I'm finding that this card, although is great, dumps loads of heat into the case I have. What's a good card (thinking of a 290) that is quiet enough but exhausts heat out the back of the case? Is it reference cards only that dump heat out the back?
I actually have my h100 pumping air out the top of my 600t case and when I'm gaming the dumped heat from the 280x in the case, gets sucked into the rad and the temps just go up and up. I know I should really turn the fans around to suck in air form the top but I'll still have the 280x dumping heat in the case.
I have bitfenix spectre 200mm as front intake and bitfenix spectre 120mm fan exhausting out the rear. I take it the best way to deal with this heat buildup is to reverse the h100 intake fans and have them sucking IN from the top of the case?
Will the intake of air from the top help force more heat out the back of the case with the different air pressure?
If not then what's a good rear exhausting card I can use?
