Which 32" - 40" budget tv is the best in 2014?
31 Dec 2005
Glasgow
Looking to buy a decent but obviously budget 1080p tv for around the £200 mark. (ie no higher than £220)
Have narrowed it down to a few...
Samsung UE32H5000 32-inch Widescreen 1080p Full HD LED TV with Freeview HD
Pros = Good Picture, Freeview HD built in, Decent sound, should be good for sdtv hdtv viewing and decent enough for console gaming?
Con = only 32"
£199
Technika 39E21B-FHD 39 Inch Full HD 1080p Slim LED TV With Freeview
Pros: super cheap, decent screen size, actually a samsung under the hood?
Con: Unsure of quality in hd viewing or gaming.. could be crap???
£179
BLAUPUNKT 40/233i 40 inch LED TV 1080p HD
Pros: Good screen size, good picture maybe?
Con: heard sound can be bad on these? No idea if ok for gaming.
£219
Will be sitting about 5 or 6ft away.
Used for Blurays, Netflix, Gaming and sometimes tv SD viewing.
Or is there another out there better and in the same budget?
Be really careful with the Technika's
My friend had one which was okay for the price but my dad bought similar model and the ghosting and picture on it was so bad he sent it back.
On your budget i would go for a 32 inch imo.
A 40 inch tv for around 200 pound surely the picture is going to be pants you should be looking to spend 300-400 for a 40 inch t.v
I would go for that samsung its a steal at that price and got really great reviews.
