Ah-hah, fair play Gibbo, thanks for sating my curiosity as far as it goes. Do you have any 'if you must' recommendations? Again, I am playing Devil's Advocate here, but I am sure there are many for whom they simply cannot stretch to £50 and are working at an absolute budget. If not completely understood, I think many would appreciate the feedback on the varying quality of the cheaper units from 'If you must' to 'buy at your own risk!'.
And certainly no disagreements on the Superflower, I have seen the Johnny Guru reviews and they are excellent seemingly across the board essentially, I have already recommended at least one unit which was purchased from yourselves last week
PPS...please don't say Q-Tec
All I would recommend if budget was tight would be these:
SuperFlower Golden Green HX 350W "80 Plus Gold" Power Supply - Black @ £41.99 inc VAT
nonl2br
The Golden Green HX series are the perfect all rounder. They meet 80+ Gold Standards resulting in lower electricity usage, saving on the bills, hence the green. The Gold Rating means they are capable of powering pretty much any PC specification and the 14cm fan ensures the PSU stays cool whilst remaining quiet. One of our best value for money Gold Rated power supplies we sell.
<br><br>
<h1>Features</h1>
- Supports all Intel and AMD Dual Core and Quad core and its compatible Motherboards, ATX/BTX compliant.
<br>- Supports Intel Core i7-980X / Core i7 / Core i5 / Core 2 Quad / Core 2 Duo &AMD Phenom II X6 / Phenom II X4 / Phenom II X3 / Athlon 64 X2series chip set.
<br>- EPS 12V Ver2.92
<br>- Patent black color connector, easy plug-in design, safe and firmly attached.
<br>- Fit in with EuP(Energy-using Products) instructions / U.S.A Energy Star standards: energy consumption during shut off status less than 1W
<br>- PCI-E power plugs are setup in a 6+2 configuration for the latest graphic cards and Compatible with every brand.
<br>- Patent 14cm LED Low Noise Fan, Great air flow for exceptional heat dissipation.
<br>- Passed 80 PLUS® Gold Certification, on 20% 50% 100% loading, with 91.64% 92.88% 90.99% Transform Efficiency.
<br>- Full Range APFC, support 100V~250V.
<br>- Patent high power and low consumption transformer / Patent dual voltage circuit with intelligence thermal control system (Patent applying for U.S.A, Taiwan, Mainland China and other countries)
<br>- Solid state Capacitance is used for longer lasting and higher reliability.
<br>- Extend Output Capacitance are used for higher stability and longer lasting.
<br>- Over Voltage Protection / Over Current Protection / Over Power Protection / Short Circuit Protection / Under Voltage Protection
<br>- Switches on/off test for more than 2000 times.
<br>- Multiple safety certificates acquired.
<br>- All series are made of RoHS unleaded green material.
<br><br>
<h1>Specification</h1>
- Real Power: 350W
<br>- Transform Efficiency: on 20% 50% 100% loading, with 88.77% 92.82% 88.61% Transform Efficiency
<br>- Intel Power Design Guide: EPS Ver. 2.92
<br>- Outlook: Honeycomb ventilation panel, high efficiency air flow design
<br>- Fan Size: 12cm Silent Blue LED Fan with temperature control
<br>- Dimension: 145mm(L) x 150mm(W) x 86mm(H)
<br>- Protection: OVP/OCP/OPP/SCP/UVP
<br>- Safety Certificates: BSMI R33529 / CE / FCC / CUL / cTUVus / CB
<br><br>
<h1>Connectors</h1>
- 1 x 20+4-Pin ATX12V/EPS12V
<br>- 1 x 4+4-Pin ATX12V/EPS12V
<br>- 2 x 6+2-Pin-PCIe
<br>- 4 x SATA
<br>- 3 x 4-Pin-Molex
<br>- Warranty: 5yr
Only £41.99 inc VAT.
ORDER NOW
SuperFlower Golden Green HX 450W "80 Plus Gold" Power Supply - Black @ £49.99 inc VAT
nonl2br
<br><br>
<h1>Features</h1>
<br><br>
- Real Power: 450W
<br><br>
<h1>Connectors</h1>
<br>- 4 x SATA
<br>- Warranty: 5yr
Only £49.99 inc VAT.
ORDER NOW
These two are great quality and the price really is very good considering the quality of the internals.
