Why does this happen ? Blue screen after moving any device to another USB port ?
12 Jul 2012
I'm using Windows 7 Ultimate 64 bit.
Ive had this happen a few times in the past, if you have a keyboard or another USB device in a certain USB port, then while the pc is switched off you unplug that device and move it to another port. You then boot up the pc, after a short while you get a blue screen error message, no matter how many times you reboot you get the same blue screen error message.
If you then unplug all the USB devices while the PC is off, do a reboot and plug them back into any port the PC is switched on everything is fine and the blue screen error messages go away. What's the cause for it to do that ?
It's looking highly likely that its to do with the TP Link TL-WN822N Wireless adapter that i'm using, they havn't updated the drivers for a long time and it seems like other people are having the same issues with regular blue screens from using this adapter with Windows 7 64 bit.
TP-Link arne't the chipset maker
Look up the model and see what chipset it has. I'd assume Atheros, or possibly Realtek.
If it's Atheros, visit https://www.atheros.cz and get the right driver.
