Piece of cake if you know how to do port forwarding on your router. If you're playing as a group on a LAN then it's even easier. If you look in the game's root folder there is a program that creates the CFG data for an event then you just run the server app (Not on the right computer just now but the programs have server in their namesHas anyone set up a server too? I had a look at doing this but it seems to be a little complicated if you're setting one up on the PC you're playing the game on too.
Piece of cake if you know how to do port forwarding on your router. If you're playing as a group on a LAN then it's even easier. If you look in the game's root folder there is a program that creates the CFG data for an event then you just run the server app (Not on the right computer just now but the programs have server in their names, the dedicated app is in the server folder from memory)
I still can't find a reasonably priced racing seat/stand combo :/ GT omega had one for 260ish but it's sold out now and doesn't look like it'll be back in stock any time soon.
any recommendations for around 250?
needs to fit g27 with shifter.
Play Challenge mate. £140 on BoysStuff mine came today
Or one of the others.
http://www.boysstuff.co.uk/search/playseat/
be interested to hear how you find it after a bit of use, have to put my wheel away when not in use so this sounds spot on as can leave in situ
Does the steering wheel mount clip off, or do you have to kinda climb into the chair when sitting down into it? Can't really tell from the pictures and the description isn't overly clear!
