Right story is, I switched over to VM (Virgin Media) from BT infinity cause I liked the Virgin's TV package and the ability to record some of the HD channel which BT doesn't let you record, namely the Data channels.
Long story short, switched over yesterday, and immediately I noticed the web pages were loading very slow. So I did a few speed tests, the initially results varied from 30mbs to 20mbs. Not too much of a fuss as I only signed up for 50mbs. but an hour into usage, the hub resetted itself then my net speed properly dropped. I have been getting no higher than 5mbs and is pretty solid at 3mbs.
So I called VM, and the first tech guy told me there is an outage in the area and it will be fixed in 4 hours and everything will be fine. So I checked the service status, there was nothing. So I waited 4 hours, I checked speed and it was the same lame speed. Then called, another tech guy said, yes there is a problem. But it is not an outage, the slow speed is due to high utilisation in the area. When i asked multiple times when it will be fixed, the guy said at earliest end of April 2015!!!
Naturally I couldn't believe what i was hearing. Now for everyone this is shocking, but to me this isn't the first time. 2 and half years ago, i had the very same problem with VM and that time the same excuses of outage was played to me over a period of 2 weeks, until I was told the truth that the "high utlisation" was the problem and it wasn't going to be fixed for at least 9 months.
My reasons for the title of this is that 1) I have been lied to in the face by a tech guy, trying to prolong my wait for a resolution 2) I have been lied to when I signed up to the services by their website as the problem of utilisation has been around for over two and half years
So my natural end effect is to swtich services as soon as I can. But if knew virgin wasn't going to live up then I probably would have stayed with BT as I was getting decent speeds (70mbs DL/40mbs UL). As the result of the switch I am out of pocket due to BT charging compensatory charges. and the switch service is going to be another pain in the back side as i have to make time for the engineer to come and install etc.
Other than the financial disadvantages and the inconvenience I have to suffer, surely what VM is doing here is defrauding new customers. Is there further actions I can take such as raise the issue with Ofcom or etc?
in case anyone is interested, my area is N16 post code, however I am on the border of N1, N4, N5 and E5.
