I have to enter the code on my radio if the temperature drops below -3. It's like it forgets the settings or something![]()
French?
Is it a "V" serial or a "M" serial on your radio? The "V" is dealer only but the "M" is simple to get.
Pretty much as everyone above has said, the physics of a car battery mean they don't work so well in cold weather so if it's poorly that can finish it off.
Also if it's been poorly for a while and the voltage been dropping it suffers permanent damage due to a process called 'sulphation' - there'll be a decent explanation of it on the web if you google it.
http://www.wisegeek.com/how-does-sulfation-drain-a-battery.htm
Just to check with your new battery is it a silver calcium type? Didn't know this myself till recently but Ford run a 'smart' charging system and they specify this type of battery is used.
Ahhh! You're still around here, neglecting the road cycling thread I see!![]()
Thank you OCUK, solved it! Found a code via an app on Google Play. Cost me £1.89 but it was cheaper than getting Ford to do it!
Now to dispose of the old one....
Ah great, that's reassuring to know that that is all likely to be wrong with it. More annoying is that I don't have the audio code from the previous owners so the radio will be down until I pay Ford £25 for a new code....
you can get £2 to 5 for it depending on size just have to find a place that recycles battery'sSorry should have said to PM me I would get it for free on M codes.
As for the old battery, the tat men will take it off your hands, just leave it at the side of the road and it will disappear.
