** PSU GUIDE BY GIBBO/8PACK TO TRY AND PREVENT COIL WHINE!! **
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
As people have requested it here is a guide on what PSU's should help to reduce mild/low coilwhine issues.
Key Points
  • Sometimes even the best PSU on the market will not eliminate coilwhine
  • Coilwhine is not a fault, it is how electricial devices work and any card can suffer it, particular high-end cards, such as dual GPU solutions
  • OcUK stance on coilwhine is if you have a quality PSU and the card has audible coilwhine on an open test bench, we will replace it.
  • Does 970 suffer from whine more so than other cards, well return rates cannot be conclusive of this as we are seeing nothing unusual in return rates but the majority of returns are related to whine issues.
  • Whether a PSU is 80+ Gold does not necessarily mean its a good quality PSU, it is down to the internal components used and frequencies etc.
No money no object, best quality PSU's ideal for Tri/Quad SLI that I/8 pack recommend
Antec High Current Pro 1300W "80+ Platinum" Fully Modular Power Supply @ £229.99 inc VAT
Antec's High Current Pro Platinum series is the pinnacle of power supplies. High Current Pro Platinum is fully modular with a revolutionary 20+8-pin MBU socket for the needs of tomorrow. By using a PSU that is 80 PLUS® PLATINUM & ErP Lot 6: 2013 certified, operating up to 94% efficient, you can reduce your electricity bill by up to 25% when compared to many other power supplies. HCP Platinum's innovative 16-pin sockets create a new level of flexibility by doubling the modular connectivity, supporting two different 8-pins connectors and even future connectors of 10, 12, 14 or 16-pins. All cables are darkened to become Stealth Wires and are thus nearly invisible in your chassis. 4 High Current Rails and a 100% +12V output ratio maximize HCP-1300 Platinum's capabilities to power the latest CPU's & GPU's. HCP Platinum's PhaseWave™ Design is a server-class "full-bridge" LLC design with a synchronous rectification based on a DC-DC topology. All Japanese capacitors achieve unprecedented tight voltage regulation & low ripple & noise to maximize your system's performance. Antec's intelligent Thermal Manager fan control spins the high-quality 13.5cm DBB fan optimally to cool your PSU quietly. CircuitShield™ makes the HCP-1300 Platinum safe and reliable in any environment with its nine industrial-grade protections. Backed by a 7 year warranty and lifetime global 24/7 support, the HCP-1300 Platinum embodies everything a power supply can accomplish today.
Specification:-
- 1300W Continuous Power - Guaranteed 1300W of Continuous Power from Antec
- 80 PLUS® PLATINUM certified - Up to 94% efficient, to reduce your electricity bill
- Save Energy and Money - Reduce your electricity bill by up to 25%
- 16-pin Socket - Industry-leading 16-pin sockets double the modular connectivity by supporting 2 different 8-pin cables per socket and allow for future connector changes
- 28(20+8)-pin MBU socket - World's first socket for possible future MBU connectors
- 135 mm DBB Silence - Whisper-quiet high-quality double ball bearing fan with long lifetime
- Thermal Manager - An advanced low voltage fan control for optimal heat & noise management
- High Current Rails - 4 High Current +12V rails with high load capabilities ensure maximum CPU & GPU compatibility
- 100% +12V - Output for maximum CPU & GPU support
- Multi PCI-E - 10 PCI-E connectors for multiple GPU support
- OC Link™ - Allows 2 HCP Platinums to work in tandem to power the most demanding systems
- CircuitShield™ - Full suite of industrial grade protections: Over Current Protection (OCP),
- Over Voltage Protection (OVP), Under Voltage Protection (UVP), Short Circuit Protection (SCP), Over Power Protection (OPP), Over Temperature Protection (OTP), Surge & Inrush Protection (SIP), No Load Operation (NLO) & Brown-Out Protection (BOP)
- All Japanese Heavy-Duty Caps - All high-performance Japanese capacitors ensure tightest DC stability and regulation
- PhaseWave™ Design - A server-class full-bridge LLC design with a synchronous rectification based on a DC-DC topology
- Stealth Wires - All wires darkened for minimal visibility in chassis
- Connectors: 1 x 24pin, 1 x 8pin(4+4pin)ATX12V/EPS12V, 1 x 8pin EPS12V, 10 x 8pin(6+2pin) PCI-Express, 6x Molex, 9 x SATA, 1 x Floppy, 1 x OC Link
- AQ7 - Antec Quality 7 year warranty and lifetime global 24/7 support
Only £229.99 inc VAT.
ORDER NOW
Corsair AX1500i Digital ATX 80 Plus Titanium Modular Power Supply (CP-9020057-UK) @ £359.99 inc VAT
AX1500i is the best enthusiast PC power supply you can own. It provides 1500 Watts of continuous power – even on 115V 15 Amp circuits – and 80 PLUS Titanium certified efficiency of over 94%. Zero RPM Fan mode ensures silent operation at low and medium loads, and the fully modular, low profile cable set makes for easy installation and great-looking builds. Corsair Link integration lets you monitor power usage and efficiency and customize performance, directly from your Windows desktop. The AX1500i lets you have it all, and it’s the power supply you want for your ultra-high performance PC.
Features:-
- The best enthusiast PC power supply you can own - The AX1500i is our flagship of power supplies, designed for use in truly remarkable PCs. Built with DSP control for amazing efficiency without compromising electrical performance.
- 80 PLUS Titanium certified efficiency - 80 PLUS Titanium certification guarantees 94% efficiency and silent operation at typical loads.
- Flat black, Low-Profile Modular Cables - You can remove unneeded cables and leave them in the box for fast, easy, and great-looking builds.
- 1500 watts of reliable, continuous power delivery - The AX1500i power ratings are continuous, not peak, for superior protection for your valuable PC. Corsair uses high-quality internal components like 105°c rated Japanese capacitors and is guaranteed to deliver clean, stable, continuous power even at a server grade 50°c ambient temperature.
Specification:-
- Digital Signal Processor (DSP) for delivering extremely clean, efficient power with real-time adjustments.
- Corsair Link. Integration for monitoring and adjustment of performance, noise, and OCP settings.
- 80 PLUSR Titanium Efficiency, delivering 94% energy efficiency at real world load conditions.
- ZeroRPM mode for fanless operation at low loads and outstanding noise reduction.
- 140mm thermally controlled fluid dynamic bearing fan spins up as needed.
- Fully Modular low profile cables for easy installation, less clutter, and helps maximize airflow through your computer¡¦s chassis.
- Engineered to meet maximum power output at a server-grade 50C temperature rating.
- Self-test switch to determine PSU functionality even before installation.
- The latest ATX12V v2.4 and EPS 2.92 standards and it is backward compatible with ATX12V 2.2, 2.31 and ATX12V 2.01 systems.
- 4th generation IntelR Core. processor Ready (Intel Haswell and Z87 motherboards).
- Over-voltage protection, under-voltage protection, and short circuit protection, over power protection, over temperature protection provide maximum safety to your critical system components.
- Safety and Agency Approvals: FCC, ICES, CE, UL / CUL, CSA, C-Tick/RCM, TUV, CB, CU, KC Mark, RoHS, WEEE, RoHS (China), REACH
- +3.3V 30A 180W +5V 30A +12V 125 A 1500W
Only £359.99 inc VAT.
ORDER NOW
EVGA SuperNova P2 1600W '80 Plus Platinum' Modular Power Supply (220-P2-1600-X3) @ £275.99 inc VAT
nonl2br
Introducing the EVGA SuperNOVA 1600 P2 power supply. This power supply raises the bar with 1600W of continuous power delivery and 92% (115VAC) / 94% (220VAC~240VAC) efficiency. A fully modular design reduces case clutter and 100% Japanese Capacitors ensures that only the absolute best components are used. What does that mean? The best stability, reliability, overclockability and unparalleled control. The EVGA SuperNOVA 1600 P2 is the ultimate tool to eliminate all system bottlenecks and achieve unrivaled performance.
<br><br>
<h1>Features</h1>
- 80 PLUS Platinum high efficiency power supply certified – 50% load (92% Efficiency)
<br>- Superior vertical double layer main transformer increases power output
<br>- 100% highest quality Japanese Nippon Chemi-Con solid state capacitors ensure long-term reliability
<br>- Fully Modular to reduce clutter and improve airflow
<br>- Quiet and Intelligent Auto Fan for near-silent operation
<br>- EVGA's unparalleled Customer Support
<br>- Ready for 4th Generation Intel Core Processors (C6/C7 Idle Mode)
<br>- High Amperage Single-Rail Design for maximum power and efficiency
<br>- Over Power/Under Power/Over Voltage/Short Circuit protection built in
<br>- An outstanding 10 Year Warranty
<br><br>
<h1>Specifications</h1>
- Operating Temperature: 0° to 50° C
<br>- Japanese Capacitors: 100%
<br>- ECO Mode: Yes
<br>- MTBF: 100,000 Hours
<br>- Net Weight: 3.63KG
<br>- Size: 85mm (H) x 150mm (W) x 200mm (L)
<br>- Approvals: TUV, CB, CE, FCC, RCM, cTUVus, BSMI, WEEE, RoHS
<br>- Compliance with ErP Lot 6 2013 Requirement
<br>- Fan Size / Bearing: 140mm Double Ball Bearing
<br><br>
<h1>Connectors</h1>
- 1 x 24 Pin ATX
<br>- 2 x 8 Pin EPS (4+4)
<br>- 9 x 6+2 Pin PCI-E
<br>- 5 x 6 Pin PCI-E
<br>- 16 x SATA
<br>- 6 x Molex
<br>- 2 x Floppy
<br>- Unbeatable 10 Year Warranty (after registration) and unparalleled EVGA Customer Support
Only £275.99 inc VAT.
ORDER NOW
Silverstone Strider SST-ST1500-GS "80 Plus Gold" Modular Continous Power Supply - 1600W Peak @ £209.99 inc VAT
To meet the requirements of current and future desktop computers, SilverStone created the Strider Gold S series power supplies. The Strider Gold S models are all new designs engineered to be the smallest, full-modular ATX power supplies at any wattage levels.
The Strider Gold S series includes wattage range from 550W to 1500W for a great variety of applications. With short depth designs, all models in the series are among the world’s smallest full-modular ATX PSUs. In addition to 80 PLUS Gold level efficiency, the Strider Gold S PSUs are built to meet very high standards in electrical performance with ±3% voltage regulation, ±3% ripple & noise, and high amperage single +12V rail. Other notable features included are 24/7 40? continuous output capability, low-noise fan, and multiple sets of PCI-E cables. For users looking for a power supply with faultless combination of compact size, performance, efficiency, and quality, the Strider Gold S Series is the only choice.
Features:-
- High efficiency with 80 PLUS Gold certification
- 100% modular cables
- 24/7 continuous power output with 40? operating temperature
- 1600W peak power
- Strict ±3% voltage regulation and low ripple & noise
- Silent running 135mm fan with 18dBA minimum
- Supports Eight PCI-E 8/6pin connectors
- Compact design with a depth of 180mm for easy integration
Specification:-
- combined +3.3, +5V: 150W
- combined +12V: 1440W/120A
- Input Voltage: 90V~264V
- Input Frequency Range: 47Hz ~ 63Hz
- PFC: Active PFC(PF>0.95 at Full Load)
- Efficiency: 87%~90%(at 20%~100% loading)
- MTBF: 100,000 hours
- Operating temperature: 0°C ~ 40°C
- Protection:
- Over current protection
- Over power protection
- Over voltage protection
- Over Temperature Protection
- Under voltage protection
- Short circuit protection
- No load operation
- Connectors:
- 1 x 24 / 20-Pin motherboard connector(550mm)
- 1 x 8 / 4-Pin EPS / ATX 12V connector(750mm)
- 1 x 8 / 4-Pin EPS / ATX 12V connector(550mm)
- 8 x 8 / 6-Pin PCIE connector("550mm / 150mm" x4)
- 16 x SATA connector(”600mm / 150mm / 150mm / 150mm” x4)
- 6 x 4-Pin Peripheral connector (”600mm / 150mm / 150mm” x 2)
- 2 x 4-Pin Floppy connector(”600mm / 150mm / 150mm / 150mm” x 2)
- Color: Black (scratch resistant and lead-free paint)
- Cooling System: Silent 135mm fan
- Noise Level: 18dBA-34dBA
- Dimension: 150 mm (W) × 86 mm (H) × 180 mm (D)
- Weight: 3.2Kg
- Form factor: ATX PS/2
- Certification: 80 PLUS Gold
Only £209.99 inc VAT.
ORDER NOW
SuperFlower Leadex Platinum 1200W Fully Modular "80 Plus Platinum" Power Supply - White @ £185.99 inc VAT
Leadex Platinum series PSU are 80+ Platinum certified with 100% fully modular cable design, our R&D team's latest innovation, a brilliant idea to maximize PSU cables & connectors management to have the best cable routing solution, also increase case chassis air flow to have best cooling for your system.
Ledex series PSU provides high efficiency & stable power output and come with a 14cm two-way thermal control intelligent cooling fan to ensure your professional PC system will work under heavy load, also capable of powering your PC system equipped with NVIDIA® SLI™ or ATI CrossFireX™ setup.
Features:
- 100% Full Modular Cabling Design For Easy Cable Management<br/>
- 80 PLUS ® Platinum Certified, 91.07% 92.44% 90.47% Efficiency At 20% 50% 100% Rated Load<br/>
- Full Range Auto Voltage Detection Design 100V~240V (Active PFC)<br/>
- Comply With ATX 12V. V2.2, EPS 12V. V2.91 & SSI EPS 12V. V2.92 Specification<br/>
- Comply With Energy Star Standard & EuP (Energy Using Products) Regulation<br/>
- Over Voltage Protection / Over Current Protection / Over Power Protection / Short Circuit Protection / Under Voltage Protection<br/>
- Support All Intel/AMD Multi-Core CPU & ATX/BTX Compatible Motherboards<br/>
- Support NVIDIA® SLI™ & ATI CrossFireX™ High Performance Graphic Card<br/>
- Patented Easy To Use & Install Crystal Clear Cube Connectors with LED<br/>
- More than 2,000 times On/Off test<br/>
- Unleaded Green Materials with RoHS/WEEE Compliance<br/>
- Perfect For Professional & High Performance Gaming System<br/>
Specification:
- Type: ATX <br/>
- Maximum Power: 1200W <br/>
- Fans: 1 x 14cm <br/>
- PFC: Active <br/>
- +12V Rails: 1 <br/>
- Modular Cable: Yes 100% modular cable design <br/>
- Input Voltage: Full Range - 100V~240V <br/>
- Input Frequency Range: 50 ± 3 Hz / 60 ± 3 Hz <br/>
- Output: +3.3V@20A ; [email protected] ; [email protected] ; [email protected] ; [email protected] <br/>
- Protection: OVP/OCP/OPP/SCP/UVP <br/>
- Dimension: 200mm(L) x 150mm(W) x 86mm(H) <br/>
<br><br>
<h1>Connectors</h1>
- 1 x 20+4-Pin ATX12V/EPS12V<br/>
- 1 x 8-Pin EPS12V<br/>
- 1 x 4+4-Pin ATX12V/EPS12V<br/>
- 8 x 6+2-Pin-PCIe<br/>
- 10 x SATA<br/>
- 5 x 4-Pin-Molex<br/>
- 1 x Floppy<br/>
- Warranty: 5yr
Only £185.99 inc VAT.
ORDER NOW
SuperFlower Leadex Platinum 1000W Fully Modular "80 Plus Platinum" Power Supply - Black @ £161.99 inc VAT
Features:
<br>- 80 PLUS ® Platinum Certified, 91.12% 92.53% 91.11% Efficiency At 20% 50% 100% Rated Load
<br>- Full Range Auto Voltage Detection Design 100V~240V (Active PFC)
<br>- Comply With ATX 12V. V2.2, EPS 12V. V2.91 & SSI EPS 12V. V2.92 Specification
<br>- Comply With Energy Star Standard & EuP (Energy Using Products) Regulation
<br>- Over Voltage Protection / Over Current Protection / Over Power Protection / Short Circuit Protection / Under Voltage Protection
<br>- Support All Intel/AMD Multi-Core CPU & ATX/BTX Compatible Motherboards
<br>- Support NVIDIA® SLI™ & ATI CrossFireX™ High Performance Graphic Card
<br>- Patented Easy To Use & Install Crystal Clear Cube Connectors with LED
<br>- More than 2,000 times On/Off test
<br>- Unleaded Green Materials with RoHS/WEEE Compliance
<br>- Perfect For Professional & High Performance Gaming System
<br>- Product Review: http://www.jonnyguru.com/modules.php?name=NDReviews&op=Story6&reid=340
<br><br>
<h1>Specification</h1>
- Type: ATX
<br>- Maximum Power: 1000W
<br>- Fans: 1 x 14cm
<br>- PFC: Active
<br>- +12V Rails: 1
<br>- Modular Cable: Yes 100% modular cable design
<br>- Input Voltage: Full Ranage - 100V~240V
<br>- Input Frequency Range: 50 ± 3 Hz / 60 ± 3 Hz
<br>- Output: +3.3V@20A ; [email protected] ; [email protected] ; [email protected] ; [email protected]
<br>- Protection: OVP/OCP/OPP/SCP/UVP
<br>- Dimension: 200mm(L) x 150mm(W) x 86mm(H)
<br><br>
<h1>Connectors</h1>
- 1x 20+4-Pin ATX12V/EPS12V
<br>- 1x 8-Pin EPS12V
<br>- 1x 4+4-Pin ATX12V/EPS12V
<br>- 6x 6+2-Pin-PCIe
<br>- 10x SATA
<br>- 5x 4-Pin-Molex
<br>- 1x Floppy
<br>- Warranty: 5yr
Only £161.99 inc VAT.
ORDER NOW
Summary on premium Power Supplies
In short myself and 8 Pack have our favourites when it comes to having the highest quality PSU, we both are very happy with the Superflower Leadex models, EVGA P series are also exceptional as they too are built by Superflower. Another firm favourite is the Antec HCP 1300W Platinum and of course the Corsair 1500i is a great unit but the price is very high and in short the EVGA 1600W Superflower units are superior. When it comes to these power supplies Superflower and EVGA are giving the best quality but also at a lower price point than competing brands.
High-end Power supplies built using quality internals!
Antec High Current Pro 750W '80 Plus Platinum' Fully Modular Power Supply @ £128.99 inc VAT
<br><br>
All cables are darkened to become Stealth Wires and are thus nearly invisible in your chassis. 3 High Current Rails and a 100% +12V output ratio maximize HCP-750 Platinum's capabilities to power the latest CPU's & GPU's. HCP Platinum's PhaseWave™ Design is a server-class LLC design with a synchronous rectification based on a DC-DC topology. All Japanese capacitors achieve unprecedented tight voltage regulation & low ripple & noise to maximize your system's performance.
<br><br>
Antec's intelligent Thermal Manager fan control spins the high-quality 13.5cm DBB fan optimally to cool your PSU quietly. CircuitShield™ makes the HCP-750 Platinum safe and reliable in any environment with its nine industrial-grade protections. Backed by a 7 year warranty and lifetime global 24/7 support, the HCP-750 Platinum embodies everything a power supply can accomplish today.
<br><br>
- 750w Continuous Power: Guarenteed 750w of continuous power from Antec
<br>- Manufactured by Delta Electronics
<br>- 80 Plus Platinum
<br>- Save Energy and money
<br>- 16pin socket; industry-leading 16-pin socket double the modular connectivity by supporting 2 different 8-pin cables per socket and allow for future MBU connections
<br>- 28 (20+8) pin MBU socket; Worlds first socket for possible future MBU connectors
<br>- 135mm DBB Silence: Whisper Quuiet high-quality double ball bearing fan with long life
<br>- Thermal Manager; An advanced low voltage fan control for optimal heat and
<br>- High Current Rail: 3 High Current +12v Rails with high load capacities ensure maximium CPU & GPU support
<br>- Multi PCI-e Support: 6 x PCI-e connectors
<br>- OC Link: Allows two HCP Platinums PSUs to work in tandem to power the most demanding systems
<br>- Circuit Shield: full suite of protections standards
<br>- All Japanese Heavy Duty Caps: All high-performance Japanese caps rated to 105 degrees to ensure the tightest DC stability and regulation
<br>- StealthWires: All cables are darkened for minimal visibility
<br><br>
<h1>Connectors</h1>
- 1 x 24 Pin
<br>- 1 x 8 (4+4) EPS/ATX Pin
<br>- 1 x 8 Pin EPS
<br>- 6 x 6+2 Pin PCI-E
<br>- 6 x Molex
<br>- 9 x SATA
<br>- 1 x Floppy
<br>- 1 x OC-LINK Cable
<br>- AQ7: Quality 7 year warranty and 24/7 lifetime support
Only £128.99 inc VAT.
ORDER NOW
EVGA SuperNova G1 1000W '80 Plus Gold' Modular Power Supply @ £119.99 inc VAT
The EVGA SuperNOVA 1000 G1 has arrived! This power supply is 80 Plus Gold Rated, offers 1000W of
continuous power, exceptional efficiency and is fully modular. Not to mention, a first class 5 Year EVGA Warranty.
Designed with enthusiast needs in mind the EVGA SuperNOVA 1000 G1 power supply is the best choice to power this and next generation enthusiast computers. Take your system to the next level and power up with the EVGA SuperNOVA 1000 G1!
Features:-
- 80 PLUS Gold certified, with up to 90% efficiency under typical loads
- NVIDIA SLI Ready
- Double Ball Bearing fan for exceptional reliability and quiet operation
- Heavy-duty protections, including OVP (Over Voltage Protection), UVP (Under Voltage Protection), OCP (Over Current Protection), OPP (Over Power
- Protection), and SCP (Short Circuit Protection)
- Unbeatable 5 Year Warranty and unparalleled EVGA Customer Support
Only £119.99 inc VAT.
ORDER NOW
EVGA SuperNova G2 750W '80 Plus Gold' Modular Power Supply @ £89.99 inc VAT
Unleash the next generation in power with the EVGA SuperNOVA 750 G2 Power Supply. Based on the award winning G2 series Power Supplies from EVGA, this PSU features 80 PLUS Gold rated efficiency, and clean, continuous power to every component. This provides improved efficiency for longer operation, less power consumption, reduced energy costs and minimal heat dissipation. The new ECO Thermal Control Fan System offers fan modes to provide zero fan noise during low load operations. Backed by a 10 year warranty and Japanese capacitor design, the EVGA SuperNOVA 750 G2 is not only the right choice for your system today, it is also the best choice for your system tomorrow.
Features:-
- Unbeatable 10 Year Warranty and unparalleled EVGA Customer Support
- Highest quality Japanese brand capacitors ensure long-term reliability
- NVIDIA SLI Ready
- Heavy-duty protections, including OVP (Over Voltage Protection), UVP (Under Voltage Protection), OCP - (Over Current Protection), OPP (Over Power Protection), and SCP (Short Circuit Protection)
Specification:-
- ATX Cable 1x 600mm (m)
- EPS Cable 2x 700mm (m)
- PCIE Cable 4x 700mm (m)
- SATA Cable 3x 550mm, 650mm, 750mm (m)
- Four-Pin Peripheral Cable 1x 550mm, 650mm, 750mm (m)
- Floppy Adapter 1x 100mm
- AC Power 1x 1500mm (m)
- CONNECTOR QUANTITY
- 24 Pin ATX 1x
- EPS (CPU) 2x 8pin (4+4)
- PCIE 4x 8pin (6+2)
- SATA 9x
- Four-Pin Peripheral 4x
- Floppy 1x
- INPUT
- Input Voltage 100 - 240 VAC
- AC Input 10A
- Input Frequency Range 50 - 60 Hz
- Efficiency Gold Rated - 90% Typical
- 12v - 62.4A
- Dimensions: 85mm (H) x 150mm (W) x 180mm (L)
- Approvals TUV, CB, CE, FCC, RCM, cTUVus, BSMI, WEEE, RoHS
- 10yr Warranty
Only £89.99 inc VAT.
ORDER NOW
SuperFlower Leadex GOLD 1000W Fully Modular "80 Plus Gold" Power Supply - White @ £149.99 inc VAT
Leadex series PSU are 80+ Gold certified with 100% fully modular cable design, our R&D team's latest innovation, a brilliant idea to maximize PSU cables & connectors management to have the best cable routing solution, also increase case chassis air flow to have best cooling for your system.
Features:-
<br>- 80 PLUS ® Gold Certified, 90.43% 92.03% 90.27% Efficiency At 20% 50% 100% Rated Load
<br><br>
<h1>Specification:-</h1>
- Type: ATX
<br>- PFC: Active
<br>- +12V Rails: 1
<br>- Output: +3.3V@24A ; [email protected] ; [email protected] ; [email protected] ; [email protected]
<h1>Connectors</h1>
<br>- 8x 6+2-Pin-PCIe
<br>- 10x SATA
<br>- 1x Floppy
<br>- Warranty: 5yr
Only £149.99 inc VAT.
ORDER NOW
SuperFlower Leadex GOLD 750W Fully Modular "80 Plus Gold" Power Supply - Black @ £99.95 inc VAT
Features
<br><br>
- Type: ATX
<br>- Maximum Power: 750W
<br>- PFC: Active
<br>- +12V Rails: 1
<br>- Input Voltage: Full Range - 100V~240V
<br>- Dimensions: 200mm(L) x 150mm(W) x 86mm(H)
<br><br>
<h1>Connectors</h1>
<br>- 4x 6+2-Pin-PCIe
<br>- 10x SATA
<br>- 1x Floppy
<br>- Warranty: 5yr
Only £99.95 inc VAT.
ORDER NOW
SuperFlower Leadex GOLD 650W Fully Modular "80 Plus Gold" Power Supply - Black @ £85.99 inc VAT
Features:
<br><br>
- Type: ATX
<br>- Maximum Power: 650W
<br>- PFC: Active
<br>- +12V Rails: 1
<br>- Output: +3.3V@22A ; +5V@22A ; [email protected] ; [email protected] ; [email protected]
<br><br>
<h1>Connectors</h1>
<br>- 10x SATA
<br>- 1x Floppy
<br>- Warranty: 5yr
Only £85.99 inc VAT.
ORDER NOW
Summary
In this area if you want quality and at a good value for money price both EVGA and Superflower are kings here, the engineering quality is undeniable and they are fairly priced. Also again Antec quality is unquestionable. Also anything that is built by Seasonic should also be fine, XFX for example.
Lower cost PSU that are still built using quality internals
This is a list of PSU's suitable for those who are building a gaming PC but cannot quite afford a quality PSU, this is where it becomes quite a mindfield as there are so many 80+ rated PSU's but the ratings are not a guarantee of quality components.
For example here is an 80+ Gold certified PSU I'd not touch with a barge pole, its built to a price point and as such we do not recommend it and it would whine like crazy potentially as well.
CiT 500W "80+ Gold Edition" 12cm Fan Silent Power Supply @ £19.99 inc VAT **NOT RECOMMENDED**
A value 80+ certified gold power supply for anyone building a budget PC system.
OcUK does not recommend this PSU for those building gaming PC's as this PSU is built to meet a price point and with power supplies you get what you pay for!
Features:
- Single 12v Rail
- Cooling: 12cm Silent Fan
- New Version Ver. 2.3
- Silent and Better Ventilation
- ATX 12V Compliant for all Types of CPU and Mainboard
Specification:
+5v: 30A
+3.3v: 28A
+12V: 27A
Only £19.99 inc VAT - OcUK DOES NOT RECOMMEND THIS UNIT!!
ORDER NOW - DO NOT BUY THIS IT IS JUNK!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
UNITS WE RECOMMEND!
Antec High Current Gamer 620W '80 Plus Bronze' Power Supply @ £64.99 inc VAT
Antec’s High Current power supplies are the perfect PSU combination of power and efficiency. The High Current Gamer features a high-power +12V rail and special heavy-duty High Current connectors and cabling that supply extreme levels of power, and also superb efficiency thanks to 80 PLUS® Bronze certification and Active PFC. Highest-quality gold-plated connectors, Japanese-brand capacitors and quiet 135 mm double ball bearing fans complete the package. If loads of power, High Current engineering and extreme efficiency are what you’re after, the High Current Gamer is the PSU for you.
- 80 PLUS® Bronze certified – up to 88% efficient
- High Current +12V rail for graphics card compatibility and over
current protection (OCP) for safety
- Quiet 135 mm double ball bearing cooling fan
- All Japanese brand capacitors for reliability
- Gold-plated High Current terminals for optimal conductivity
- ATX12V version 2.3 and EPS12V version 2.91 compliant
- Full industrial-grade protection:
- Over current protection (OCP), Over voltage protection (OVP), Short circuit protection (SCP), Over power protection (OPP)
- Active PFC with PF: 0.99 – less harmonic pollution and more
savings on corporate electrical bills
- Meets 2010 EUP requirement: 5Vsb < 1W
- Safety: cUL, TÜV, CE, CB, FCC, C-TICK, CCC, BSMI, Gost-R
- Weight: 4.4 lb / 2 kg
- Dimensions: 86 mm (H) x 150 mm (W) x 160 mm (D)
- AQ3 - 3 Year Warranty
Only £64.99 inc VAT.
ORDER NOW
Antec TruePower Classic 650w '80 Plus Gold' Power Supply @ £64.99 inc VAT
Antec's TruePower Classic series sets new standards for power supplies. TruePower Classic is one of the first series to comply with the toughest energy standard available, ErP Lot 6: 2013. By using a PSU that is 80 PLUS® GOLD certified, operating up to 92% efficient, you can reduce your electricity bill by up to 20% when compared to many other power supplies. Backed by a 5 year warranty and lifetime global 24/7 support, the TruePower Classic is the guaranteed gold standard for power. This unit provides two high current +12V rails with high load capabilities. 100% Full support for the new generation of Intel Haswell CPU's for full future upgradability, giving you complete peace of mind.
- 80 Plus Gold Certified
- Upto 92% efficient
- 648w output on the +12V Rails @ 30A per rail
- 120mm DBB Silence Fan
- Active PFC circuit providing PF value > 0.95
- Designed to sustain at 50?ambient with full load
- Multi PCI-Es to comply with Nvidia SLI and AMD Crossfire
- Advance LLC resonant topology to provide high efficiency
- Advance SR+DC to DC topology to provide excellent voltage regulation and ripple noise performance
- High Current Dual Rails
- Full Circuit Shield, including Over current protect, Over volt protect, under volt protect, short circuit protect, over power protect, over temperature protect, surge protect, no load operation and brown out protect.
- High Performance Japanese Capacitors ensure the tightest DC stability and regulation
- ErP Lot 6: Top standby energy standards
- Connectors: 1 x 20+4pin, 1 x 4+4pin, 6 x SATA, 5 x Molex, 1 x FDD, 4 x 6+2 PCI-Express
- Antec Quality Full 5 Year Warranty
ORDER NOW
EVGA SuperNova G1 650W '80 Plus Gold' Modular Power Supply (120-G1-0650-XR) @ £69.95 inc VAT
nonl2br
The EVGA SuperNOVA 650 Power Supply is here with Gold Rated Efficiency. Designed with enthusiast needs in mind the SuperNOVA series are the best choice to power next generation enthusiast computers. Combining 650W of continuous power with exceptional performance, stunning efficiency, and cutting-edge design and features, the SuperNOVA series power supplies are what you need to take your system to the next level.
<br><br>
<h1>Features</h1>
- 80 PLUS Gold certified, with 90% (115VAC) / 92% (220VAC~240VAC) efficiency or higher under typical loads
<br>- NVIDIA SLI Ready
<br>- Double Ball Bearing fan for exceptional reliability and quiet operation
<br>- Heavy-duty protections, including OVP (Over Voltage Protection), UVP (Under Voltage Protection), OCP (Over Current Protection), OPP (Over Power Protection), and SCP (Short Circuit Protection)
<br><br>
<br>- Japanese Capacitors: Main PCB
<br>- ECO Mode: No
<br>- Size: 85mm (H) x 150mm (W) x 180mm (L)
<br>- Approvals: TUV, cUL, UL, CB, CE, FCC, RCM, cTUVus, BSMI, CCC, WEEE, RoHS
<br>- Fan Size / Bearing: 135mm Double Ball Bearing
<br><br>
<h1>Connectors</h1>
- 1 x 24 Pin ATX
<br>- 4 x 6+2 PCI-E Pin
<br>- 9 x SATA
<br>- 6 x Molex
<br>- 1 x Floppy
Only £69.95 inc VAT.
ORDER NOW
SuperFlower Golden Green HX 450W "80 Plus Gold" Power Supply - Black @ £49.99 inc VAT
The Golden Green HX series are the perfect all rounder. They meet 80+ Gold Standards resulting in lower electricity usage, saving on the bills, hence the green. The Gold Rating means they are capable of powering pretty much any PC specification and the 14cm fan ensures the PSU stays cool whilst remaining quiet. One of our best value for money Gold Rated power supplies we sell.
Features:
- Supports all Intel and AMD Dual Core and Quad core and its compatible Motherboards, ATX/BTX compliant.
<br>- Supports Intel Core i7-980X / Core i7 / Core i5 / Core 2 Quad / Core 2 Duo &AMD Phenom II X6 / Phenom II X4 / Phenom II X3 / Athlon 64 X2series chip set.
<br>- EPS 12V Ver2.92
<br>- Patent black color connector, easy plug-in design, safe and firmly attached.
<br>- Fit in with EuP(Energy-using Products) instructions / U.S.A Energy Star standards: energy consumption during shut off status less than 1W
<br>- PCI-E power plugs are setup in a 6+2 configuration for the latest graphic cards and Compatible with every brand.
<br>- Patent 14cm LED Low Noise Fan, Great air flow for exceptional heat dissipation.
<br>- Passed 80 PLUS® Gold Certification, on 20% 50% 100% loading, with 91.64% 92.88% 90.99% Transform Efficiency.
<br>- Full Range APFC, support 100V~250V.
<br>- Patent high power and low consumption transformer / Patent dual voltage circuit with intelligence thermal control system (Patent applying for U.S.A, Taiwan, Mainland China and other countries)
<br>- Solid state Capacitance is used for longer lasting and higher reliability.
<br>- Extend Output Capacitance are used for higher stability and longer lasting.
<br>- Switches on/off test for more than 2000 times.
<br>- Multiple safety certificates acquired.
<br>- All series are made of RoHS unleaded green material.
Specification:
- Real Power: 450W
<br>- Transform Efficiency: on 20% 50% 100% loading, with 88.77% 92.82% 88.61% Transform Efficiency
<br>- Intel Power Design Guide: EPS Ver. 2.92
<br>- Outlook: Honeycomb ventilation panel, high efficiency air flow design
<br>- Fan Size: 12cm Silent Blue LED Fan with temperature control
<br>- Dimension: 145mm(L) x 150mm(W) x 86mm(H)
<br>- Safety Certificates: BSMI R33529 / CE / FCC / CUL / cTUVus / CB
<br><br>
<h1>Connectors</h1>
<br>- 1 x 4+4-Pin ATX12V/EPS12V
<br>- 2 x 6+2-Pin-PCIe
<br>- 4 x SATA
<br>- 3 x 4-Pin-Molex
<br>- Warranty: 5yr
Only £49.99 inc VAT.
ORDER NOW
SuperFlower Golden Green HX 550W "80 Plus Gold" Power Supply - Black @ £59.99 inc VAT
Features:
<br><br>
- Real Power: 550W
<br><br>
<h1>Connectors</h1>
<br>- 5 x SATA
<br>- 4 x 4-Pin-Molex
<br>- Warranty: 5yr
Only £59.99 inc VAT.
ORDER NOW
SuperFlower Leadex GOLD 650W Fully Modular "80 Plus Gold" Power Supply - White @ £85.99 inc VAT
Features:
<br><br>
Specification</h1>
- Type: ATX
<br>- PFC: Active
<br>- +12V Rails: 1
<br><br>
<h1>Connectors</h1>
<br>- 10x SATA
<br>- 1x Floppy
<br>- Warranty: 5yr
ORDER NOW
Summary
Please bear in mind this is a personal recommendation by myself and what me and 8 Pack would use in our own home systems, recommend to friends or use on our overclocking attempts. We might work for OcUK but when it comes to power supplies we get very personal as we've come across so many units that have all the labels, certifications and marketings to make them sound good, OcUK even sells many such PSU's but we'd not touch them. Above are our recommendations on getting the best build quality for your money and without a doubt both Superflower and Antec are our favourites. For those who are concerned how Superflower only goes upto 1300W, well in the new year we shall have models going upto 2000W and Titanium specification.
So the above is what we would use personally and our first port of call is always Superflower, they have simply out shown all other brands when it comes to using the highest quality components and this shows in reviews that do ripple test, Superflower are normally always King for lowest ripple results, this is why some users have reported Superflower units reducing or eliminating coil whine for them. But bear in mind some cards are beyond help no matter what PSU you use.
When it comes to power supplies, remember if your building a high-end gaming PC that is like a sports car engine and anyone here old enough and lucky enough will know highly strung engines only run to their full potential and optimal ability when fuelled on premium fuels such as Shell Vpower/Nitro for example, run a high performance car on supermarket fuel and they can run terrible.
A high performance PC is no different, the power source needs to be of very high quality to ensure not only stable running but to try and keep noise levels to a minimum, especially electrical noise.
Of course the PSU cannot cure cards with coilwhine beyond help, but in short if your buying Superflower OEM built power supplies or Antec and then going with say a graphics card that is built around reducing coilwhine you will be very unlucky if you experience any whine.
So if your building a gaming PC then please do not try to save money on buying a PSU with cheap internals, it is simply not a good idea and our recommendations are as per above.
In short anything Superflower HX and Leadex are very high-end internally. Antec are also a good shout and also Seasonic OEM built units as well. I personally will not recommend anything else, though we do sell many other models so you are free to chose but you asked for my recommendation and well you have it. :)
Well i had the superflower golden green hx550 and i had bad (what i thought was bad) coil whine on my msi 970
Also had the evga 600b, which was the same also
Much appreciated Gibbo. I am going to pull the trigger today on getting a new PSU as my coil whine is pretty unpleasant... just to confirm, if I get one of the recommended PSUs and it whines, then its okay to send to RMA?
I'm looking at the sub £70 models...
Hi there
OcUK has taken moves to try and completely eliminate any kind of coilwhine by designing cards which incorporate coil whine reduction technologies on the 970 series.
Here are both those cards designed by myself and exclusively available from OcUK and www.caseking.de
OcUK GeForce GTX 970 "NVIDIA 970 Cooler Edition" 4096MB GDDR5 PCI-Express Graphics Card **WorldWide Exclusive** @ £319.99 inc VAT
nonl2br
This very special NVIDIA GeForce GTX 970 is the only one of its kind designed by our in-house VGA Guru Gibbo making this the worlds ONLY genuine reference 970 available in the world. Gibbo's design request were very specific, genuine NVIDIA 970 cooler, yes the crazy expensive one just like the 980 cooler and a NVIDIA BGA Board using all original NVIDIA components with absolute zero cost down in the design.
<br>
<br>
Infact Gibbo improved the design by changing the containers in which the inductors are located for better quality items to help reduce and eliminate any possibility of coil whine. We also instruct our factory to only build these cards with Samsung memory. So why buy this over any other 970, well it is most likely the quietest whilst under load (gaming) due to having the NVIDIA cooler and any chances of coil whine have being pretty much eliminated with the design changes Gibbo has had implemented.
<br>
<br>
So this card is ideal for those seeking as little noise as possible and the other major advantage is the NVIDIA cooler which offers much better cooling performance in smaller enclosures or when running in 2-way or 3-way SLI.
<br>
<br>
Finally of course this card is perfect for when Half Life 3 is finally released at some point in the future and of course the latest GTA V game which is now confirmed!
<br>
<br>
The GTX 980 is the worlds fastest GPU and the GTX 970 offers the most advanced performance in its class. Each delivers 2x the performance of previous-generation card, bringing new gaming experiences to virtual reality, and ultra resolution 4k displays.<br /><br />
Enable the detail of 4k monitors, on a 1080P display. DSR produces smoother images by rendering a game at a high resolution, then downscaling it to the native resolution of the display using advanced filtering.<br /><br />
GeForce GTX 980 and 970 cards support tear-free, super-fast NVIDIA G-Sync monitor display technology including 4k. Together, these technologies provide the most immersive and competitive gaming experiences possible.<br /><br />
Features:-<br />
- Voxel Global Illumination Technology (VXGI)<br />
- NVIDIA® Super Resolution technology<br />
- NVIDIA® GameWorks technology<br />
- NVIDIA® GameStream technology<br />
- NVIDIA® TXAA Technology<br />
- NVIDIA GPU Boost 2.0<br />
- NVIDIA PhysX® Technology<br />
- NVIDIA FXAA Technology<br />
- NVIDIA Adaptive Vertical Sync<br />
- NVIDIA Surround<br />
- Support for four concurrent displays including: Two dual-link DVI, HDMI and DisplayPort 1.2<br />
- Microsoft DirectX 12<br />
- NVIDIA® 3D Vision® Ready<br />
- NVIDIA SLI® Ready Technology<br />
- NVIDIA CUDA® technology<br />
- PCI Express 3.0 support<br />
- OpenGL 4.4 support<br />
- OpenCL support<br />
- NVIDIA SHIELD Ready<br />
- NVIDIA G-Sync Ready<br />
<br /><br />
Specification:-<br />
- Genuine NVIDIA 970 Cooler with Visualizer<br />
- Genuine NVIDIA 980 PCB<br />
- Samsung memory guaranteed<br />
- Coil Whine reduction technology: We specify the capacitors/inductors to be enclosed in plastic containers as it helps reduce/eliminate coil whine<br />
- GeForce GTX 970<br />
- GPU: GeForce GTX 970 (GM204)<br />
- Core Base Clock: 1050MHz<br />
- Core Boost Clock: 1178MHz (Upto 1268MHz Boost)<br />
- Memory Clock: 7010MHz <br />
- Memory Size: 4096MB Samsung GDDR5<br />
- Bus Type: PCI Express 3.0<br />
- Memory Bus: 256-bit<br />
- CUDA Cores: 1664<br />
- DirectX 12: Yes<br />
- DVI Port: 1x Dual-Link DVI, 3x DisplayPort & 1x HDMI<br />
- DisplayPort: Yes <br />
- HDCP: Yes<br />
- HDMI: Yes<br />
- Power: 2x 6-Pin<br />
- 450W PSU Required<br />
- 145W TDP<br />
- Dimensions: 268.6 x 98.4 x 40 mm<br />
- Warranty: 3yr<br />
Only £319.99 inc VAT.
ORDER NOW
GALAX GeForce GTX 970 OC Silent "Infinity Black Edition" 4096MB GDDR5 PCI-Express Graphics Card **WorldWide Exclusive** @ £299.99 inc VAT
Since Overclockers UK introduced our Infinity system range, demand for high performance zero compromise systems has exploded. Our Infinity brand represents performance hardware coupled with a unique and stylish aesthetic.
Since the release of high end Maxwell architecture, the hardware game has changed. The new GeForce cards offer revolutionary new technologies and class leading performance alongside low operating temperatures and impressive power consumption.
The GALAX GeForce GTX 970 OC Silent "Infinity Black Edition" is a collaboration of one of the largest Nvidia board partners worldwide, Overclockers UK Graphics Specialist: Andrew Gibson and Overclockers UK Technical Specialist & Overclocking World Champion, Ian ‘8Pack’ Parry.
Originally the Galax 970 EX OC Black Edition was intended as a high performance option for customers looking for the ultimate gaming experience with class leading performance. Our close partnership with Galax allowed us to specify a list of important modifications that would make the GALAX GeForce GTX 970 OC Silent "Infinity Black Edition" a real show stopper.
Primarily, to fit the Infinity aesthetic, we demanded that the external design of our Black Edition card was sleek and stealthy. Adding to the already imposing look of the Galax design, this new, aggressive appearance really highlights the intent behind this product.
Additionally to the colour change, we included a nickel plated I/O plate, heatsink and heatpipes to compliment the premium nature of the product. The already impressive backplate on the card has been accented with a stylish "Infinity: Inspired by 8 Pack" decal.
The imposing looks of the card would be nothing without the ‘go’ to back up all the show.
Building on the already impressive performance of the GTX 970 platform, world class overclocking expertise from 8Pack has been implemented to fine tune the BIOS of this card to achieve maximum safe, reliable performance from the GTX 970.
As an industry leading gaming and high end hardware specialist, Overclockers UK understands the importance of offering a product that meets a customer’s expectation. A major worry for any enthusiast is operational noise under load. We have used this knowledge to reduce coil whine by using higher quality components and also using glue to attach the inductors to the PCB to help reduce electrical vibrations which help reduce whine.
This collaboration with Galax has allowed us to build what we believe to be the finest example of a GTX 970 on the market today.
This product is exclusively available from Overclockers UK and Caseking group throughout UK and Europe. We suggest European customers visit www.caseking.de to purchase this card in Western Europe and Eastern European customers purchase from http://www.kellytech.hu/
Features:-
- OcUK Zero Coil Whine guarantee*
- All Black Design!
- Nickel plated I/O Plate
- Nickel plated heatsink and heatpipe
- All black shroud/cooling design
- Black PCB
- Black Backplate
- Inductors placed in higher quality containers and glued to PCB to reduce coil whine
- Extreme factory overclock with huge OC potential
- Anodized aluminum backplate protects components and reinforces the PCB
- All new Silence Extreme cooler reduces temps by up to 10C
- Silence Extreme technology switches to single fan cooling at idle for almost noiseless operation
Quad mixed-gauge heat pipes ensure maximum heat dissipation
- Copper base with solid aluminum cover
- 5 + 2 Phase enhanced power system with 8 + 6-pin inputs delivers up to 50% more power for overclocking
- NVIDIA Surround
- OpenCL support
Specification:-
- GeForce GTX 970
- Core Base Clock: 1178MHz
- Core Boost Clock: 1329MHz
- Memory Size: 4096MB GDDR5
- CUDA Cores: 1664
- DirectX 12: Yes
- DVI Port: 2x Dual-Link DVI, 1x DisplayPort & 1x HDMI
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 1x 8-Pin & 1x 6-Pin
- 450W PSU Required
- 150W TDP
- Zero coil whine guarantee
- KitGuru Review: http://www.kitguru.net/components/g...rce-gtx-970-oc-silent-infinity-black-edition/
- Warranty: 2yr
*If your card emits any coilwhine when used on a decent power supply that is 80+ Gold rated or higher then OcUK will refund or exchange the card. These cards incorporate our exclusive Coil Whine Reduction technology to help reduce and eliminate any whine.
Only £299.99 inc VAT.
ORDER NOW
The first card is built using no cost down methods whatsoever and is why it is built on a 980 PCB which is way beyond what a 970 required and we had the inductors placed in higher quality containers to keep any noise to a minimum and then had insulating pads between the inductors and genuine NVIDIA cooler.
The second card was built again using highest possible quality inductors and containers, but we then also had them attached to the PCB using glue which can be very clearly seen as the glue used is red.
These steps help to reduce and eliminate coilwhine completely! :)
Which is a card which is beyond help and we would replace for you. :)
Yes, the PSU will not always cure it but me and 8 Pack have used and tested so many and the ones above are what we both recommend, we personally would not buy or recommend anything else.
Of course OcUK as a store sells many other models and brands, they are just simply brands neither myself or 8 Pack would use in our own PC, so take that as you see fit. :)
Couple of reviewers have been discussing with me about the EVGA G2 series almost surpassing the Sea Sonic Gold units in tests and performance as wel as general build quality. Definitely a new contender. The digital Corsair series are also one of the few 1KW+ PSU's to get immensely high scores, on par with the Sea Sonic units.
I'll also reiterate after doing tests on the CiT gear, they're one of the most dangerous PSU's available on the market. Managed to get one to go pop after 12 minutes of a stress test.
This, long long time ago used to have a 600w cit. it literally blew up (nothing died though), this is from a single 560ti and a phenom 955.
Well 8 Pack proved this, he took a Superflower 1200W Platinum and a Corsair 1200i Platinum.
The Corsair was struggling to power three 290X cards whereas the Superflower unit powered four 290X without struggling. Huge difference on internal quality.
Also as a bit of insider info, the Superflower Platinum units were actually built and engineered to meet Titanium specification and that is why they tend to do so well.
Yes that is why next to the CiT unit I put a massive warning saying I DO NOT RECOMMEND, but its a perfect example of how ratings mean absolutely nothing, it is an absolute piece of junk! But there is a market for junk unfortunately........
Flogged it (the 970) somebody elses problem now haha
Bailey did raise the rma for it, but didnt fancy driving to you or run the risk of the rma failing and id have to pay shipping etc
So i have no ill feeling etc towards ocuk, you did everything asked of you and it boiled down to me in the end
nice to know thanks
i'm sure i read the "be quiet" range maybe the dark power ones say there is no whine a all in there advertising as is with mine :)
No coil whine on the PC I've just built with this PSU, it is powering a 2500K/GTX760 gaming rig & its for my nephew, it will be him that will be gaming with it & if it did have CW he wont hear it as he uses headphones.
For 50 quid (black friday deal) first impressions of the golden green hx550 are good, considering I've bought a fair few Seasonics over the years.
Very informative post here Gibbo, I like it. There are many brands on the market that claim to be the best, sadly most of these are ok, but not the best.
I think you have summed up the best of the best out there on the market today. I would use any of the above PSU's personally (except that CIT lol). I was the buyer of PSU's at OcUK for almost 6 years as well so I know what kind of return rates all PSU brands have, including some of the other brands that are considered "good" - (NOT naming any of them though)
Great post and further proof that if you skimp on the PSU in your build, you end up buying twice. You can't go wrong with a Superflower/Delta/Seasonic made PSU!
Good info here, it does baffle me why people spend £600+ on there build then stick a cheap Chinese 600w PSU in it for £20 then it blows killing some of that money!
Good to know my 1000W platinum Super Flower is on the approved list. I bought it to future-proof my power requirements and bought it while on offer, so sounds like a made a good investment :)
Can I ask what "coil whine reduction technologies" means....is it actually new technology or is it just marketing speak for "we used other components" to make it sound like something special....or is it an actual researched and designed technology you have spent time and money on?
Yes we had the factory try several different solutions for trying to reduce it, which they spent about a month doing and place the cards under sound testing. After researching several methods the best solution is what we have now.
So yes we have invested money and the cards cost us more because so. :)
