Gaming Monitor for £250
  • Thread starter Thread starter Izi
  • Start date Start date
Not wishing to hijack the thread, but Joelk2, would any of those also be acceptable for general office work too...my load is split 50/50 between gaming and office work.
for office would i would suggest alternatives to be honest.
21:9 would be a great monitor for office work or even a 1440p monitor.
for anything colour specific then you dont want one of these either.
i mean my wife uses my PC for office work and she doesnt complain but i only use it for gaming hence the 144hz (i have another 60hz benq 24" next to it aswell though) so its not that it cant be used for office work but generally something different would prob be better.
personally if i was using my pc 50/50 id go for this. http://www.overclockers.co.uk/showproduct.php?prodid=MO-121-LG&groupid=17&catid=2898
from the reviews the response time is good so gaming you'd be fine. plus you get the added benefit of the widescreen for movies or office work.
Iiyama ProLite 27" 144HZ can be had for £250~.
It's what I'm considering, gets good reviews over at tft central.
