Spec me a de-icer
All this debate about whether letting it idle or driving it gently is better... What about sitting stationary as you wait for the screen to clear, manually holding it at about 2000RPM?
Don't some performance engines have a much higher idle until they are up to temperature?
Yeah DC5 is nearly 2k on initial start when very cold!
The problem with this is the engine isnt under load, which behaves very differently on different cars.
That's the other thing heated windscreens are great for - stopping condensation build up when you first get in the car :D (particular issue for me as i'm out the door minutes after my hot shower :()
The only luxury my car has is a 12 hour digital clock
Being able to see is my no 1 priority :p
Thats emissions related and getting the cat up to temp rather than the bulk oil temp.
It is a good way to get your car stolen though.
I was just at a company this morning where this exact situation happened. The guy started his car, put his child in and went back to the house. Came back to the car and took the child out as he was going to be a bit longer in the house then as he went back the car was gone. Luckily the car was a company car and had a tracker installed but the poor guy was in bits wondering what would have happened if he hadn't gone back for his daughter.
I leave engine running, have a cup of tea and wear my work boots. Leave it running for about 7-8mins.
Why is that?
It's a phase change cooling effect.
As the hot water turns to vapor it rapidly cools the screen making any remaining liquid freeze faster.
Try this: Put 2 ice cube trays in the fridge, one hot, one cold and see which one freezes first.
The hot one wins every time!
Same as some others have mentioned, last winter I started using warm (tepid) water and I find it works far quicker than any deicer, and can drive off straight away. In the times I have done it I haven't had any problems so far, and saved not buying any de-icer.
Really not sure about this. As the warm water evaporates, it's not taking more heat from the window that it would have done if it were cold. It's evaporating because it's warm. Before it evaporates it will impart some of it's heat anyway.
This isn't the same as putting a wet towel around something to cool it, which is a convection effect. You need specific conditions for warmer water to freeze quicker than colder water and the reasons why and what these are aren't fully understood.
