Samsung Launches the new 850 EVO to replace the 840 EVO range of SSD's
22 Apr 2014
Here is the new range of Samsung 850 EVO's and the specs for each one. I have stock on order and hope to get a small quantity before Christmas but that all depends on Samsung shipping them in time. If not it will be the New Year for stock. I will keep everyone updated with info in this thread.
Samsung 120GB 850 EVO SSD 2.5" SATA 6Gbps 32 Layer 3D V-NAND Solid State Drive (MZ-75E120BW/EU @ £73.49 inc VAT
Specifications
  • Controller: Samsung MGX Controller
  • DRAM Cache Memory: 256MB
  • Sequential Read: 540Mbps
  • Sequential Write: 520Mbps
  • 4KB Random Read (QD1): Max 10,000 IOPS
  • 4KB Random Write (QD1): Max 40,000 IOPS
  • 4KB Random Read (QD32): Max 94,000 IOPS
  • 4KB Random Read (QD32): Max 88,000 IOPS
  • Reliability: MTBF: 1.5 million hours
  • TBW: 75TBW
  • Data Security: AES 256-bit Full Disk Encryption (FDE) / TCG/Opal V2.0 Encrypted Drive (IEEE1667)
3D V-NAND Technology and THE SAMSUNG SSD 850 EVO
Samsung’s unique and innovative 3D V-NAND flash memory architecture is a breakthrough in overcoming the density limitations, performance and endurance of today’s conventional planar NAND architecture. 3D VNAND is fabricated by stacking 32 cell layers vertically over one another rather than
decreasing the cells dimensions and trying to fit itself onto a fixed horizontal space resulting in higher density and better performance utilizing a smaller footprint.
The 850 EVO is the advanced consumer SSD powered by 3D V-NAND technology that maximizes everyday computing experiences with optimized performance and enhanced reliability.
Optimized performance for everyday computing experiences
Powered by Samsung's cutting-edge 3D V-NAND technology, 850 EVO delivers top-class sequential and random read and write performance to optimize everyday computing. With improved performance thanks to TurboWrite technology the 850 EVO provides not only more than a 10% better user experience than 840 EVO but up to 1.9x faster random write speeds for the 120/250 GB models as well. In fact, the 850 EVO delivers top class sequential read (540 MB/s) and write (520 MB/s) performance in all capacities. This comes with optimized random read and write performance on all QD and improved QD1 and QD2 random performance for Client PC usage.
Reinforcement of TurboWrite Technology
In the early stages of the 840 EVO, Samsung adopted sequential write performance first. With TurboWrite, write speeds are significantly accelerated during data transfers by creating a high-performance write buffer in the SSD. If a consecutive write operation (i.e. no idle time) exceeds the size of the buffer, the transfer will exit TurboWrite and be processed at ”After TurboWrite” speeds. Once the buffer is cleared, TurboWrite performance will resume. However, the buffer size for TurboWrite is more than sufficient for everyday PC use, and you should experience accelerated speeds for most workloads.
For the 850 EVO, enhanced TurboWrite technology applied to random write speeds up to 1.9x faster for the 120 GB model and 1.25x faster for the 250GB model over the 840 EVO.
Guaranteed endurance and reliability for maximum use
The 850 EVO delivers guaranteed endurance and reliability by doubling the TBW compared to the previous generation 840 EVO backed by an industry leading 5 year warranty. With twice the endurance of a typical NAND flash SSD, the 850 EVO will keep working as long as you do. The 850 EVO guarantees a 5 year limited warranty or 75TBW for 120GB and 250GB, 150TBW for 500GB and 1TB.
Enhanced reliability with improved sustained performance
With enhanced reliability through improved sustained performance, the 850 EVO assures long-term dependable performance up to 30% longer than the 840 EVO with minimized performance degradation. This means you can use it every day when taking care of work or entertaining yourself knowing it will keep performing even with heavy daily workloads over the years.
Advanced data encryption
The 850 EVO provides the same data encryption feature as the 840 EVO does. Self-Encrypting Drive (SED) security technology will help keep data safe at all times. It includes an AES 256-bit hardware based encryption engine to ensure that your personal files remain secure. Being hardware based, the encryption engine secures your data without performance degradation that you may experience with a software-based encryption. Also, 850 EVO is compliant with advanced security management solutions (TCG Opal and IEEE 1667). Magician will guide ”How to use security features”. Furthermore, you can erase or initialize data with the crypto erase service with PSID.
Efficient power management for all PC applications
Power consumption affects everyone. You actually save of up to 50% more on power than with the 840 EVO during write operations thanks to 3D V-NAND consuming half the power of 2Dplanar NAND.
Plus, whether it’s preserving battery life for longer cordless use or just saving on costs, power management is important. Device sleep signals the SSD to enter a low power state which is vital for ultra-books and other battery powered devices. With 850 EVO’s Device Sleep at a highly efficient 2mW you get longer battery life on your notebook thanks to a controller optimized for 3D V-NAND. With the 850 EVO you can work and play longer without having to plug in.
Summary
  • SATA 6Gb/s SSD for Client PCs
  • 2.5 inch form factor
  • Samsung 32 layer 3D V-NAND
  • Samsung Magician Software for SSD management
  • Samsung Data Migration Software
Only £73.49 inc VAT.
ORDER NOW
Samsung 250GB 850 EVO SSD 2.5" SATA 6Gbps 32 Layer 3D V-NAND Solid State Drive (MZ-75E250BW/EU) @ £109.99 inc VAT
Specifications
  • DRAM Cache Memory: 512MB
  • 4KB Random Read (QD32): Max 97,000 IOPS
  • TBW: 75TBW
Only £109.99 inc VAT.
ORDER NOW
Samsung 500GB 850 EVO SSD 2.5" SATA 6Gbps 32 Layer 3D V-NAND Solid State Drive (MZ-75E500BW/EU) @ £198.49 inc VAT
Specifications
  • 4KB Random Read (QD32): Max 98,000 IOPS
  • 4KB Random Read (QD32): Max 90,000 IOPS
  • TBW: 150TBW
Only £198.49 inc VAT.
ORDER NOW
Samsung 1.0TB 850 EVO SSD 2.5" SATA 6Gbps 32 Layer 3D V-NAND Solid State Drive (MZ-75E1T0BW/EU) @ £367.49 inc VAT
Specifications
  • Controller: Samsung MEX Controller
  • DRAM Cache Memory: 1GB
  • TBW: 150TBW
Only £367.49 inc VAT.
ORDER NOW
How do these compare to the 840's? I was lining up a 840 500gb drive but now wondering if there's benefit in holding out for the 850 :)
Some good info here posted within the last 20 minutes >> http://www.bit-tech.net/hardware/storage/2014/12/08/samsung-ssd-850-evo-review/1
Nice to see they have improved the 3 year warranty of the 840 EVO with a 5 year warranty on the 850 EVO's, also lower power consumption, very nice indeed. :)
bit-tech | 8th December 2014 said:
Thanks to the higher endurance of 3D V-NAND, Samsung is now offering a five year warranty with the SSD 850 EVO compared to three years before (the MX100 also has three years). This warranty covers 75TBW (total bytes written) for 120GB and 250GB drives, which is around 40GB/day over five years, and 150TB TBW for 500GB and 1TB models (around 80GB/day). Relative to the rest of the market, these ratings are very high.
As 3D V-NAND consumes roughly half the power of 2D NAND, the SSD 850 EVO will have lower power consumption that the SSD 840 EVO. It also now supports the DEVSLP ultra-low power idle state, which is likely to appeal to laptop users. Samsung once again uses LPDDR2 memory for the drives' DRAM cache, which is 256MB (120GB model), 512MB (250GB and 512GB) or 1GB (1TB) in size.
have 120gig 840 evo i a box for os still didn't bother installing it till i get 500 gig version hopefully cheaper as when these ones are out
Seem a bit pricey given some 240/256GB drives can be had for around £75. I know these are a little faster, but not enough to make it worthwhile, unless i'm missing something.
