Aerocool Strike-X ONE Advance Midi Tower Case - Black @ £24.95 inc VAT
The Strike X-One Advanced Midi Tower from Aerocool is a very value minded case that scores well with a particular functional design and extensive venting options.
- All black chassis interior (0.5mm thickness)
- Supports Long VGA Cards up to 400mm
- USB3.0 x 2 + Audio (HD) + Mic
- Includes 1 x 12cm Red LED Fan (Front) & 1 x 12cm Black fan (Back)
- Dust filter for PSU
- 4 x ODD screw-less kit
- 6 x 5 1/4" < 3 1/2" convertor brackets – can be used as fan adaptor, can install 3.5" HDDs and 5" HDDs and can be used to install floppy or card reader.
- Cable Routing Management (pre-drilled holes on the MB plate)
- Pre-drilled CPU holes for easy mounting and removable of CPU cooler
- Motherboard Support: Micro ATX/ATX
- Dimensions: 440mm (H) x 180mm (W) x 475mm (D)
- Drive Bays: 4 x 5.25" (Exposed) / 6 x 3.5" HDD or 2.5 HDD
- Expansion Slots: 7
- Max length space available for PCI slots: 400mm
Only £24.95 inc VAT.
ORDER NOW
_____
BitFenix Front Panel Dual USB3.0 Bay - Black @ £5.99 inc VAT
Add two additional USB3.0 ports to your case to enable you to have a plethoria of peripherals connected to your PC.
- Dimensions: 101.5 x 25 x 119 mm (W x H x D)
- Space: 1x 3.5-inch slot
- Material: Aluminum (front)
- Color: Black
- Connectors on the panel: 2x USB 3.0
- Connector on the motherboard: 1x USB 3.0 (internal)
- Cable length: 50 cm
- Compatibility: Windows 2000 / XP / Vista / 7
Only £4.99 inc VAT.
ORDER NOW
ORDER NOW
_____
- Color: Black
Only £4.99 inc VAT.
ORDER NOW
