-to-life colour, even when viewed from extreme angels, so the experience is always vivid and brilliant. <br /><br />
The Samsung LED Business Monitor SA850 has been designed to help boost work efficiency, delivering a tailored experience with its choice of viewer settings. The height-adjustable stand ensures that the screen can always be set at the optimal eye level, which enhances the visual experience while also helping maintain the viewer’s body posture. Other features include the tilt and pivot capabilities, which not only increase comfort levels but also introduce new ways of working. The SA850 Monitor can rotate 90°°° degrees, allowing for more appropriate view depending on the work. So, now you can take convenience and efficiency to amazing heights with the Samsung LED Business Monitor SA850.<br /><br />
If you need a work monitor that uses office space efficiently, then Samsung LED Business Monitor SA850 is the perfect choice. It features an innovative new detachable adaptor, which allows the monitor to be easily moved and installed. From physically moving the monitor with the carrying handle to quickly installing, the SA850 is ready to deliver an efficient and clean work space. The SA850 is also equipped and prepared for you as a VESA Wall mount, providing a multi-screen or wall mounted monitor. Optimising your office space is now easily achieved with the Samsung LED Business Monitor SA850<br /><br />
Utilising Samsung’s dual input feature, two PCs can now be viewed simultaneously on the one monitor screen. The SA850’s Picture by Picture capabilities allow for a far more flexible approach to work and ensure that content can be easily accessed, even if they require different PC access. This is perfect for businesses handling large and complex content from two PCs, but prefer to view it on one convenient screen. <br /><br />
As the work environment becomes increasingly modernised, it is essential that monitor also have the latest technology. Samsung SA850's USB Hub with USB 3.0 technology, which provides super-speed data transmissions, is the ideal solution for connecting all of your mobile devices. With a maximum speed of 5GB per second and uncompressed Full HD video transmissions, the USB Hub effortlessly brings your content together on one convenient monitor. <br /><br />
Eco saving makes saving energy easy, it adjusts the brightness of your Samsung monitor based on how much energy you want to save. And with the choice of three energy saving modes (50%;, 25%; and Power Saving off), you can really tailor your monitor use to meet your own personal needs. Samsung’s commitment to saving energy is designed to help both you and the environment, and with up to 50%; saving on consumption, you can really make a positive impact on your eco footprint. Take the effort out of saving energy and take control with Eco saving.<br /><br />
Take the guess work out of eco savings with Samsung’s new Energy Tree feature. For the first time, you can now know exactly how much energy you are saving through your eco modes such as the Eco light sensor and the Eco motion sensor. Through an intuitive energy saving status, which can be displayed either intuitively or graphically, you can keep tabs on your efforts to make the world a better place. <br /><br />
Features:-<br />
- 27" (16:9) <br />
- 300cd/m² Brightness <br />
- DCR Mega 8 Dynamic Contrast Ratio <br />
- 2560 x 1440 Resolution <br />
- 5ms Respond Time <br />
- 178° / 178° Viewing Angle <br />
- 16.7 Million Colour Support <br />
- Inputs: 1x Dual Link DVI, 1x DisplayPort, 1x HDMI<br />
- 3x USB <br />
- HAS (150mm) <br />
- Tilt / Swivel / Pivot <br />
- VESA: (100 x 100, 100 x 200) Available <br />
- USB 3.0 Super Power <br />
- 2yr Warranty<br />
Only £269.99 inc VAT.
ORDER NOW
Acer B326HUL 32" Widescreen LED Professional/Gaming Slim Bezel Flicker FREE Monitor - Black @ £359.99 inc VAT
The Acer B326HUL is a premium quality 32” display with WQHD resolution enabling sharper and more detailed content and true to life color accuracy for the most intense work applications and multi-tasking environments.
The B326HUL display is easy to adapt to personal needs and to integrate into any office environment, featuring a flexible height adjustment, tilt and swivel foot-stand.
The B326HUL 32’’ display provides multiple interface options, including HDMI, DisplayPort and traditional DVI, as well as 4 USB 3.0 ports with power-off charging. 100% sRGB, Acer eColor and ComfyView technologies make every pixel colorful and close to true colors making this monitor the perfect companion for graphic professionals and multimedia enthusiasts.
In additions the Acer Eco-Display technology used in the B6 series helps to minimize environmental impact and reduces the total costs of ownership (TCO).
The 2560 x 1440 resolution of this LED monitor delivers excellent detail with high pixel density, making it perfect for advanced HD productivity and specialized financial or CAD applications. View more details over a high quality large screen display with fantastic image consistency even from wide viewing angles.
6 axis color adjustment feature to meet the highest standard of color accuracy. Individual Hue and Saturation of Red, Green, Blue, Cyan, Yellow and Magenta colors can be customized by users.
sRGB provides users superb color accuracy and wide color coverage. With built-in sRGB color correction technologies, B326HUL reproduces rich color performance and captures images in their original and true colors.
"Low dimming" is designed for people to solve eye fatigue by brightness adjustment in dark environments. This design could provide more comfortable experience when user is in poor light conditions.
Features:-
- 32" WQHD 2560x1440 resolution, view 4 x HD applications
- Exceptional color accuracy with 100% sRGB coverage
- Robust Ergonomic stand: adjustable tilt, swivel, and height
- Extensive connectivity, including DVI, HDMI., DisplayPort. and USB Hub 3.0
- Eco-friendly design: ENERGY STARR qualified, EPEATR Gold rated and TCO 6.0
- Extensive connectivity: HDMIR, DisplayPort., DVI and USB 3.0
Specification:-
- Full Height adjust stand, pivot, swivel & tilt
- Screen Size: 32"W, VA LED
- Resolution (max.): 2560 x 1440
- Pixel Pitch: 0.276 mm
- Brightness: 300 cd/m2
- Contrast Ratio: 3000:1
- DCR: 20M:1
- Response Time: 4 ms GTG
- Display Color: 1.07 billion
- Viewing Angle (L/R;U/D) (CR>=10): 178 / 178
- Terminals: DVI-D / 2x HDMI / DisplayPort
- VA (AMVA+) LED Technology
- HDCP Support
- Speaker: 5W x2
- USB Hub: Yes
- VESA Wall Mounting (mm): 100 x 100 mm
- Warranty: 3yr
Was [£469.99] Inc. VAT
Only £359.99 inc VAT.
ORDER NOW
BenQ BL3200PT 32" Widescreen LED Professional/Gaming Slim Bezel Flicker FREE Monitor - Black @ £439.99 inc VAT
Accurate Color Gamut that brings your imagination to life, A Large Screen that extends your design space, High Resolution to view the smallest details, Ergonomic Features that ease your eye and neck strain... Result, A monitor that meets all your CAD/CAM needs!
With a 2560x1440 WQHD resolution and extra working space mean less scrolls for zooming in and out. Start using BenQ CAD/CAM Monitor now and boost your work efficiency!
The unique CAD/CAM Mode is specially designed to enhance work efficiency and reducing eye fatigue for all CAD/CAM users. By making the color contrast higher, every displayed line will be perfectly distinguished. With BenQ CAD/ CAM Monitors, you will never miss a line again in your designed work.
To clearly distinguish detailed textures in the darkest areas, BenQ developed Animation Mode that enhances brightness in dark areas without overexposing bright areas. With ten levels of brightness, the Animation Mode provides the comfort and freedom that every designer will welcome with open arms.
With the BenQ’s advanced 100% sRGB screen technology, every color is delivered with the finest precision in every detail and at every possible viewing angle. Get and share a professional viewing experience.
Auto Pivot detects the rotation of the monitor and dynamically rotates displayed content automatically. All windows will be equally portioned and displayed on the screen when clicking on the Desktop Partition icon, which allows you to compare all design works with just, one simple click. Moreover, you can preset different picture modes to each frequently used software. Display Pilot will automatically switch to your preferred picture mode in different user scenarios.
Unique control device docked to the stand of every BL3200PT monitor remotely accesses the OSD menu. Three pre-set hot-keys allow quick switching between 1. sRGB Mode, 2. CAD/CAM Mode, 3. Low Blue Light Mode, or let you assign your own set of display modes providing ultimate user flexibility.
Large screen monitors usually take a noticeable amount of space on the working desk. BL 3200 is designed to save as much of your workspace as possible. Compact stand architecture enables the screen to sit at the very edge of the desk and maximize your working space and comfort.
I/O ports on the side of the screen effortlessly bring all your content together in one convenient package. 2x USB 3.0 and SD card reader provide super-speed data transmissions.
The slim bezel makes the monitor look lighter and larger. In a multi-display setup with two or more units, thin bezels are less intrusive and effectively expand your work-space.
An extensive range of monitor adjustments – height, tilt, pivot, stroke and swivel – tailor your own unique working station that is best suited for your height and viewing habits with a maximum 150mm distance between the screen bottom and the base.
The Flicker-free technology eliminates flickering at all brightness levels and effectively reducing eye fatigue. Conventional LCD screens flicks 200 times per second. Your eyes may not see flickers, but they can certainly feel them. Free your eyes from flickers by switch to CAD/ CAM Monitors and let your eyes do less work while you are working on CAD/ CAM designs.
Every Monitor produces a strain of blue spectrum light that is one of the critical causes of eye damage, eye strain, headaches and sleeping disorders. BenQ's unique Low Blue Light technology is designed to deal with the everyday problem of blue light exposure and allows a healthier time spent in front of your computer. Switch to one of the four preset Low Blue Light Modes from OSD hot key (Multimedia – 30% reduction, Web-surfing – 50% reduction, Office – 60% reduction, Reading – 70% reduction), and reward your eyes without having to lose the visual enjoyment. Corporate users are frequently required to read documents from a monitor. Reading Mode adjusts the screen brightness, contrast ratio and sharpness to make your eyes feel as easy as reading directly from hard copies without wasting any paper.
Specification:-
- DCR: 20M:1
- Terminals: D-sub / DVI-D / HDMI / DisplayPort
- Flicker FREE technology
- Senseye® Human Vision Technology (plus Senseye 3)
- Advanced Motion Accelerator (AMA)
- HDCP Support
- Speaker: 5W x2
- USB Hub: Yes
- Dimensions(HxWxD mm) HIGH: 640.16*740.28*232.48mm
- Warranty: 2yr
Only £439.99 inc VAT.
ORDER NOW
Asus PG278Q ROG Swift 27" G-Sync 144Hz Gaming Widescreen LED Slim Bezel Monitor - Black/Red @ £599.99 inc VAT
Quite possibly the best gaming monitor ever made and ideally suited to NVIDIA cards with 3D Vision 2.0 and G-Sync technology. This monitor runs at a staggering 2560x1440 resolution with 144Hz technology and a 1ms response, even better this is the latest in TN technology.
The ROG SWIFT PG278Q represents the pinnacle of gaming displays, seamlessly combining the latest technologies and design touches that gamers demand.
This 27-inch WQHD 2560 × 1440 gaming monitor packs in nearly every feature a gamer could ask for. An incredible 144Hz refresh rate and a rapid response time of 1ms eliminate lag and motion blur, while an exclusive Turbo key allows you to select refresh rates of 60Hz, 120Hz or 144Hz with just one press. The ROG SWIFT contains integrated NVIDIA® G-SYNC™ technology to synchronize the display's refresh rate to the GPU. This technology eliminates screen tearing, while minimizing display stutter and input lag to give you the smoothest, fastest and most breathtaking gaming visuals imaginable. Connectivity is simple, yet robust, with a single DisplayPort 1.2 port to enable NVIDIA® G-SYNC™ and dual USB 3.0 ports for convenience.
Conventional 60Hz monitors show extensive motion blur which detracts from your gaming experience. The ROG SWIFT PG278Q Gaming Monitor with NVIDIA® Ultra Low Motion Blur technology* reduces the effects of motion blur by delivering crisp edges in fast-paced gaming environments for perceivable differences in natural movement.
ASUS-exclusive GamePlus Technology enhances your gaming experience further by providing you with crosshair overlays for FPS games and multiple in-game timers for RTS/MOBA games.
The ROG Swift has a super-narrow 6mm bezel that begs this monitor to be used in multi-display gaming set-ups. With VESA wall mount capability and an ergonomic stand designed with full tilt, swivel, pivot and height adjustments, the ROG SWIFT is ready for long gaming sessions in comfort.
The ROG SWIFT PG278Q represents the next generation in gaming displays. This WQHD 2560 x 1440 monitor delivers four times the resolution of 720p, with 109 pixels per inch or 109 RGB matrices per inch. This gives you the benefits of greater image detail and up to 77% more onscreen desktop space than standard Full HD (1920 x 1080) displays. These minor details add up to give you a major in-game advantage.
Unlock the highest frame rates available, decimate lag and say goodbye to motion blur to gain the upper hand in first person shooters, racers, real-time strategy and sports titles. With twice the frame rate of standard LCDs, the ROG SWIFT PG278Q Gaming Monitor encourages you to never blink again.
Response time and ultra-smooth gameplay are the hallmarks of a true gaming monitor. With a 1ms rapid response time – the fastest available – the ROG SWIFT PG278Q Gaming Monitor eliminates smearing, tearing and motion blur, allowing you to quickly react to your game.
NVIDIA®G-SYNC™ display technology delivers the smoothest, fastest and most breathtaking gaming imaginable. G-SYNC™ synchronizes the ROG SWIFT's refresh rate to the GPU in your GeForce GTX-powered PC, eliminating screen tearing and minimizing display stutter and input lag. Scenes appear instantly, while objects look sharper and more vibrant. Gameplay is fluid and responsive too, ensuring a serious competitive edge.
The ASUS Display R&D team works closely with NVIDIA to ensure that everything runs smoothly on ASUS G-SYNC™ monitors. The ROG SWIFT PG278Q gaming monitor with built-in G-SYNC™ delivers super smooth and stunning visuals.
The ROG SWIFT PG278Q is compatible with the NVIDIA® 3D Vision™ 1 and 2 kits* to support up to three WQHD displays for immersive multi-display 3D gaming experience. ROG SWIFT provides the finest 3D gaming and content viewing experience and thanks to the ever-growing library of over 700 3D Vision™ ready game titles, as well as 3D Blu-ray movies and YouTube 3D Playback support. See everything in a new dimension with the ROG SWIFT.
*Requires NVIDIA® 3D Vision™ kit, sold separately.
Features:-
- Crisp 27-inch, 2560 x 1440 visuals combined with fast 144Hz refresh rate, 1ms response time, made smooth by NVIDIA®G-SYNC™ technology
- Exclusive GamePlus onscreen timer/crosshair, 60-120-144Hz refresh rate turbo key and intuitive 5-way OSD navigation joystick
- Complete ergonomic tilt, swivel, pivot and height adjustment with VESA mount capability for optimal placement
Specification:-
- Fully adjustable stand: tilt/swivel/pivot/height
- Screen Size: 27" (68.47cm)
- Pixel Pitch: 0.233mm
- Resolution: 2560x1440 WQHD
- 2D mode: 2560x1440 (up to 144Hz)
- 3D mode: 2560x1440 (up to 120Hz)
- 2D Surround: 7680x1440 (up to 144Hz)
- 3D Surround: 7680x1440 (up to 120Hz)
- Panel: TN
- Refresh Rate: 144Hz
- Brightness: 350cd/m
- Contrast ratio: 1000:1
- Colour: 16.7M (Real 8-Bit)
- Connectivity: 1x DisplayPort (Display Cable and USB cables included)
- USB 3.0 Hub
- 3D Vision 2.0 Enabled
- G-Sync Enabled
- ULMB Enabled (NVIDIA Ultra Low Motion Blur Technology)
- Phys. Dimension with Stand(WxHxD): 619.77x362.96x237.9mm
- Box Dimension (WxHxD): 756x456x300mm
- Weight 7.5kg
- Full Specification: http://www.asus.com/Monitors/ROG_SWIFT_PG278Q/
- Warranty: 3yr (28 Day OcUK DOA, Asus After)
- OcUK Exclusive Service: Warranty regarding dead pixels falls under ISO rules and as such dead pixels if very few are not an actual fault. But at OcUK we value our customers especially when spending such a large amount of money on what is a flagship gaming monitor. As such even if you only have 1 dead/stuck pixel and it has not gone after 3 days, we will class the monitor as faulty and exchange it for you at no cost to you. This service is exclusive at OcUK for Asus ROG Swift ONLY or other qualifying monitors! (Valid for 28 days from purchase)!
Was [£629.99] Inc. VAT
Only £599.99 inc VAT.
ORDER NOW
Acer Predator XB270HA 27" G-Sync 144Hz Gaming Widescreen LED Monitor - Black/Red @ £329.99 inc VAT
nonl2br
<p>
Acer XB270HA gaming monitor as the world’s first 1080P 27" display featuring NVIDIA® G-SYNC™ technology to provide stunning, ultra-smooth, tear-free imagery and rich colors for outstanding gaming experiences. It features Acer’s flicker-less, low-dimming and ComfyView technologies that reduce strain on the eyes for smooth and comfortable extensive viewing.
</p>
<p>
The Acer XB270HA is intended to be paired with enthusiast PCs for immersive, ultra high-end gaming. It features a spacious 27-inch LED backlit display with True HD (1920 x 1080 pixels).
</p>
<p>
</p>
<p>
The Acer XB270HA features 170/160 degree viewing angles so that brilliantly-colored images can be seen from almost every angle. DisplayPort™ v1.2 transmits video signals and four USB 3.0 ports are conveniently located at the side and bottom of the display for connecting to keyboard, mouse or mobile devices.
</p>
<p>
The Acer XB280HA monitor is made with post-consumer recycled plastic and features a distinctive red ring on the base stand. The multi-functional ErgoStand allows the screen to tilt from -5° to 35° to ensure the best viewing angle; the base rotates 120° from left or right for easy screen sharing; the panel height can be raised by up to 150 mm for optimum comfort; and the screen pivots from horizontal to vertical for more viewing perspectives.
</p>
<p>
</p>
<center>
<object width="640" height="360"><param name="movie" value="//www.youtube.com/v/4qyrT7l0nwg?version=3&amp;hl=en_GB&amp;rel=0"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="//www.youtube.com/v/4qyrT7l0nwg?version=3&amp;hl=en_GB&amp;rel=0" type="application/x-shockwave-flash" width="640" height="360" allowscriptaccess="always" allowfullscreen="true"></embed></object>
</center>
<br><br>
<p>
<h1>Features:</h1>
- Flicker-less technology – stable power supply eliminates screen flicker particularly beneficial for heavy users by helping to reduce eye strain.<br>
- Low dimming technology – adjust to as low as 15 percent brightness in low light environments to make it easy on the eyes. Standard monitor settings start at 30 percent brightness level.<br>
</p>
<p>
<h1>Specification:</h1>
- G-Sync Technology<br>
- 3D Vision Technology<br>
- Flicker-less Technology<br>
- Height Adjust stand with tilt, swivel and pivot<br>
- Display Screen Size: 27" <br>
- Aspect ratio: 16:9<br>
- Panel Type: TN<br>
- Brightness: 300cd/m2<br>
- Contrast Ratio: 1000:1 (Typ)<br>
- Dynamic Contrast Ratio: 10,000,000<br>
- Resolution: 1920x1080 144Hz<br>
- Response Time: 1ms (GTG)<br>
- Colurs: 16.7M<br>
- Bits: 8 bits<br>
- Viewing Angle (H / V ): 170 ° / 160 °<br>
- Connectivity: 1x DisplayPort 1.2 (144Hz)<br>
- USB Hub 3.0: Yes (1up, 4down)<br>
- VESA: 100x100mm<br>
- Speakers: No<br>
- Warranty: 2yr
Was [£359.99] Inc. VAT
ORDER NOW
TeamGroup Vulcan RED 8GB (2x4GB) DDR3 PC3-19200C11 2400MHz Dual Channel Kit (TLRED38G2400HC11CDC01) @ £56.99 inc VAT
Named after the god of fire in Greek mythology, the Team Vulcan is the combination of high-end craftsmanship and top-notch technology. The short version heat sink of Team Vulcan prevents difficulty in installation due to large and bulky heat dissipation device of motherboard. The arrow-shaped opening design helps increase heat dissipation. In addition, the explosively red color combined with diamond cut pattern not only shows great texture but also the crazy sensation of over-clocking speed.
Made of chips from major manufacturers, Team Vulcan passes series of harsh testing and verification procedures which have proven its stability and durability. Currently, DDR3 2400 CL10, DDR3 2133 CL11, DDR3 1866 CL9/10/11 and DDR3 1600 CL9 are available to cover the mainstream Dual- and Quad-channel specifications that pretty much satisfy the demands of players of all levels.
Features:-
- Module Type 240Pin Unbuffered DIMM Non ECC
- CL-tRCD-tRP-tRAS 11-13-13-35
- DRAM Density 128x8 / 256x8 / 512x8
- Data transfer bandwidth 19,200MB/Sec (PC3 19200)
- Heat Sink Aluminum heat-sink
- Working voltage 1.55V-1.65V
- Warranty Lifetime warranty
- Haswell & AMD Richland compatible
Was [£65.99] Inc. VAT
Only £56.99 inc VAT.
ORDER NOW
TeamGroup Vulcan RED 16GB (2x8GB) DDR3 PC3-19200C11 2400MHz Dual Channel Kit (TLRED316G2400HC11CDC01) @ £107.99 inc VAT
Features:-
Was [£149.99] Inc. VAT
Only £107.99 inc VAT.
ORDER NOW
GeIL EVO Potenza 16GB (4x4GB) DDR4 PC4-24000C16 3000MHz Quad Channel Kit - Red (GPR416GB3000C16QC) @ £199.99 inc VAT
Potenza, the Italian word for “power”, hence the name of GeIL’s latest top of the line DDR4 Gaming Memory – EVO POTENZA. Speed of up to 3200MHz, available in Quad and Dual-Quad Kits, the DDR4 EVO POTENZA is designed for the latest Intel X99 chipset for maximum performance and compatibility.
EVO POTENZA is equipped with the Potenza heat-spreader, designed with GeIL’s MTCD – Maximum Thermal Conduction & Dissipation technology for superior cooling efficiency. EVO POTENZA is the new DDR4 performance benchmark that powers up your desktop.
Specification:-
- CPU Compatibility: Intel Haswell-E ( LGA 2011-3 )
- Chipset: Intel X99
- Capacity: 16GB (4GBx4)
- Quad Channel kit: Yes
- Tested Speed: DDR4-3000 MHz (PC4-24000)
- Tested Latency: 16-16-16-36
- Tested Voltage: 1.2V
- Registered/Unbuffered: Unbuffered
- Error Checking: Non-ECC
- Type: 288-pin UDIMM
- SPD Speed: 2133 MHz
- SPD Voltage: 1.2V
- Features: Intel XMP 2.0(Extreme Memory Profile)Ready
- Warranty: Lifetime
Was [£269.99] Inc. VAT
ORDER NOW
GeIL EVO Potenza 32GB (4x8GB) DDR4 PC4-24000C16 3000MHz Quad Channel Kit - Red (GPR432GB3000C16DQC) @ £399.95 inc VAT
Specification:-
- Capacity: 32GB (8GBx4)
- SPD Voltage: 1.2V
Was [£499.99] Inc. VAT
Only £399.95 inc VAT.
ORDER NOW
SuperFlower Leadex GOLD 650W Fully Modular "80 Plus Gold" Power Supply - White @ £74.99 inc VAT
nonl2br
Leadex series PSU are 80+ Gold certified with 100% fully modular cable design, our R&D team's latest innovation, a brilliant idea to maximize PSU cables & connectors management to have the best cable routing solution, also increase case chassis air flow to have best cooling for your system.
<br><br>
Ledex series PSU provides high efficiency & stable power output and come with a 14cm two-way thermal control intelligent cooling fan to ensure your professional PC system will work under heavy load, also capable of powering your PC system equipped with NVIDIA® SLI™ or ATI CrossFireX™ setup.
<br><br>
<h1>Features</h1>
- 100% Full Modular Cabling Design For Easy Cable Management
<br>- 80 PLUS ® Gold Certified, 90.43% 92.03% 90.27% Efficiency At 20% 50% 100% Rated Load
<br>- Full Range Auto Voltage Detection Design 100V~240V (Active PFC)
<br>- Comply With ATX 12V. V2.2, EPS 12V. V2.91 & SSI EPS 12V. V2.92 Specification
<br>- Comply With Energy Star Standard & EuP (Energy Using Products) Regulation
<br>- Over Voltage Protection / Over Current Protection / Over Power Protection / Short Circuit Protection / Under Voltage Protection
<br>- Support All Intel/AMD Multi-Core CPU & ATX/BTX Compatible Motherboards
<br>- Support NVIDIA® SLI™ & ATI CrossFireX™ High Performance Graphic Card
<br>- Patented Easy To Use & Install Crystal Clear Cube Connectors with LED
<br>- More than 2,000 times On/Off test
<br>- Unleaded Green Materials with RoHS/WEEE Compliance
<br>- Perfect For Professional & High Performance Gaming System
<br><br>
<h1>Specification</h1>
- Type: ATX
<br>- Maximum Power: 650W
<br>- Fans: 1 x 14cm
<br>- PFC: Active
<br>- +12V Rails: 1
<br>- Modular Cable: Yes 100% modular cable design
<br>- Input Voltage: Full Range - 100V~240V
<br>- Input Frequency Range: 50 ± 3 Hz / 60 ± 3 Hz
<br>- Output: +3.3V@22A ; +5V@22A ; [email protected] ; [email protected] ; [email protected]
<br>- Protection: OVP/OCP/OPP/SCP/UVP
<br>- Dimensions: 200mm(L) x 150mm(W) x 86mm(H)
<br><br>
<h1>Connectors</h1>
- 1x 20+4-Pin ATX12V/EPS12V
<br>- 1x 8-Pin EPS12V
<br>- 1x 4+4-Pin ATX12V/EPS12V
<br>- 4x 6+2-Pin-PCIe
<br>- 10x SATA
<br>- 5x 4-Pin-Molex
<br>- 1x Floppy
<br>- Warranty: 5yr
Was [£85.99] Inc. VAT
Only £74.99 inc VAT.
ORDER NOW
SuperFlower Leadex GOLD 1300W Fully Modular "80 Plus Gold" Power Supply - Black @ £129.95 inc VAT
nonl2br
<br><br>
<br><br>
<h1>Features:-</h1>
<br>- 80 PLUS ® Gold Certified, 91.09% 91.75% 89.25% Efficiency At 20% 50% 100% Rated Load
<br><br>
<h1>Specification:-</h1>
- Type: ATX
<br>- Maximum Power: 1300W
<br>- PFC: Active
<br>- +12V Rails: 1
<br>- Modular Cable Yes 100% modular cable design
<br>- Input Voltage Full Ranage - 100V~240V
<br>- Input Frequency Range 50 ± 3 Hz / 60 ± 3 Hz
<br>- Output +3.3V@24A ; [email protected] ; [email protected] ; [email protected] ; [email protected]
<br>- Protection OVP/OCP/OPP/SCP/UVP
<br>- Dimension 200mm(L) x 150mm(W) x 86mm(H)
<br><br>
<h1>Connectors</h1>
<br>- 8x 6+2-Pin-PCIe
<br>- 10x SATA
<br>- 1x Floppy
<br>- Review: http://www.jonnyguru.com/modules.php?name=NDReviews&op=Story6&reid=367
<br>- Warranty: 5yr
Was [£169.99] Inc. VAT
Only £129.95 inc VAT.
ORDER NOW
PRICES GO UP TOMORROW AT 10am, DO NOT MISS OUT!!!
PMSL
Seems to do the trick though. :)
Having said that the new revision Coils look like this.
They have an extra set of VRMs, which is great, but no glue? so how are they reducing Coil whine now?
No really, the fact that they glued the coils to start with is a clear indication that Powercolor recognises the problem and has done something about it, with no glue i'm wondering how are they doing it now?
Anyway, the PCS+ is a fantastic card. :) i have had 8 Months of trouble free, cool and quiet gaming from mine so far.
PMSL
Probably like our first reference 970 the factory found changing the containers to yield better results, so they went that way.
Our Galax card, well Galax decided to change both containers and also use glue.
That makes sense, the containers do look different, actually the whole power quarter of the PCB looks beefed up.
Indeed it is.
But I was being sarcastic, as to the reason why these manufactuers don't use glue in the first place
Indeed it is.
Because it does cost more and these manufacturers are trying to save every penny possible because when your producing product in the 100,000's a few pennies saved give them much higher profits or let them hit the market with lower price.
That is why we went out of our way with our 970's to simply build the highest quality item with no cost spared, because for me who is buying just a few thousand I am not concerned about having to pay more to have things changed because we now have cards available for customers that no competitor does, meaning we have smartly filled a void in the market and capitalised on it. :)
Yup, that's exactly what I think. Low grade components to maximize profits :)
The Truth ^^^^, some of the established brands of late have left me somewhat unimpressed.
Very thin PCBs, Plastic Shrouds, no Backplates on high end cards.... some of the establishment just feel plain cheap, not what you want from £300+ cards.
I know i go on about the PCS+, but handle it and some of established brands for comparison and you will know what i mean.
The PCS+ is heavy, ridged, it has a cold solid steel shroud, a thick cold brushed alloy BackPlate, a thick Satin Black PCB... it feels like a proper quality product, it never gets anywhere near hot, it doesn't dump a lot of heat into the case. and it just works beautifully without any complaints.
Its a well built, well engineered bit of kit.
i'm little tired of some premium brands, it seems they no longer have anything to prove and just sell a name, the few who do have something to prove it seems to me are the ones who put the work in.
The PCS+ is heavy, ridged, it has a cold solid steel shroud, a thick cold brushed alloy BackPlate, a thick Satin Black PCB... it feels like a proper quality product, it never gets anywhere near hot, its doesn't dump a lot of heat into the case. and it just works beautifully without any complaints.
Its a well built well engineered bit of kit.
It's always the same, when a brand gets popular they seem to start lacking and think it's okay because their name will hold them up. MSI for example sold the most 970's I believe, no backplate, cheap plastic cooler, many people had the fan issue if you used auto. The only reason I bought one is because of how well it overclocked in most reviews. I can't fault the card as I don't need a backplate, the cooler while being cheap plastic performs incredibly well and I didn't have the fan problem. It would be nice to see them make an effort though.
I think my next card I might choose one of the "lesser brands" as it seems they actually take time on their cards to try and gain customers.
Havn't bought anything for myself at all, not been impressed to be honest, did get a monitor for my daughter though. Just come back from the Usa where everything is so much cheaper, well nearly everything. :D
