OcUK Staff
 - 26 Nov 2014
 - Stoke
Now in stock and ready to ship! Great looking aluminium finished case with the Bitfenix ICON™ technology, a programmable LED display that you can set to pretty much whatever you like! Also available with side window at no additional cost.
BitFenix Pandora Micro-ATX Case - Black @ £94.99 inc VAT
Pandora represents the next level of BitFenix chassis design. The soft curved design is surrounded by luxuriously brushed aluminium side panels that give the entire case a timelessly elegant look that melds perfectly with any modern décor. On the front of the case is another innovation dubbed BitFenix ICON™ - a programmable display that can be customized with a simple drag and drop interface, making it simple to personalize the look of your case whenever inspiration strikes. Despite its slim 160mm width, Pandora can accommodate high octane hardware, such as 240mm water cooling radiators, and expansion cards up to 50mm in length. Users are able to house up to two 3.5" HDDs or three 2.5" SSDs, and to keep all of this hardware running cool, a direct airflow design along with smart cable management features help ensure everything runs frosty. Friendly features like pre-installed standoffs and pop off screwless side panels help get your system up and running quickly, while magnetic dust filters allow for easy clean up.
Specifications:-
- Material: Aluminum, Steel, Plastic
- Dimensions: 160 x 420 x 465
- Form Factor: Micro ATX, Mini-ITX
- LCD: 2.4" TFT, 240 x 320
- 3.5" Driver Bays: 2
- 2.5" Driver Bays: 3
- Cooling top: 120mm x 1 (included)
- Cooling Front: 120mm x 2 (1 included)
- PCI Expansion slots: 5
- Front Panel: USB 3.0 x 2, HD Audio
- Power Supply Support: ATX, up to 180mm in length
- USB 3.0 x 2, HD Audio
Only £94.99 inc VAT.
ORDER NOW
BitFenix Pandora Core Micro-ATX Case - Silver @ £83.99 inc VAT
Pandora represents the next level of BitFenix chassis design. The soft curved design is surrounded by luxuriously brushed aluminium side panels that give the entire case a timelessly elegant look that melds perfectly with any modern décor. Despite it's slim 160mm width, Pandora can accommodate high octane hardware, such as 240mm water cooling radiators, and expansion cards up to 50mm in length. Users are able to house up to two 3.5" HDDs or three 2.5" SSDs, and to keep all of this hardware running cool, a direct airflow design along with smart cable management features help ensure everything runs frosty. Friendly features like pre-installed standoffs and pop off screwless side panels help get your system up and running quickly, while magnetic dust filters allow for easy clean up.
Specifications:-
Only £83.99 inc VAT.
ORDER NOW
Specifications:-
ORDER NOW
Specifications:-
ORDER NOW
