Hi all,
I have a self-built gaming desktop put together around 2011-2012 built around an Asus P8Z68V mobo, Intel i5-2500k, and an Nvidia 670. I currently have it in a CoolerMaster case that looks similar to this one: http://www.overclockers.co.uk/showproduct.php?prodid=CA-344-CM&groupid=2362&catid=29
Anyway, I'm fed up of this case because there's too many places for dust to get in so I'm thinking of taking the PC apart and putting it in a more enclosed case with two or three really nice dust-filtered quiet case fans.
Questions:
Could anyone recommend a good case option that is dust-resistant? It needs to be big enough for my Nvidia 670, an aftermarket CPU cooler (Gelid Tranquillo I think), 4 HDDs, and an optical drive?
Whilst I'm taking the system apart, cleaning, and transferring to the new case, should I re-do the CPU paste? Should I actually buy a new cooler? I haven't noticed that it's particularly hot under load, but the processor does seem to differ a few degrees between the cores.
Can you recommend some good case fans and tell me what I need to know about swapping them?
Do you know of any good, really thorough guides to cleaning out a PC?
Thanks a bunch!
Questions:
Thanks a bunch!
