- 15 Jan 2011
- UK
Is this a serious thread (reading OP)
just buy a bulb from tesco when one goes??????
The 40w equivalent led bulbs are as bright as 60w tungsten bulbs. All of them are warm bulbs.
So you dont do energy saving? I dont really do it either, but the cost of electric is shocking nowaday and with burning 5 normal 60watt bulbs for 5-7 hours a day, it gets expensive.
My old candle bulbs are 550lumens apparently and they are nowhere like 60watt equivalent.
Perhaps this doesn't hold true for the candle types or it could be the reduced angle of light they produce which would limit the location they can be best used. Pointing straight up to the ceiling probably doesn't maximise light distribution.
Yeah maybe but the old 60watt candle shaped incandescent bulb was much brighter then the 11w(60watt equivalent) CFL candle bulbs in my room.
Is it something todo with the size of the bulb, is that why manufactures cant produce a high brightness candle bulb, same with the golf ball size and the small screw fitting bulbs?
I think it is the angle of the light. With them pointing up it is significantly reducing the amount of light. My bathroom light is also LED and it is sideways mounted, you can definitely tell one side of the room is brighter than the other. Where I have candle bulbs they are LED filament types which are 360 degree angle. Most LED bulbs don't have 360 degree angle of light projection which makes ceiling mounted upwards facing bulbs more of an issue. It would also explain why my downward facing 40w equivalents seem as bright as my original 60w tungsten bulbs as the light is a bit more focused down into the room.
