- 16 Dec 2014
Hi All,
I am looking to convert my current home server into a machine that is capable of gaming.
The current setup is in my signature, personal the CPU and GFX cards need upgrading but everything else I think should be OK for the time being?
As its a GFX card forum what would you suggest as an upgrade?
If it helps I am looking at an i5 CPU (Budget around £350 for both).
The card I was looking at is:
http://www.overclockers.co.uk/showproduct.php?prodid=GX-004-GX&groupid=701&catid=1914
Thanks for your help.
Spec:
Case - Fractal Design Define R3
Motherboard - ASUS P8 H67-M LE
CPU - Intel Celeron G530 @ 2.40GHz (Sandy Bridge)
GPU - None (Integrated Graphics from CPU)
PSU - Be Quiet Straight Power 480W Semi Modular 80+ Gold Power Supply
RAM - CORSAIR VENGEANCE BLUE 4GB (2X2GB) DDR3 PC3-12800 C9 1600MHZ
HDD - 1x 60GB (OS Drive) Seagate Momentous 5400RPM & 2x 2TB (Storage and Backup Drive) WD Green Caviar 7200RPM
Spec:
