Legs
Squats
WU (15,15,15,45,65)
5x8x75 2 min rests
Not huge weight but 40 reps is the aim. Will slide weight up from here by 2.5 per session
SLDL - or at least what I think they are (bar on rack, lift, step back, drop it down and hump it back up with straight legs)
WU (15,15,35,45)
3x8x55 60s rest
Don't think I got these right - bit too much back involved? Didn't feel much hamstring going on.
Bulgarians
8xBW(x each leg)
8x10kg (holding plate)
8x20kg (on right only, left just couldn't keep stable. Foot was turning over / out a lot)
First set was worst and I should use bar on shoulders as plate interferes with knee. Good exercise to work my balance. Right leg hates being on bench - hip tightness galore I would guess.
Hanging leg raise
3x15
What, they've got leg in the title haven't they?! Found it hard to control the swaying at first, then tried bent knees from 3rd set onwards and realised I'd probably just been swinging my legs about 15 times! So started count again.
Then some stretches -
3 x Each leg straight in the air, then across body to touch opposite hand. Really feel those in outer quad / outer hip area.
5 x Bridge ridge hold for 5s
Mmmm, impending leg DOMS tomorrow? Any other exercises I can stick in given I've got a bar, squat rack and bench only?
Other leg ideas discounted are lunges (too similar to Bulgarians?), calf raises or indeed anything calf based (seem a bit pointless), box jumps (could do weighted ones onto my bench.), hip thrusters (I look great in yoga pants already
