Miles per Gallon, computer seems accurate?
20 Oct 2002
Oxfordshire / Bucks
I know we've talked about Miles Per Gallon a million times already
but since changing my car not long ago, I filled it to the brim and tried to go as far as I could before I ran out of fuel (well until the light came on)
could you tell me if my MPG is correct ?
my manual says I have 55 litre tank
I filled it to the brim, and I did 340 miles when the light came on, and it said I still had 50 miles to go, so approx. 400 miles to the tank, computer says around 33 MPG, does that seem accurate to you?
The way to work it out manually.
Brim it. Drive until light comes on, Brim it and take note of how much you put back in along with the mileage. Doing it over multiple tanks makes it more accurate
ok ill do that for a while ill started it when I fill up again
but for now, what do you think ?
Your tank may well be 55l, but you probably only used 48.2l or something. You won't know exactly unless you brim it again, and take note of the litres you out in and the miles you have covered since last brimming it.
As bledd. Said, repeat over several tanks to increase accuracy. Personally I only ever brim my tanks (it's not like I won't use the fuel), note the mileage, average mpg over the tank and average mph over the tank, and fire that info into fuelly.com.
Obviously I reset one of my obc's at every fill, including the av. Speed and mpg so I can get that data. But after around 17k worth of doing this I have a pretty good idea now. Plus it lets me log every penny spent in running the vehicle.
Could be 10L still in the tank, without accurate data, I'd decline to comment.
What car is it?
You really don't need to use an app, the calculator on a smart phone is more than adequate for working out tank to tank consumption.
The working out is easy yes... but does it collate all the information and store it so you can see the past X amount of tanks and see the variance over a period of time? I think not
Or you could just look at the mpg reading on the dashboard occasionally and decide if mpg if it's getting better or worse.
You'd love my spreadsheet. 5 years worth of fuel logs, alerts me when service items are due and how old each consumable part is :D
see now that's how you do it! none of this calculator and remembering.
Technology is our friend! You have now given me something to set up tonight:cool:
