Hi there
I've negotiated some supported pricing with NEC and stock is readily available on these truly stunning 4k monitors from NEC which are extremely high-end mainly targeting the professional user:
NEC MultiSync EA244UHD 24" 4K Widescreen Professional LED Monitor - Black @ £899.99 inc VAT
NEC is ushering in a new era of visual experience with the MultiSync® EA244UHD.
The EA244UHD is a high performance IPS display with the latest 4K UHD (3840x2160) super resolution and accurate wide colour gamut capability. Offering the very latest DisplayPort connectivity (UHD at 60 Hz), as well as a range of DVI and HDMI inputs, this monitor can be used in many mission critical applications, where decision making is based on highly detailed, accurate and reliable image quality. Outstanding ergonomic comfort makes it very user-friendly and further enhances professional productivity.
Features:
- Rich detail and complete image overview - 4K UHD resolution 3840x2160.
- Uncompromising image quality and more realistic colour reproduction - 10-bit IPS AdobeRGB Wide Gamut Colour.
- Multi-source management - Advanced Picture-by-Picture to show simultaneously up to 4 different images from a variety of video inputs.
- Ergonomic Office - full height adjustability (130 mm), swivel, tilt and pivot functionality ensures perfect individual ergonomic set-up.
- Minimize power consumption - Human Sensor detects the presence of a person in front of the screen; display switches on/off automatically depending on the presence of the user.
- Comprehensive network-wide asset management and easier remote support - NaViSet Compatible.
- Expanded connectivity - 6 signal inputs (DVI-D, DP, HDMI, USB) and MHL connection for latest smartphone office productivity.
- Straightforward radiological review applications - DICOM Simulation.
Specification:-
- Diagonally Viewable Size: 60.47 cm
- 23.8" (23.8-inch wide viewable image size)
- Aspect Ratio: Widescreen (16:9)
- Panel Type, Surface: In-plane switching, anti glare with hard coat 3H
- Optimal resolution: 3840 x 2160 at 60 Hz (DP1.2) / 3840 x 2160 at 30 Hz HDMI
- Contrast Ratio: 1000: 1 (typical) 2 Million:1 (Max) (Dynamic Contrast Ratio)
- Brightness: 350 cd/m2 (typical)
- Response Time: 5ms (gray to gray)
- Viewing Angle: (178° vertical / 178° horizontal)
- Color Support: Color Gamut (typical): Adobe RGB 99%, sRGB 100%
- 1.07 Billion colors (10 Bit)
- Pixel Pitch: 0.137 mm
- Pixel Per Inch (PPI): 185
- Backlight Technology: LED
- Display Type: Widescreen Flat Panel Display
- Display Screen Coating: Antiglare with hard-coating 3H
- Connectivity: 1x HDMI connector, 1x HDMI with MHL, 2x DisplayPort (version 1.2a), 2x DVI-D, 4x USB 3.0 ports - Downstream (4 at the back, 1 with battery charging), 1 USB 3.0 port - Upstream
- Full height adjust stand with pivot, tilt and swivel
- Weight (with packaging): 10.0 kg (22.05 lbs)
- Bezel Width [mm] 14.8 (left and right); 18.1 (top and bottom)
- Dimensions (W x H x D) [mm] 558.2 x 386.7 x 218
- VESA Mounting [mm] 100 x 100
- Warranty: 3yr
Only £899.99 inc VAT.
ORDER NOW
NEC MultiSync EA244UHD 24" 4K Widescreen Professional LED Monitor - White @ £899.99 inc VAT
Features:
Specification:-
- Warranty: 3yr
ORDER NOW
NEC MultiSync PA322UHD 32" 4K Widescreen Professional LED Monitor - Black @ £2,099.99 inc VAT
Professional Reference 10-bit IPS type LCD panel W-LED with IGZO technology 32" UHD Display UHD Display delivers uncompromising image quality as well as minimising lifecycle environmental impact. Uniting outstanding colour reproduction, class-leading ergonomics, latest DisplayPort, HDMI and DVI connectivity, ambient light sensor and 10-bit IPS type LCD panel with IGZO technology performance makes it ideal for mission critical applications requiring absolute attention to detail.
The ideal display for all creative professionals, designers, photographers, CAD-CAM, video-editing, finance, precision engineering, medical imaging, broadcasting and industrial applications (e.g. NDT) and anyone who cares about their visual work.
Features:
- Ambient Light Sensor - with Auto Brightness function always sets optimised brightness level according to ambient light and content conditions.
- Enhanced imaging performance - advanced settings of all relevant visual parameters for full control of brightness, colour, gamma and uniformity with Spectraview Engine.
- Ergonomic Office - full height adjustability (150 mm), swivel, tilt and pivot functionality ensures perfect individual ergonomic set-up.
- Stunning "pixel-free" ergonomic viewing - delivered by an Ultra High Definition (3,840 x 2,160) Professional LED backlit 10-bit IPS type LCD panel with IGZO technology.
- Reliable colour reproduction - due to 10-bit colour performance, wide gamut covering 99% of AdobeRGB, and hardware calibratable 14-bit LUT for accurate image presentation.
Future Ready with Extension Slot based on OPS Form Factor - upgrade the capabilities of your display at any time without the need for external cables or devices.
- Advanced Picture by Picture - simultaneously show up to 4 different video inputs.
Specification:-
- Diagonally Viewable Size: 80 cm
- 31.5" (31.5-inch wide viewable image size)
- Response Time: 10ms (gray to gray)
- Viewing Angle: (176° vertical / 176° horizontal)
- Connectivity: 4x HDMI connector, 2x DisplayPort (version 1.2a), 2x DVI-D, 4x USB 3.0 ports - Downstream (4 at the back, 1 with battery charging), 1 USB 3.0 port - Upstream
- Weight (with packaging): 15.0 kg
- VESA Mounting [mm] 100 x 100 & 200x100
- Warranty: 3yr
Only £2,099.99 inc VAT.
ORDER NOW
Features:
Specification:-
- Warranty: 3yr
ORDER NOW
Features:
Specification:-
- Warranty: 3yr
ORDER NOW
Features:
Specification:-
- Warranty: 3yr
ORDER NOW
