Hi guys,
I was trying to Overclock my i5 4670K, and so far no problems, I reached 4.2Ghz with no problems andhonestly I don't need more, as I am not interested in having top results. My only concern is the way that the gigabyte deals the vcore voltage, if I leave it on Auto, it goes up to 1.365v which is extremely too much, but the fact to leave the setting on auto, does reduce the voltage in case the cpu goes down to 800mhz in idle situations.
As 1365v was to much I decided to reduce it, and I reached 1.200v, did a copule of usual tests and everything is ok. The only concern is, that now, even if the multiplier goes down to 8, so 800mhz the voltage of the vcore stays fixed at 1.200v, which is a non sense. Is there any way to have a variable vcore with this board without setting it to auto? I found the vcore offset but i really does not help. Any suggestions from any of you who has a gigabyte motherboard?
