Radeon bios editing tools?
Come on AMDMatt where are you?!?!
I need to edit the bios permanently as I can't change anything in Unix fellas.
Any one know of any? I need to reduce my memory speed permanently.
No such tool exists Andy and if it did i would not expect any support from AMD. However i would suggest reaching out to the guy who did the bios tool for Tahiti. I spoke with him prior to working for AMD and he seemed to think it would be possible to edit the bios for Hawaii as well.
If your card is a reference based model with factory OC you could just flash a vanilla reference BIOS to it.
This guy made a bunch of custom 290/290X BIOSes for LTC mining back in the day, he may be able to answer some of your questions /shrug.
It's running a vanilla bios Uber.
Ah well, seems this will be the last AMD GPU I ever buy. Crap ! same as the 7970 I had I should have learned.
matt whats wrong with you! fix his Linux drivers
and give us 390x news alrdy :mad:
:p
doesn't rbe work then? I admit last bios I messed with was on a 5870 card
somebody should make one (matt clap your hand's n make it happen)
Not on Hawaii, only Tahiti based gpu's.
@Andy, there is the rbe thread over on tpu forums, if you read through it, someone has been editing some Hawaii bios for a few users, you might be able to contact the guy there and see if he can help you out.
What's the problem Andy?
The card I have is crap is the problem.
In Windows it's OK. Miles off of what it should be, no doubt down to the crap memory. However in Unix, where it is fully supported, with an official driver, it doesn't work properly.
I get artefacts all over objects in games until I close in on them and they redraw. And, I've heard this is down to the crap memory on my card because I have seen several reports of it happening on 290s with the crap memory in Windows.
The fix is apparently to down clock the ram so that it stops, yet in Unix there is no tool to do that so I'm completely stuck with a duff card again.
The 7970 I used to have did it too, and I dropped £439 on that.
Now I know why I always swore by Nvidia GPUs :(
http://forums.overclockers.co.uk/showpost.php?p=27281194&postcount=3
There's the issue. Everything is covered with glittery blocks, when you close in on them they redraw OK but eventually it just crashes out to desktop.
