Hey Guys
We have stock landing tomorrow of the fantastic Corsair K70 mechanical keyboard.
This has been a best seller for us for ages now and we have managed to secure the last units of stock from Corsair in the UK.
We have plenty on the way, this is going to be the most affordable full featured mechanical board from Corsair.
Corsair K70 Mechanical Gaming Keyboard - Black – Red Switch (CH-9000011-UK) @ £89.99 inc VAT
The Corsair K70 is a fully mechanical, backlit keyboard that’s designed for performance gaming. The built-in Cherry MX Red switches deliver smooth, linear response for ultra fast double and triple taps without the audible click. Every key is individually lit for brilliant backlighting and easy customizability to highlight important functions. The black anodized brushed aluminum structure provides rugged durability and a professional-grade finish. Replaceable contoured keycaps make it easier to find critical WASD keys—even in dim light. Plus the 20 Key Roll-over and 100% Anti-Ghosting mean that every key you touch translates directly into the game.
- Cherry MX Red Mechanical Switches - Smooth, linear key response for ultra fast double and triple taps without the audible click
- Key-by-Key Customizable Backlighting - Deep red LEDs with adjustable brightness and per key programmability to light up just the keys you need. Save the keys for your favorite game directly to the keyboard.
- Contoured, Textured WASD Keycaps - Keep your eyes on the action with easy to locate FPS keys
- Anodized Black Brushed Aluminum Chassis - Professional-Grade look and feel plus the rugged durability needed for hours of gaming
- Full Key Matrix Anti-Ghosting with 20-Key Rollover - Every keystroke translates into accurate gameplay¡Xeven when multiple keys are pressed.
- Detachable full length wrist rest - Soft touch design that¡¦s comfortable for hours of play and comes off if it gets in your way.
- Cherry MX Red mechanical switches / 45g Actuation Force / 2mm to actuation and 4mm to bottom / Rated to 50 million operations / Gold contacts
- Replaceable contoured, textured WASD Keycaps / Additional keys for WASD and 1-6 number keys
- Up to 1000 Hz USB report rate
- Selectable 8ms, 4ms, 2ms, 1ms and BIOS mode
- Deep red LED backlighting with key-by-key programmability to light up individual keys / 650nm red LEDs
- Aluminum unibody construction for increased strength, durability and rigidity
- Six dedicated multimedia keys / STOP, PREVIOUS, PLAY/PAUSE, NEXT, MUTE, VOLUME UP/DOWN roller
- Windows Lock key for uninterrupted game play
- Product Dimensions: 438 x 166mm
- Product Weight: 1200g
Was £109.99 Inc. VAT
Only £89.99 inc VAT.
ORDER NOW
ORDER NOW
		 and whats the difference between this one and this one
