 - 5 Sep 2011
 - Surrey
No reason I asked the question.
Well, last time I had Crossfire 3 months ago I had to disable it still, for one.
True. Disabling ulps for xfire setups is pretty much standard procedure.
lol, mmj can't even go for two posts without saying fanboys
Issues, yo.
I been for past couple months running with ULPS on and had no issues.
Well considering forcing V-snc doesn't work reliably in the driver I wouldn't hold your breath on this actually working and being reliable.
http://www.rage3d.com/board/showthread.php?t=33984337&highlight=VsyncVsync was changed rather a lot when Vista & Win7 came out. Before then the OS desktop was not vsync'd so it was a lot easier to alter the vsync state for apps since you didn't have the desktop manager in the background screwing things up. Microsoft also said that they didn't want vsync to alter Aero so they made it more difficult too. Both RadeonPro and ATI Tray tools and other things like that use hacks which go against what is the the WDDM spec. Nvidia also do this so their drivers shouldn't be WHQL certified IMO.
Forcing Vsync on or off globally can bugger things up for quite a few apps which is why AMD did not go the same route as Nvidia and ignore the WDDM spec & Microsoft guidelines. Now that there will be app specific profiles there should be no reason to not allow it to be forced on or off for a particular app so I have asked AMD to take another look at it which hopefully they will do.
I couldn't game without a FPS limiter as I often lock to 30fps when I can't hit 60 and I want the absolute maximum settings. I find myself doing it more and more with newer releases that need ridiculous power to hit 60 at the higher settings. Can't stand tearing (AT ALL) and V-Sync below 60 feels like 15fps. I honestly don't know how people game at anything that isn't 30 or 60. How they stand the judder and micro-stutter I will never know.
I think we all do!Sounds like you need gsync/freesync in your life![]()
folks
Yet I bet folks are still having to set 2D profiles.
The days of having to disable ULPS are gone with Hawaii. It can still be beneficial from a performance, monitoring and overclocking perspective to disable it though. However it's not essential in some cases like it used to be on Tahiti.
