** TRULY INSANE XMAS DEALS: SOME ONLY LASTING THE WEEKEND!! **
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
OK Christmas is nearly here!! Are we all happy Christmas is nearly here?
Well you should be because here is some truly insane crazy deals, some of them shall be ending end of today or when stock runs out, so DO NOT MISS OUT:
XFX AMD Radeon R9 295 X2 8192MB GDDR5 PCI-Express Graphics Card @ £499.99 inc VAT
No matter what the game or the resolution you can now select the maximum settings even at 4k resolution and enjoy fluid ultimate smooth framerates in latest games such as Titanfall, Diablo 3, Watchdogs and even potential upcoming games such as GTA V and Half Life 3 should they surface.
Featuring a pair of 290X Hawaii GPU's fused onto a single PCB with an advanced PLX chip along with only requiring 2x 8-Pin power connectors.
The other major feature of the 295 X2 is its cooling solution which truly does keep the cards temperatures around 60c even after gaming for hours and it also manages to do this in more or less silence with zero throttling of the cores themselves. Making it one of the smoothest, quietest and easily most powerful graphics card on the market today. If you really crave the most powerful and have or are considering a 4k monitor for gaming then the 295 X2 is the card for you.
If your demands are truly the most powerful experience possible then these cards work great in Crossfire (4 GPU's) and you will be able to smash benchmarks to pieces and have no slow downs in games.
Specification:-
- GPU: 2x Hawaii XT
- Hybrid Liquid Cooling
- Litecoin Hash Rate: 1600-2000
- Stream Processors: 5632
- ROPS: 128
- Core Speed: 1018MHz
- Memory Speed: 5000Mhz
- Memory interface: 1024-Bit (2x 512-Bit)
- Memory capacity: 8192MB GDDR5
- PCI-Express X16 lane required
- 850W or greater PSU required with genuine 8-Pin PCI-E cables such as Silverstone 1500W
- Case capable of fitting such a long card and support for a 120mm radiator
- Dimensions: Card is 307x111x65mm and Cooler is 153x120x63mm
- Power Connectors: 2x 8-pin
- Display Outputs: 1x Dual Link DVI, 4x Mini-DisplayPort
- Warranty: 2yr
Was [£599.99] Inc. VAT
Only £499.99 inc VAT - WE ARE STRUGGLING TO FIND MORE 295 X2 AT THIS LOW PRICE, BE QUICK, OTHER BRANDS ARE NOW BACK AT £700 :( :( :(
ORDER NOW
MSI Radeon R9 290X LE Lightning Edition 4096MB GDDR5 PCI-Express Graphics Card @ £239.99 inc VAT
The MSI R9 290X Lightning is a genuine contender as a powerful gaming card. Not quantified by "for a Radeon", this thing is fast, full stop. Easy, and rewarding to overclock with a fantastic cooler and every option you could want. It's Brilliant. It's Rapid. It's Yellow. It's a worthy winner of our OC3D Gold Award and the best Radeon card on the market today.
Features:-
- Triple Level Signals: Show the real time GPU load by different colours
- TriFrozr Thermal Design: Triple PWM fans with independent control system on
- Pure Digital PWM Control: Digitally controlled GPU, Memory and VDDC.
- Twin BIOS: Seperated BIOS chips for regular use and LN2 overclocking.
- Enhanced Power: 12 GPU phases and 3 memory phases on a custom designed 12 layers PCB for amazing overclocking potential.
- Military Class 4 Components pass MIL-STD-810G certificatiomn for best stability and quality.
- Equipped with CopperMOS, Hi-C CAPS, New SFC and All Dark Solid CAPs.
- Triple Overvoltage: Total control with GPU, Memory and PLL voltage adjustment.
- Triple Temp Monitor: Real time monitoring of GPU, Memory and PLL Conditions.
- V-Check point: For direct and accurate read-out of GPU, memory and PLL voltage.
Specification:-
- Radeon R9 290X
- GPU: Hawaii XT
- Stream Processors: 2816
- ROPS: 64
- Core Speed: 1030MHz
- Memory Speed: 5000Mhz (Samsung IC)
- Memory interface: 512-Bit
- Memory capacity: 4096MB GDDR5
- 750W or greater PSU required
- Power Connectors: 2x 8-pin + 1x 6-pin required
- Warranty: 3yr
- Download PDF Presentation: https://www.dropbox.com/s/9kkxjuw2a0n421v/R9 290X LIGHTNING Infokit 1_0 - PDF Version.pdf
Was [£299.99] Inc. VAT
Only £239.99 inc VAT.
ORDER NOW
Powercolor Radeon R9 290 PCS+ OC 4096MB GDDR5 PCI-Express Graphics Card @ £209.99 inc VAT
PCS+ Version features Powercolor's amazing tri-fan cooler, for much lower noise levels whilst offering superior cooling. Along with a great overclock out the box, this card runs at 1040MHz core and 5400MHz memory.
AMD Radeon R9 290 is a new graphics card powered by the latest AMD Radeon™ R9 290 graphics-processing unit (GPU). 4GB of super-fast GDDR5 memory for the best gaming experience at the highest resolutions including 4k and incorporates AMD Eyefinity and TrueAudio technologies to enable expansive multi-display setups and more accurate environmental sounds. R9 290 also includes support for both DirectX® 11.2 and AMD's new Mantle application programming interface (API) for great handling of even the most-demanding PC games.
Specification:
- Radeon R9 290
- Coil Whine Reduction Technology (Exclusive to Powercolor)
- GPU: Hawaii Pro
- Litecoin Hash Rate: 800-950
- Stream Processors: 2560
- Core Speed: 1040MHz
- Memory Speed: 5400Mhz
- Cooling: 2-Slot Blower Fan
- Power Connectors: 8-pin + 6-pin required
- Display Outputs: 2x Dual Link DVI, 1x HDMI, 1x DisplayPort
- Warranty: 2yr
Was [£227.99] Inc. VAT
Only £209.99 inc VAT.
ORDER NOW
Powercolor Radeon R9 290X PCS+ OC 8192MB GDDR5 PCI-Express Graphics Card **OcUK Exclusive** @ £319.99 inc VAT
PCS+ Version features Powercolor's amazing tri-fan cooler, for much lower noise levels whilst offering superior cooling. Along with a great overclock out the box, this card runs at 1050MHz core and 5400MHz memory.
AMD Radeon R9 290X is a new graphics card powered by the latest AMD Radeon™ R9 290X graphics-processing unit (GPU). 8GB of super-fast GDDR5 memory for the best gaming experience at the highest resolutions including 4k and incorporates AMD Eyefinity and TrueAudio technologies to enable expansive multi-display setups and more accurate environmental sounds. R9 290X also includes support for both DirectX® 11.2 and AMD's new Mantle application programming interface (API) for great handling of even the most-demanding PC games.
Specification:
- Radeon R9 290X
- GPU: Hawaii XT
- Litecoin Hash Rate: 850-1000
- ROPS: 64
- Memory Speed: 5500Mhz
- Comes with BF4 Voucher included in the box
- Warranty: 2yr
Was [£359.99] Inc. VAT
Only £319.99 inc VAT.
ORDER NOW
Sapphire Radeon R9 280 Dual-X 3072MB GDDR5 PCI-Express Graphics Card @ £149.99 inc VAT
With 3GB of the latest GDDR5 memory and 1792 stream processors, and support for DirectX 11.2, the architecture is built to play the very latest games with perfectly smooth action even at higher resolutions such as 2560 x 1440. In fact its Ultra HD graphics processor can feed even the latest 4K displays with the HDMI 1.4a interface. The R9 280 family represents a breakthrough in cost:performance.
Specification:-
- Litecoin Hash Rate: 500-700
- PCI-E 3.0 Ready: Delivers double the bandwidth per lane of PCIe GEN2 for faster GPU- CPU
- Hugely overclockable
- Core Clock Speed: 850MHz
- Boost Clock Speed: 940MHz
- Shader Architecture: GCN
- Stream Processors: 1792
- Texture Units: 128
- ROPS / Z-Stencil: 32 / 128
- Frame Buffer / Memory: 3GB GDDR5
- Memory Width / Speed: 384 bit / 5000MHz
- Display Outputs: 2x DVI + 1x DP + 1x HDMI
- Power: 250W TDP
- 2yr Warranty
Was [£179.99] Inc. VAT
Only £149.99 inc VAT.
ORDER NOW
Sapphire Radeon R9 280X Vapor-X OC 3072MB GDDR5 PCI-Express Card (11221-12-20G) @ £179.99 inc VAT
High-end graphics card use more power, which means they get hotter quicker. With the innovative Vapor-X, we were the very first to apply aerospace-industry vapor chamber technology to graphics cards. It's a pioneering way to accelerate heat away from the graphics chips into the rest of the cooling system.
Sapphire Vapor-X technology is used in conjunction with a heatpipe and fan assembly. The vapor chamber accelerates the heat away from the graphics chips into the rest of the cooling system. How? Inside the vapor chamber, a liquid coolant is vaporized at the hot surface. The resulting vapor moves across the chamber where it condenses at a cooled surface. Then the liquid is returned to the hot surface to aid in superior cooling.
Features:-
- 2nd generation Vapor-X technology
- Factory overclocked
- Quiet and efficient cooling
- UEFI support
Specification:-
- Litecoin Hash Rate: 550-750
- Core Clock Speed: 950MHz
- Boost Clock Speed: 1000MHz
- Stream Processors: 32 CU / 2048 ALU
- Memory Width / Speed: 384 bit / 6000MHz
- Power: 250W TDP
- 2yr Warranty
Was [£239.99] Inc. VAT
Only £179.99 inc VAT.
ORDER NOW
OcUK GeForce GTX 980 "Reference Design" 4096MB GDDR5 PCI-Express Graphics Card @ £419.99 inc VAT
The new NVIDIA GeForce GTX 980/970 is powered by the next generation NVIDIA Maxwell Architecture, giving you incredible performance, unmatched power efficiency, and cutting-edge features.
Maxwell is the most advanced GPU architecture ever made, designed to be the engine of next generation gaming. Inspired by light, it was designed to solve some of the most complex lighting and graphics challenges in visual computing. For the first time, gaming GPU's can dynamically render indirect light using the new VXGI (Voxel Global Illumination technology). Scenes are significantly more lifelike as light interacts more realistically in the game environment.
The GTX 980 is the worlds fastest GPU and the GTX 970 offers the most advanced performance in its class. Each delivers 2x the performance of previous-generation card, bringing new gaming experiences to virtual reality, and ultra resolution 4k displays.
Enable the detail of 4k monitors, on a 1080P display. DSR produces smoother images by rendering a game at a high resolution, then downscaling it to the native resolution of the display using advanced filtering.
GeForce GTX 980 and 970 cards support tear-free, super-fast NVIDIA G-Sync monitor display technology including 4k. Together, these technologies provide the most immersive and competitive gaming experiences possible.
Features:-
- Voxel Global Illumination Technology (VXGI)
- NVIDIA® Super Resolution technology
- NVIDIA® GameWorks technology
- NVIDIA® GameStream technology
- NVIDIA® TXAA Technology
- NVIDIA GPU Boost 2.0
- NVIDIA PhysX® Technology
- NVIDIA FXAA Technology
- NVIDIA Adaptive Vertical Sync
- NVIDIA Surround
- Support for four concurrent displays including: Two dual-link DVI, HDMI and DisplayPort 1.2
- Microsoft DirectX 12
- NVIDIA® 3D Vision® Ready
- NVIDIA SLI® Ready Technology
- NVIDIA CUDA® technology
- PCI Express 3.0 support
- OpenGL 4.4 support
- OpenCL support
- NVIDIA SHIELD Ready
- NVIDIA G-Sync Ready
Specification:-
- GeForce GTX 980
- GPU: GeForce GTX 980 (GM204)
- Core Base Clock: 1127MHz
- Core Boost Clock: 1216MHz
- Memory Clock: 7010MHz
- Memory Size: 4096MB GDDR5
- Bus Type: PCI Express 3.0
- Memory Bus: 256-bit
- CUDA Cores: 2048
- DirectX 12: Yes
- DVI Port: 1x Dual-Link DVI, 3x DisplayPort & 1x HDMI
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Dimensions: 268.6 x 98.4 x 40 mm
- Power: 2x 6-Pin
- 500W PSU Required
- 178W TDP
- Warranty: 3yr
Was [£455.99] Inc. VAT
Only £419.99 inc VAT - LAST CHANCE TO GET A REF 980 CHEAP!!
ORDER NOW
Inno3D GeForce GTX 980 "Reference Design" 4096MB GDDR5 PCI-Express Graphics Card (N980-1DDN-M5DN) @ £425.99 inc VAT
Features:-
- NVIDIA Surround
- OpenCL support
Specification:-
- GeForce GTX 980
- CUDA Cores: 2048
- DirectX 12: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 2x 6-Pin
- 500W PSU Required
- 178W TDP
- Warranty: 2yr
Was [£469.99] Inc. VAT
Only £425.99 inc VAT - LAST CHANCE TO BUY A REFR 980 CHEAP!!
ORDER NOW
GALAX GeForce GTX 970 OC Silent "Infinity Black Edition" 4096MB GDDR5 PCI-Express Graphics Card **WorldWide Exclusive** @ £284.99 inc VAT
Since Overclockers UK introduced our Infinity system range, demand for high performance zero compromise systems has exploded. Our Infinity brand represents performance hardware coupled with a unique and stylish aesthetic.
Since the release of high end Maxwell architecture, the hardware game has changed. The new GeForce cards offer revolutionary new technologies and class leading performance alongside low operating temperatures and impressive power consumption.
The GALAX GeForce GTX 970 OC Silent "Infinity Black Edition" is a collaboration of one of the largest Nvidia board partners worldwide, Overclockers UK Graphics Specialist: Andrew Gibson and Overclockers UK Technical Specialist & Overclocking World Champion, Ian ‘8Pack’ Parry.
Originally the Galax 970 EX OC Black Edition was intended as a high performance option for customers looking for the ultimate gaming experience with class leading performance. Our close partnership with Galax allowed us to specify a list of important modifications that would make the GALAX GeForce GTX 970 OC Silent "Infinity Black Edition" a real show stopper.
Primarily, to fit the Infinity aesthetic, we demanded that the external design of our Black Edition card was sleek and stealthy. Adding to the already imposing look of the Galax design, this new, aggressive appearance really highlights the intent behind this product.
Additionally to the colour change, we included a nickel plated I/O plate, heatsink and heatpipes to compliment the premium nature of the product. The already impressive backplate on the card has been accented with a stylish "Infinity: Inspired by 8 Pack" decal.
The imposing looks of the card would be nothing without the ‘go’ to back up all the show.
Building on the already impressive performance of the GTX 970 platform, world class overclocking expertise from 8Pack has been implemented to fine tune the BIOS of this card to achieve maximum safe, reliable performance from the GTX 970.
As an industry leading gaming and high end hardware specialist, Overclockers UK understands the importance of offering a product that meets a customer’s expectation. A major worry for any enthusiast is operational noise under load. We have used this knowledge to reduce coil whine by using higher quality components and also using glue to attach the inductors to the PCB to help reduce electrical vibrations which help reduce whine.
This collaboration with Galax has allowed us to build what we believe to be the finest example of a GTX 970 on the market today.
This product is exclusively available from Overclockers UK and Caseking group throughout UK and Europe. We suggest European customers visit www.caseking.de to purchase this card in Western Europe and Eastern European customers purchase from http://www.kellytech.hu/
Features:-
- OcUK Zero Coil Whine guarantee*
- Samsung memory guarantee
- All Black Design!
- Nickel plated I/O Plate
- Nickel plated heatsink and heatpipe
- All black shroud/cooling design
- Black PCB
- Black Backplate with Inspired by 8 Pack logo
- Inductors placed in higher quality containers and glued to PCB to reduce coil whine
- Extreme factory overclock with huge OC potential
- Anodized aluminum backplate protects components and reinforces the PCB
- All new Silence Extreme cooler reduces temps by up to 10C
- Silence Extreme technology switches to single fan cooling at idle for almost noiseless operation
Quad mixed-gauge heat pipes ensure maximum heat dissipation
- Copper base with solid aluminum cover
- 5 + 2 Phase enhanced power system with 8 + 6-pin inputs delivers up to 50% more power for overclocking
- NVIDIA Surround
- OpenCL support
Specification:-
- GeForce GTX 970
- GPU: GeForce GTX 970 (GM204)
- Core Base Clock: 1178MHz
- Core Boost Clock: 1329MHz
- CUDA Cores: 1664
- DirectX 12: Yes
- DVI Port: 2x Dual-Link DVI, 1x DisplayPort & 1x HDMI
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 1x 8-Pin & 1x 6-Pin
- 450W PSU Required
- 150W TDP
- Dimensions: 260mm (L) x 120mm (H) x 40mm (W)
- Zero coil whine guarantee
- KitGuru Review: http://www.kitguru.net/components/g...rce-gtx-970-oc-silent-infinity-black-edition/
- Warranty: 2yr
*If your card emits any coilwhine when used on a decent power supply that is 80+ Gold rated or higher then OcUK will refund or exchange the card. These cards incorporate our exclusive Coil Whine Reduction technology to help reduce and eliminate any whine.
Only £284.99 inc VAT.
ORDER NOW
Gigabyte GeForce GTX 750 "Low Profile" 2048MB GDDR5 PCI-Express Graphics Card (GV-N750OC-2GL) @ £79.99 inc VAT
GTX 750 and GTX 750 Ti cards give you the gaming horsepower to take on today's most demanding titles in full 1080p HD. They deliver 25% more performance than previous-generation cards and up to twice the power efficiency thanks to the next-generation NVIDIA® Maxwell™ architecture. Plus, they come loaded with GeForce GTX gaming technologies like NVIDIA GameStream™, G-SYNC™, and GeForce Experience™
Specification:-
- Core Clock: 1059MHz (Maxwell)
- Core Boost Clock: 1137MHz
- Memory: 1024MB GDDR5
- Memory Clock: 5000MHz (Effective)
- Memory Interface: 128-Bit
- Processing Cores: 640
- Bus Type: PCI-Express GEN 3.0 (Backwards compatible)
- Display Connectors: 1x Single-Link DVI, 1x Dual-Link DVI, 2x HDMI
- HDCP Capable
- DirectX 11.2 Support
- OpenGL 4.4 Support
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- NVIDIA Surround Enabled
- Extremely Lower power consumption (Maximum consumption 60 watts at stock speed)
- NO external PCI-E Connectors required
- Warranty: 3 Years
Was [£89.99] Inc. VAT
Only £79.99 inc VAT.
ORDER NOW
Gigabyte GeForce GTX 750Ti "Low Profile" 2048MB GDDR5 PCI-Express Graphics Card (GV-N75TOC-2GL) @ £97.99 inc VAT
Specification:-
- Core Clock: 1033MHz (Maxwell)
- Core Boost Clock: 1111MHz
- Memory: 2048MB GDDR5
- Memory Clock: 5400MHz (Effective)
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- 1x 6-pin external PCI-E Connectors required
- Warranty: 3 Years
Was [£109.99] Inc. VAT
Only £97.99 inc VAT.
ORDER NOW
DDR4 MEGA SALE - CLICK HERE!!!!http://www.overclockers.co.uk/productlist.php?groupid=701&catid=8&subid=2557http://www.overclockers.co.uk/productlist.php?groupid=701&catid=8&subid=2557
Avexir Core Red Series 8GB (2x4GB) DDR3 PC3-12800C11 1600MHz Dual Channel Memory Kit (AVD3U16001104G-2IR) - Red Light @ £49.99 inc VAT
Avexir Core Series is designed specifically for the extreme power users who focus on challenging the excellence in high performance gaming experience. The Core Series is developed by Avexir R&D team with 10+ years’ experience of researching in memory core technology and designed specifically for the power users and gamers who demand ultimate performance and extreme reliability gaming modules.</p>
Mpower Red Series is designed to be a perfect visual match for Asus ROG, EVGA, Asrock Fatality and MSI Gaming mainboards, giving you a look which shall make you the envy of all your friends.</p><br />
With 100% hand-tested extensively in multiple PC major-brand motherboard environments at its rated speed, Avexir makes sure that both stability and performance of every memory module reach the highest quality criteria.</p>
Features:
- Black PCB
- Black/Red high performance heatspreaders
- Red LED Strobe lighting effect
- SPD programmed at: JEDEC standard 9-9-9-24 values at 1333MHz.
- CAS Timings: 11-11-11-24
- Dual Channel Kit: (2x4GB)
- 100% tested at 1600MHz in Intel & AMD based motherboards
- Lifetime Warranty
Was [£59.99] Inc. VAT
Only £49.99 inc VAT.
ORDER NOW
Kingston HyperX Savage Red 16GB (2x8GB) DDR3 PC3-19200C11 2400MHz Dual Channel Kit (HX324C11SRK2/16) @ £115.99 inc VAT
Attack the competition with HyperX® Savage memory. Its unique, asymmetrical red heat spreader is made from high-quality aluminum and has a black PCB and a diamond cut finish to make your game shine and help you stand out in the crowd. The heat spreader dissipates heat so your system stays cool and reliable and its low profile fits under oversized CPU coolers. HyperX Savage is XMP Ready and comes in a range of speeds from 1600MHz to 2400MHz. Its trend-setting design puts you and your system ahead of the game.
Features:-
- Fast - top-performing modules available with low-profile heat spreader
- Unique - red, asymmetrical heat spreader sets new trends for PC builds
- Quality - aluminium die-cast heat spreader with a diamond cut finish
- Design - low profile to fit under oversized CPU coolers
- Reliable - 100-percent factory tested
- Guaranteed - lifetime warranty, free technical support
Specification:-
- Capacity 4GB-8GB (single), 8GB-32GB (kits)
- Frequency Speed 1600MHz, 1866MHz, 2133MHz and 2400MHz
- CAS Latency CL9-CL11
- Voltage 1.5V, 1.65V
- Operating Temperature 0°C to 85°C
- Storage Temperature -55°C to 100°C
- Dimensions 133.35mm x 32.8mm
- Compatible with H67, H97, P67, Z68, Z77, Z87, Z97 and H61 Intel chipsets, as well as A75, A87, A88, A89, A78 and E35 AMD chipsets
- Warranty: Lifetime
Was [£149.99] Inc. VAT
Only £115.99 inc VAT.
ORDER NOW
TeamGroup Elite Black 16GB (2x8GB) DDR3 PC3-12800C11 1600MHz Dual Channel Kit (TPKD316G1600HC11DC01) @ £99.95 inc VAT
nonl2br
Keeping abreast with the latest trend to launch new products to replace the old, Team Group is now offering a new choice of superb value expansion with its ELITE DDR3. ELITE DDR3 features outstanding product quality that users have come to expect from Team Group and the product has also passed the strictest tests for quality assurance. Not only that, Team Group’s ELITE DDR3 is manufactured with full compliance to the specifications prescribed by JEDEC (Joint Electron Device Engineering Council) and has gone through extensive burn-in tests. ELITE DDR3 features standard 240 Pin design and operates on 1.5V of power to achieve low power consumption with a truly eco-friendly specification. In addition, TEAM ELITE also comes in a variety of selections with varying frequencies and capacities to satisfy consumers with different needs.<br /><br />
Features:-<br />
- Module Type 240Pin L-DIMM 1600 <br />
- CL-tRCD-tRP-tRAS 11-11-11-28 <br />
- DRAM Density 256x8 / 512x8 <br />
- Data transfer bandwidth 12,800MB/Sec (PC3 12,800) <br />
- Heat Sink Aluminum heat-sink <br />
- Working voltage 1.5V± 0.075V <br />
- Warranty Lifetime warranty <br />
Was [£119.99] Inc. VAT
Only £99.95 inc VAT.
ORDER NOW
ASUS ROG G751JT-T7019H - 17.3" FHD LED / i7-4710HQ / Nvidia GTX970 3G / 16G / 1TB 7200 + 128G SSD / BD Read / Win 8.1 64B @ £1,299.95 inc VAT
G751 is an unbeatable gaming laptop thanks to its 4th-gen Intel® Core™ i7 processor and NVIDIA® GeForce® GTX graphics, with TurboMaster technology for stable GPU overclocking and ROG AudioWizard-enhanced audio for immersive gaming. Its intelligent dual-fan cooling system keeps everything cool even in the heat of battle, and special keys let you access Steam or share memorable gaming moments with the world!
Specification:
- LCD Cover Color & Decoration: Black
- Top Case Color & Decoration: Black
- On board processor: Intel® Core™ i7-4710HQ Processor, 2.5 GHz (6M Cache, up to 3.5 GHz)
- Operating System: Windows 8.1 (64bit)
- Office: Microsoft® Office 2013 Trial
- Chipset: Mobile Intel® HM87 Express Chipsets
- Memory Slot: 4x
- DIMM Memory: DRAM DDR3 8G *2
- Total System Memory: DRAM DDR3 8G *2
- Storage: SATA 1TB 7200RPM 2.5' HDD, SATA 128G 2.5' SSD
- Display: 17.3'//LED Back-lit//300nits//FHD 1920x1080 16:9//AG//NTSC:72%//EWV
- External video display modes: "HDMI 1.4
VGA max. 2048*1536 @85Hz refresh rate
Displayport 1.1A"
- Discrete/Share: Discrete
- Video Graphics: NVIDIA GeForce GTX970M (N16E-GT)
- Video memory: GDDR5 3GB
- Video Camera: HD web camera
- Optical Drive: [SATA] 9.5"mm 6X Blu-Ray (Read)
- Built-in TV-Tuner: N/A
- FingerPrint: N/A
- Wireless: 802.11ac+Bluetooth 4.0 (Dual band) -WIDI
- 3G/4G: N/A
- LAN: 10/100 Mbps
- Card Reader: SD?MMC
- USB Port: 4x USB 3.0
- Interface: "1x Microphone-in jack
1x Headphone-out jack (S/PDIF)
1x RJ45 LAN Jack for LAN insert
1x VGA Port (D-Sub)
1x HDMI
1 x Thunderbolt"
- Audio: "Built-in speaker
Built-in array microphone
Built-in subwoofer
Sonic Master"
- Weight (Kg): "3.60 KG (Without Battery)
3.80 KG (with 8 cell battery)"
- Dimension (cm): 41.6(W) x 31.8(D) x 2.30 ~ 4.30 (H) cm
- AC Adapter: "230W AC Adapter
Output : 19.5V DC, 11.8A, 230W
Input : 100~240V AC, 50/60Hz universal"
- Battery: 88WHrs, 4S2P, 8 cell Li-ion Battery Pack
- Keyboard Type: Illuminated Chiclet Keyboard
- Keyboard Specification: ASUS 417mm keyboard with 19mm full size key pitch and integrated numeric keypad
- Antivirus and Tool Software: "30 days Office 365 Home Premium
Power2Go
Adobe Reader
McAfee Internet Security 2012
MaxxAudio"
- Security :"Intel Anti-theft
LoJack"
- Supplied Accessories: Without carry bag<br>
- Warranty: 2yr
Was [£1399.99] Inc. VAT
Only £1,299.95 inc VAT.
ORDER NOW
MSI GS60 2QE-247UK 15.6" FHD, Intel Core i7-4720HQ, 16GB DDR3L, 128GB (M.2.SATA) + 1TB 7200rpm HDD, NVIDIA GTX970M 3GB GDDR5, - Windows 8.1 @ £1,259.99 inc VAT
A phantom of gaming has revealed itself and its here to stay. Unbelievably thin and supernaturally powerful, the 15.6" GS60 Ghost Pro 4K is ultra-portable gaming incarnate. Unlock the true potential of your games with the 4th generation Intel® Core™ i7 processor. With a 15% increase in performance when compared to the previous generation and advances in lower power consumption, dominate and play longer than ever before.
The GS60 Ghost Pro sets a new standard in ultra portable gaming. At 1.96Kg and 19.9mm thick, the GS60 is the thinnest and lightest single GPU gaming notebook on the market. The Weapon to own your game now equipped with next gen nvidia GeForce GTX 970M Graphics
Insanely Powerful. NVIDIA GeForce GTX 970M
Discrete Graphics Card with GDDR5 3GB VRAM. The NVIDIA Geforce GTX 970M Series brings extreme, next-generation graphics performance to serious gaming notebooks. As the first graphics solution to reach a score over 9,000 in 3DMark 11, the GeForce GTX 970M delivers extremely fast and fluid gameplay at the highest settings and resolutions in a lightweight and portable design.
"Shift"
The whole new feature "SHIFT" brings you total control over the system's balance between performance and temperature. Switch between profiles "Sport," "Comfort," and "Green" to find the perfect balance between system performance and temperature. SHIFT is activated by the FN + F7 hotkey combo, or via the Dragon Gaming Center.
Sport - Runs CPU and GPU at the highest frequency for maximum performance
Comfort - Limits GPU frequency to level 1. Maintain GPU temperature at a maximum of 89°C.
Green - Disables Intel Turbo boost and limits GPU frequency to level 2. Control CPU and GPU temperatures at a maximum of 85°C.
The Stunning Storage Speed
The first Super RAID design-one notebook with two mSATA SSD RAID 0 (128GB or 256GB) units, is yet another world first courtesy of MSI. Two mSATA SSDs and one HDD can be installed in the same laptop without the need to expand the size of the laptop, increasing read, write, and saving speeds.
Killer Double Shot Pro with Smart Teaming
The Killer Double Shot Pro supports both Killer Gb LAN and WiFi 802.11ac dual band protocol and average latency improvement is 3.5 times than others who support 802.11ac as well. It also has Smart Teaming function which will be operated by Killer Network Manager to optimize the bandwidth usage combined with WiFi and Gb LAN at the same time.
SOUND by DYNAUDIO
To satisfy consumers desire to experience high quality sound effects, MSI partnered with top audio brand Dynaudio, which has a devoted aspiration for "Authentic Fidelity" to meet this demanding standard. It equips the MSI GAMING-Series gaming notebook with top-notch audio features, creating a realistic sound and immersive effects. Any high quality stereo source is transformed into true-to-life, multi-channel sound. No need to purchase extra speakers, wires or speaker stands to appreciate room-filling sound.
AUDIO BOOST
The MSI Audio Boost design enhances the output sound detail and sound stage by 30% more. The gold flash audio jack provides stable sound transmission (reduced obstruction) and works in conjunction with the optimized headsets AMP (Audio Power Amplifier) design, characterized by low noise and low distortion, to greatly enhance headphone performance and faithfully reproduce each acoustic detail.
Sound Blaster Cinema 2 Enhanced Wrap around Sound
All MSI gaming laptops this year feature upgraded Sound Blaster Cinema 2 wrap around sound, making the already cutting-edge Sound By Dynaudio 2.1 channel sound system, even better with optimized software solutions in particular for wrap around sound, human voices, virtual bass, and low quality audio sources. Sound Blaster Cinema and MSI's superior sound system complement each other exceptionally well.
CUSTOMIZE Your Game Style
SteelSeries Engine is an app that transforms your keyboard in to a lethal gaming weapon. Here, you can customize each individual key, create different macros, manage keyboard lighting and customize the keyboard to your liking.
The Real Deal:A Keyboard All Gamers Desire
A Keyboard designed by SteelSeries exclusively for MSI. Exclusive keyboard positioning and golden triangle layout offers a better gaming experience.
Show Off or Just Make for Fun Best Live Streaming App Ever
XSplit Gamecaster lets you easily record your gaming experience and broadcast it live to Twitch, YouTube, UStream and more. It's simple, easy to use and ideal for sharing your gameplay with friends, family or the world - or for capturing those perfect gaming moments, just for the heck of it. Now, with the upgraded version, you can even edit your gameplay video and share it to your social media pages directly through Gamecaster.
Dual Fan Thermal Cooling System
Stay stealthy and cool with the quiet yet efficient dual fan thermal cooling solution for optimal airflow. The automated cooler boost feature intelligently increases airflow during extreme gaming sessions to keep you cool in the heat of battle
Matrix Display
IMatrix display features MSI innovative design with 3 external screen display capabilities, allowing you to output to 3 displays simultaneously using HDMI 1.4, and mini Display-Port 1.2 port. Users can work with multi-task at same time.
Handle the big screen with support of up to 3840 x 2160 resolutions to watch your movies or play your games in true HD when connected to an HDTV.
A Must-have Engine for Gaming
The latest 4th generation quad core processor platform, representing superior performance over previous generations. The CPU performance has increased by 3%~7%, while the overall platform is 15% more powerful. Additionally, the GPU performance of 2D and 3D visuals, is even more noteworthy, with an average increase of over 30%. There have also been significant advances in user experience and battery life.
Product Specification:
- Display: 15.6", 1920*1080 FHD, Anti Glare, Wide Viewing Angle
- Colour: Black
- Processor Type: Intel Core i7 4720HQ
- Processor Cores: 4 (8 Threads)
- Processor Clock Speed: 2.50GHz (3.50GHz Turbo Mode)
- Hard Drive Supplied: 1 x 1000GB
- Hard Drive Size: 1000GB
- Solid State Drive: 128Gb SSD x 1
- Hard Drive Speed: 7200RPM
- Memory Supplied: 2 x 8GB
- Memory Size: 16GB
- Memory Type: DDR3L
- Memory Speed: 1600
- Memory Socket: 2 x SO-DIMM
- Max. Memory Support: 16GB
- Graphics Chipset: NVIDIA GeForce GTX 970M
- Graphics Memory: 3GB GDDR 5
- Chipset: Intel HM87 Express
- Optical Drive: N/A
- Microphone: Built-in
- Keyboard: Full Colour Backlight SteelSeries Keyboard
- LAN: 10/100/1000Mbps Killer Double Shot Pro GB LAN
- Wireless: 802.11 b/g/n/ac Killer Double Shot Pro AC
- Bluetooth: v4.0
- USB 3.0 Port(s): 3
- USB 2.0 Port(s): 0
- HDMI Port(s): 1 (v1.4) Supports 4Kx2K Output
- Mini Display Port(s): 1 Supports 4Kx2K Output
- VGA Port(s): 1
- Microphone Jack(s): 1
- Headphone Jack(s): 1
- LAN Port(s): 1
- Card Reader: SD
- Web Camera: HD type
- Dimension: 390*266*19.9
- Battery: 6 Cell Li-Polymer, 4840mAh
- Product Weight (g): ~1.96KG (With Battery)
- Warranty: 2 Years Collect and Return
Was [£1299.95] Inc. VAT
Only £1,259.99 inc VAT.
ORDER NOW
Acer Predator 4k2k XB280HK 28" G-Sync Gaming Widescreen LED Monitor - Black/Red @ £499.99 inc VAT
Acer XB280HK gaming monitor as the world’s first 4k2k display featuring NVIDIA® G-SYNC™ technology to provide stunning, ultra-smooth, tear-free imagery and rich colors for outstanding gaming experiences. It features Acer’s flicker-less, low-dimming and ComfyView technologies that reduce strain on the eyes for smooth and comfortable extensive viewing.
The Acer XB280HK is intended to be paired with enthusiast PCs for immersive, ultra high-end gaming. It features a spacious 28-inch LED backlit display with 4k2k Ultra HD (3840 x 2160 pixels) that’s four times the resolution of 1080p Full HD, and presents stunning high quality images for outstanding visual enjoyment.
With a GeForce® GTX™-powered PC, NVIDIA® G-SYNC™ display technology synchronizes the display’s refresh rates to the GPU to eliminate screen tearing and minimize display stutter and input lag to deliver smoother, faster, more breathtaking gaming experiences. Scenes appear instantly, objects look sharper and more vibrant, and gameplay is more fluid and responsive providing gamers with significant performance advantages.
The Acer XB280HK features 170/170 degree viewing angles so that brilliantly-colored images can be seen from almost every angle. DisplayPort™ v1.2 transmits video signals and four USB 3.0 ports are conveniently located at the side and bottom of the display for connecting to keyboard, mouse or mobile devices.
The Acer XB280HK monitor is made with post-consumer recycled plastic and features a distinctive red ring on the base stand. The multi-functional ErgoStand allows the screen to tilt from -5° to 35° to ensure the best viewing angle; the base rotates 120° from left or right for easy screen sharing; the panel height can be raised by up to 150 mm for optimum comfort; and the screen pivots from horizontal to vertical for more viewing perspectives.
This eco-friendly monitor features a mercury- and arsenic-free panel, LED backlighting for reduced power consumption, and is ENERGY STAR®(1) qualified.
Features:
- Flicker-less technology – stable power supply eliminates screen flicker particularly beneficial for heavy users by helping to reduce eye strain.
- Low dimming technology – adjust to as low as 15 percent brightness in low light environments to make it easy on the eyes. Standard monitor settings start at 30 percent brightness level.
- ComfyView technology – the non-glare panel reduces reflection from light source.
Specification:
- G-Sync Technology
- Flicker-less Technology
- Height Adjust stand with tilt, swivel and pivot
- Display Screen Size: 28" (70.8cm)
- Aspect ratio: 16:9
- Panel Type: TN
- Brightness: 300cd/m2
- Contrast Ratio: 1000:1 (Typ)
- Dynamic Contrast Ratio: 10,000,000
- Resolution: 3840x2160 (Only over DisplayPort at 60Hz)
- Response Time: 1ms (GTG)
- Colurs: 16.7M
- Bits: 8 bits+HiFRC
- Viewing Angle (H / V ): 170 ° / 160 °
- Connectivity: 1x DisplayPort 1.2 (60Hz)
- USB Hub 3.0: Yes (1up, 4down)
- VESA: 100x100mm
- Speakers: No
- Warranty: 2yr
Was [£569.99] Inc. VAT
Only £499.99 inc VAT.
ORDER NOW
Asus PG278Q ROG Swift 27" G-Sync 144Hz Gaming Widescreen LED Slim Bezel Monitor - Black/Red @ £599.99 inc VAT
Quite possibly the best gaming monitor ever made and ideally suited to NVIDIA cards with 3D Vision 2.0 and G-Sync technology. This monitor runs at a staggering 2560x1440 resolution with 144Hz technology and a 1ms response, even better this is the latest in TN technology.
The ROG SWIFT PG278Q represents the pinnacle of gaming displays, seamlessly combining the latest technologies and design touches that gamers demand.
This 27-inch WQHD 2560 × 1440 gaming monitor packs in nearly every feature a gamer could ask for. An incredible 144Hz refresh rate and a rapid response time of 1ms eliminate lag and motion blur, while an exclusive Turbo key allows you to select refresh rates of 60Hz, 120Hz or 144Hz with just one press. The ROG SWIFT contains integrated NVIDIA® G-SYNC™ technology to synchronize the display's refresh rate to the GPU. This technology eliminates screen tearing, while minimizing display stutter and input lag to give you the smoothest, fastest and most breathtaking gaming visuals imaginable. Connectivity is simple, yet robust, with a single DisplayPort 1.2 port to enable NVIDIA® G-SYNC™ and dual USB 3.0 ports for convenience.
Conventional 60Hz monitors show extensive motion blur which detracts from your gaming experience. The ROG SWIFT PG278Q Gaming Monitor with NVIDIA® Ultra Low Motion Blur technology* reduces the effects of motion blur by delivering crisp edges in fast-paced gaming environments for perceivable differences in natural movement.
ASUS-exclusive GamePlus Technology enhances your gaming experience further by providing you with crosshair overlays for FPS games and multiple in-game timers for RTS/MOBA games.
The ROG Swift has a super-narrow 6mm bezel that begs this monitor to be used in multi-display gaming set-ups. With VESA wall mount capability and an ergonomic stand designed with full tilt, swivel, pivot and height adjustments, the ROG SWIFT is ready for long gaming sessions in comfort.
The ROG SWIFT PG278Q represents the next generation in gaming displays. This WQHD 2560 x 1440 monitor delivers four times the resolution of 720p, with 109 pixels per inch or 109 RGB matrices per inch. This gives you the benefits of greater image detail and up to 77% more onscreen desktop space than standard Full HD (1920 x 1080) displays. These minor details add up to give you a major in-game advantage.
Unlock the highest frame rates available, decimate lag and say goodbye to motion blur to gain the upper hand in first person shooters, racers, real-time strategy and sports titles. With twice the frame rate of standard LCDs, the ROG SWIFT PG278Q Gaming Monitor encourages you to never blink again.
Response time and ultra-smooth gameplay are the hallmarks of a true gaming monitor. With a 1ms rapid response time – the fastest available – the ROG SWIFT PG278Q Gaming Monitor eliminates smearing, tearing and motion blur, allowing you to quickly react to your game.
NVIDIA®G-SYNC™ display technology delivers the smoothest, fastest and most breathtaking gaming imaginable. G-SYNC™ synchronizes the ROG SWIFT's refresh rate to the GPU in your GeForce GTX-powered PC, eliminating screen tearing and minimizing display stutter and input lag. Scenes appear instantly, while objects look sharper and more vibrant. Gameplay is fluid and responsive too, ensuring a serious competitive edge.
The ASUS Display R&D team works closely with NVIDIA to ensure that everything runs smoothly on ASUS G-SYNC™ monitors. The ROG SWIFT PG278Q gaming monitor with built-in G-SYNC™ delivers super smooth and stunning visuals.
The ROG SWIFT PG278Q is compatible with the NVIDIA® 3D Vision™ 1 and 2 kits* to support up to three WQHD displays for immersive multi-display 3D gaming experience. ROG SWIFT provides the finest 3D gaming and content viewing experience and thanks to the ever-growing library of over 700 3D Vision™ ready game titles, as well as 3D Blu-ray movies and YouTube 3D Playback support. See everything in a new dimension with the ROG SWIFT.
*Requires NVIDIA® 3D Vision™ kit, sold separately.
Features:-
- Crisp 27-inch, 2560 x 1440 visuals combined with fast 144Hz refresh rate, 1ms response time, made smooth by NVIDIA®G-SYNC™ technology
- Exclusive GamePlus onscreen timer/crosshair, 60-120-144Hz refresh rate turbo key and intuitive 5-way OSD navigation joystick
- Complete ergonomic tilt, swivel, pivot and height adjustment with VESA mount capability for optimal placement
Specification:-
- Fully adjustable stand: tilt/swivel/pivot/height
- Screen Size: 27" (68.47cm)
- Pixel Pitch: 0.233mm
- Resolution: 2560x1440 WQHD
- 2D mode: 2560x1440 (up to 144Hz)
- 3D mode: 2560x1440 (up to 120Hz)
- 2D Surround: 7680x1440 (up to 144Hz)
- 3D Surround: 7680x1440 (up to 120Hz)
- Panel: TN
- Refresh Rate: 144Hz
- Brightness: 350cd/m
- Contrast ratio: 1000:1
- Colour: 16.7M (Real 8-Bit)
- Connectivity: 1x DisplayPort (Display Cable and USB cables included)
- USB 3.0 Hub
- 3D Vision 2.0 Enabled
- G-Sync Enabled
- ULMB Enabled (NVIDIA Ultra Low Motion Blur Technology)
- Phys. Dimension with Stand(WxHxD): 619.77x362.96x237.9mm
- Box Dimension (WxHxD): 756x456x300mm
- Weight 7.5kg
- Full Specification: http://www.asus.com/Monitors/ROG_SWIFT_PG278Q/
- Warranty: 3yr (28 Day OcUK DOA, Asus After)
- OcUK Exclusive Service: Warranty regarding dead pixels falls under ISO rules and as such dead pixels if very few are not an actual fault. But at OcUK we value our customers especially when spending such a large amount of money on what is a flagship gaming monitor. As such even if you only have 1 dead/stuck pixel and it has not gone after 3 days, we will class the monitor as faulty and exchange it for you at no cost to you. This service is exclusive at OcUK for Asus ROG Swift ONLY or other qualifying monitors! (Valid for 28 days from purchase)!
Was [£649.99] Inc. VAT
Only £599.99 inc VAT.
ORDER NOW
LG Flatron 34UC97-S 34" WideScreen Super-Wide Curved LED Monitor @ £899.99 inc VAT
21:9 Curved UltraWide QHD (3440*1440) display offers visual comfort with 2.4 times more visual information at one time than a Full HD monitor. And also, the QHD resolution’s 1440p vertical height allows you to use more vertically than a 29 inch 21:9 monitor.
IPS’s 178’ wide viewing angles, close to 180’, allow you to view the screen clearly without distortion. Also, the Curved IPS provides an immersive viewing angle covering the entire viewing angle around your range of vision.
You are guaranteed an immersive artwork by perceiving the same color as a subject on display or print through a sRGB over 99% colourspace and IPS’s accurate colour expression.
34UC97 provides two Thunderbolt2 ™ ports to directly connect a Mac PC and Pegasus2 storage directly to transmit data more than four times faster, than a USB 3.0. As a result, there is no concern of slow transmission from using a USB or HDMI connection. You can connect to various devices with the two HDMI and two USB 3.0 ports, and a Display Port. And, If you have a Mac, you can connect directly to the 34UC97 via Thunderbolt 2™, which transmits data more than four times faster than USB 3.0.
Using MaxxAudio® technology you will experience deeper bass and crystal clear highs. Equipped with two 7w internal speakers and MaxxAudio® technology, the 34UC97 provides cinema surround- like sound, allowing you to enjoy movies without any extra external speaker or sound output equipment.
Specification:-
- Screen Size Class (diagonal): 34" Curved
- Panel Type: IPS
- Aspect Ratio: 21:9
- Resolution: 3440x1440
- Color Gamut (CIE1931): sRGB 99%
- Brightness (typical): 300 cd/m2
- Contrast Ratio(Original): 1000:1
- Response Time: 5ms
- Viewing Angle (CR>10): 178/178
- Colour Depth (Num of Colours): 1.07B (8-Bit+FRC)
- Pixel Pitch (mm): 0.2325
- Surface Treatment: Anti-Glare 3H
- Curve: 3800R
- Connectivity: 2x HDMI, 1x DisplayPort & 2x ThunderBolt
- Speakers: 2x 5W
- Tilt: -5 / +15
- Set with stand: 830.5 x 224.5 x 472.9
- Set without stand: 830.5 x 106.4 x 370.3
- Weight: 8.2kg
- Linus Review: https://www.youtube.com/watch?v=RWgQmpzdqpc
- Warranty: 2yr
Was [£989.99] Inc. VAT
Only £899.99 inc VAT.
ORDER NOW
LG Flatron 34UC87-P 34" WideScreen Super-Wide Curved LED Monitor @ £899.99 inc VAT
34UC87 provides two Thunderbolt2 ™ ports to directly connect a Mac PC and Pegasus2 storage directly to transmit data more than four times faster, than a USB 3.0. As a result, there is no concern of slow transmission from using a USB or HDMI connection. You can connect to various devices with the two HDMI and two USB 3.0 ports, and a Display Port. And, If you have a Mac, you can connect directly to the 34UC87 via Thunderbolt 2™, which transmits data more than four times faster than USB 3.0.
Using MaxxAudio® technology you will experience deeper bass and crystal clear highs. Equipped with two 7w internal speakers and MaxxAudio® technology, the 34UC87 provides cinema surround- like sound, allowing you to enjoy movies without any extra external speaker or sound output equipment.
Specification:-
- Panel Type: IPS
- Curve: 3800R
- Speakers: 2x 7W
- Height adjust stand
- VESA: 100x100mm
- Weight: 8.2kg
- Warranty: 2yr
Was [£995.99] Inc. VAT
ORDER NOW
Asus VE228HR 22" Widescreen LED Multimedia Monitor - Black @ £99.95 inc VAT
Full HD 1080p Visual Enjoyment Together with HDMI Interface. Dynamically enhances the display’s contrast by adjusting the luminance of the backlight to achieve the darkest black and brightest white – delivering lifelike images. Enter a spectacular world of colors with Full HD 1080p (1920x1080) support and HDMI port. Aspect Control function allows users to select a preferred display mode among Full and 4:3 for true-to-life gaming or movie watching without any data loss or image distortion. The exclusive Splendid Video Intelligence Technology optimizes video performance and image fidelity by enhancing color, brightness, contrast, and sharpness. 5 preset video modes (Scenery, Theater, Game, Night View, and Standard) can be selected via a hotkey.
Features:-
- Display Panel Size : 21.5"(54.6cm) Wide Screen
- True Resolution : 1920x1080
- Pixel Pitch : 0.248mm
- Brightness(Max) : 250 cd/m
- ASUS Smart Contrast Ratio (ASCR) : 800000000:1
- Viewing Angle (CR?10) : 170°(H)/160°(V)
- Response Time : 5ms
- Display Colors : 16.7M
- Video Feature SPLENDID Video Intelligence Technology
- SPLENDID Video Preset Modes : 5 Modes
- Skin-Tone Selection : 3 Modes
- Color Temperature Selection : 5 Modes
- HDCP support
- Audio Features Stereo Speakers : 1W x 2 Stereo RMS
- Convenient Hotkey SPLENDID Video Preset Mode Selection
- Auto. Adjustment
- Brightness Adjustment
- Volume Adjustment
- Input Selection
- I/O Ports Signal Input : HDMI ,D-Sub,DVI-D
- PC Audio Input : 3.5mm Mini-Jack
- AV Audio Input : HDMI 1.3
- Earphone jack : 3.5mm Mini-Jack
- Signal Frequency Analog Signal Frequency : 30~83 KHz(H)/ 50~76 Hz(V)
- Digital Signal Frequency : 30~83 KHz(H)/ 50~76 Hz(V)
- Power Consumption Power Consumption < 30 W
- Power Saving Mode < 1 W
- Mechanical Design Chassis Colors : Black
- Tilt : +20°~-5°
- VESA Wall Mounting : 100x100mm
- Security Kensington lock
- Dimensions Phys.Dimension(WxHxD): 512.84x385.96x201mm
- Box Dimension(WxHxD): 576x468x148mm
- Weight Net Weight (Esti.): 4.1 kg
- Gross Weight (Esti.): 6.1 kg
- Accessories DVI cable
- VGA cable
- Audio cable
- Power cord
- Quick start guide
- Warranty Card
- Regulation Approval Energy Star 5.0, CEL, UL/cUL, CB, CE, EuP, FCC, CCC, BSMI, Gost-R, C-Tick, VCCI, PSB, J-MOSS, WEEE, Windows Vista & Windows 7 WHQL
ORDER NOW
Asus VS229HA 22" Widescreen MVA LED Monitor - Black @ £89.99 inc VAT
Delicate touches make a monitor truly great, VS229HA Full HD LED monitor, with 80,000,000:1 high contrast ratio and full HDMI, is optimized for the finest image and color quality. This approach extends to the sturdy stand and slim profile without compromising style in ensuring stability and durability.
VS229HA adopts 178°(H) / 178°(V) ultra wide viewing angle panel that eliminates color shift on your screen no matter where and how you look at it. Aspect Control function allows users to select a preferred display mode among Full and 4:3 for true-to-life gaming or movie watching without any data loss or image distortion.
Specifications:-
- Screen Size: 21.5"
- Screen Type: VA
- Backlight: LED
- Aspect Ratio: 16:9
- Recommend Resolution: 1920 x 1080
- Screen Features: Full HD
- Colours: 16.7 Million
- Pixel Pitch: 0.248mm
- Horizontal Frequency Range: 30kHz - 80kHz
- Vertical Frequency Range: 56Hz - 76Hz
- Response Time: 5ms (GTG)
- Dynamic Contrast Ratio: 80,000,000:1
- Brightness: 250 cd/m²
- Horizontal Viewing Angle: 178°
- Vertical Viewing Angle: 178°
- Tilt Angle: -5°/20°
- VGA Port(s): 1
- DVI Port(s): 1
- HDMI Port(s): 1
- Warranty: 3yr
Was [£99.95] Inc. VAT
Only £89.99 inc VAT.
ORDER NOW
Asus VX229H 22" Widescreen AH-IPS LED Multimedia Monitor - Black @ £129.95 inc VAT
Inspired by millennia of artistic legacy, the new VX229H sports an elegant and precision-crafted sundial design. The VX229H features an edge-to-edge frameless panel with 178° ultra-wide viewing angle AH-IPS A+ panel for incredible visuals. It's ultra-slim and ergonomic design can be tilted to provide you comfortable viewing experiences, while dual HDMI/MHL ports offers extensive connectivity options.
Key Features:-
- Superior Image Quality Meets Frameless Elegant Design
- The latest IPS technology with 178?Wide-view angles
- Extensive Connectivity and Built-in Stereo Speaker for Multimedia Enjoyment
- Splendid™ Video Intelligence Technology
Specifications:-
- Screen Type: AH-IPS
- Backlight: LED
- VGA Port(s): 1
- HDMI Port(s): 2
- Speaker(s): Integrated
- Audio: 2 x 1W
- Product Width: 499.8mm
- Product Height: 371.3mm
- Product Length: 210.1mm
- Warranty: 3yr
Was [£139.99] Inc. VAT
Only £129.95 inc VAT.
ORDER NOW
EIZO Foris FG2421 23.5" 240Hz Widescreen Gaming LED Monitor - Black/Red @ £289.99 inc VAT
Experience fluid gameplay free from motion blur with the gaming industry’s first 240 Hz monitor. EIZO’s Turbo 240 converts 120 Hz input signals to 240 Hz for a refresh rate double that of conventional gaming monitors so you can enjoy the smoothest motion display yet for first-person shooter, racing, and other fast-action genres.
Input lag, or the time it takes for commands from a keyboard, mouse, or controller to appear on the screen, can be the difference between hitting your target and missing it. EIZO developed its own integrated circuit to ensure your commands appear onscreen without delay.
Play like the pros with gaming presets from pro gamers such as Counter-Strike legend Patrik “cArn” Sättermon and Dota 2 player Johan “n0tail” Sundstein. Use the bundled software, ScreenManager Pro for Gaming, to download these and other presets from gaming.eizo.com or to export your own presets.
The FORIS FG2421 uses a new VA (vertical alignment) panel with a native contrast ratio of 5000:1. This is 5 times more than what other gaming monitors offer and increases the visibility in dark scenes so you can spot enemies more quickly.
The rear cabinet design features an LED backlit EIZO logo on a glossy surface surrounded by a vermillion frame. The logo glows brilliantly in a dimly-lit room or in a tournament setting. The front cabinet has a simple design so you can focus on the screen.
EIZO’s five-year warranty is two years or 67% longer than the standard three-year warranty of most brands.
Specification:-
- Panel Type: VA
- Size: 23.5" / 59.8cm (598mm diagonal)
- Native Resolution: 1920x1080 (16:9 aspect ratio)
- Display Size (HxV): 521.3 x 293.2mm
- Pixel Pitch: 0.272 x 0.272mm
- Grayscale Tones: 256 tones (a palette of 1021 tones)
- Display colours: 16.77 million from a palette of 1.06 billion
- Viewing Angles: 176 / 176
- Brightness: 400cd/m (Turbo 240: off)
- Contrast ratio: 5000:1 Typical (15000:1 with Contrast Enhancer)
- Response Time: Less than 1ms (Turbo 240: ON, Monito spec)
- Connections: 1x DisplayPort, 1x DVI-D (with HDCP) & 1x HDMI
- USB Hub: 2 Ports
- Power Saving: Less than 0.5W
- Standby Mode: Less than 0.5W
- Stand: 60mm Height adjust, 25 degress up tilt and 344 degrees swivel
- Dimensions: 563.5 x 391 - 451 x 200 mm
- Weight: 6.2kg
- Warranty: 5yr
- TFT Central Review: http://www.tftcentral.co.uk/reviews/eizo_fg2421.htm
Was [£329.99] Inc. VAT
Only £289.99 inc VAT.
ORDER NOW
Acer B326HUL 32" Widescreen LED Professional/Gaming Slim Bezel Flicker FREE Monitor - Black @ £359.99 inc VAT
The Acer B326HUL is a premium quality 32” display with WQHD resolution enabling sharper and more detailed content and true to life color accuracy for the most intense work applications and multi-tasking environments.
The B326HUL display is easy to adapt to personal needs and to integrate into any office environment, featuring a flexible height adjustment, tilt and swivel foot-stand.
The B326HUL 32’’ display provides multiple interface options, including HDMI, DisplayPort and traditional DVI, as well as 4 USB 3.0 ports with power-off charging. 100% sRGB, Acer eColor and ComfyView technologies make every pixel colorful and close to true colors making this monitor the perfect companion for graphic professionals and multimedia enthusiasts.
In additions the Acer Eco-Display technology used in the B6 series helps to minimize environmental impact and reduces the total costs of ownership (TCO).
The 2560 x 1440 resolution of this LED monitor delivers excellent detail with high pixel density, making it perfect for advanced HD productivity and specialized financial or CAD applications. View more details over a high quality large screen display with fantastic image consistency even from wide viewing angles.
6 axis color adjustment feature to meet the highest standard of color accuracy. Individual Hue and Saturation of Red, Green, Blue, Cyan, Yellow and Magenta colors can be customized by users.
sRGB provides users superb color accuracy and wide color coverage. With built-in sRGB color correction technologies, B326HUL reproduces rich color performance and captures images in their original and true colors.
"Low dimming" is designed for people to solve eye fatigue by brightness adjustment in dark environments. This design could provide more comfortable experience when user is in poor light conditions.
Features:-
- 32" WQHD 2560x1440 resolution, view 4 x HD applications
- Exceptional color accuracy with 100% sRGB coverage
- Robust Ergonomic stand: adjustable tilt, swivel, and height
- Extensive connectivity, including DVI, HDMI., DisplayPort. and USB Hub 3.0
- Eco-friendly design: ENERGY STARR qualified, EPEATR Gold rated and TCO 6.0
- Extensive connectivity: HDMIR, DisplayPort., DVI and USB 3.0
Specification:-
- Full Height adjust stand, pivot, swivel & tilt
- Screen Size: 32"W, VA LED
- Resolution (max.): 2560 x 1440
- Pixel Pitch: 0.276 mm
- Brightness: 300 cd/m2
- Contrast Ratio: 3000:1
- DCR: 20M:1
- Response Time: 4 ms GTG
- Display Color: 1.07 billion
- Viewing Angle (L/R;U/D) (CR>=10): 178 / 178
- Terminals: DVI-D / 2x HDMI / DisplayPort
- VA (AMVA+) LED Technology
- HDCP Support
- Speaker: 5W x2
- USB Hub: Yes
- VESA Wall Mounting (mm): 100 x 100 mm
- Warranty: 3yr
Was [£419.99] Inc. VAT
Only £359.99 inc VAT.
ORDER NOW
Samsung 32D850D 32" Widescreen LED Professional/Gaming Slim Bezel Monitor - Black @ £379.99 inc VAT
Samsungs latest flagship monitor ideal for gamers, professionals and photography experts.
Specification:-
- Screen Size: 32"
- Panel Type: VA
- Backlight: LED
- Contrast Ratio: 10,000,000:1
- Pixel Pitch (HxV): 0.27675mmx0.27675mm
- Response Time: 4ms
- Viewing Angles: 178/178
- Colour Support: 1.07b
- Connectivity: Dual Link DVI, DisplayPort, HDMI, USB Hub
- Speakers: No
- Stand Type: Height Adjustable (130mm), Tilt, Swivel & Pivot
- VESA: 100x100
- Set Dimension with Stand (WxHxD): MAX:741.3×630×280, MIN:741.3×500×280mm
- Set Dimension without Stand (WxHxD): 741.3×441×68.5mm
- Review: http://www.trustedreviews.com/samsung-s32d850t-review-image-quality-uniformity-input-page-2
- Warranty: 3yr
Was [£449.99] Inc. VAT
Only £379.99 inc VAT.
ORDER NOW
OcUK Value Fibre Optic USB Christmas Tree @ £5.99 inc VAT
The OcUK Christmas Tree, NUFF SAID!
Features:-
- 8" in height
- Low power Fibre Optic RGB lights, enjoy Christmas without the usual expense of expensive trees and fairy lights
- Small compact design
- Blue/Red OcUK colour scheme
- Think of OcUK during the festive period with this superb Christmas Tree.
- Watch out for this beautiful tree being given away in upcoming OcUK Christmas promotions. ;)
Was [£14.99] Inc. VAT
Only £5.99 inc VAT.
ORDER NOW
DO NOT MISS OUT GUYS AND HAPPY CHRISTMAS!!!!
I was going get 970 Reference Design SLI now I'm not sure if to pay the extra and get 2 980 reference design for SLI now that they are on sale. Would I notice much of a difference or is 970 SLI going to be good enough?
In before the, what res do you run at, what games do you play nonsense.
Just buy whatever you want and can afford.
Hehe well even with the price cut it would be pushing my budget to the max an extra £200 over the 970 SLI I'm intending to get. I'm looking to game at 1440P and I play a mix of RTS, MMO, FPS some examples would be Assassins Creed Call of Duty Crusader Kings 2 Civ 5 Rome Total War 2 The Old Republic not played a lot of graphical games recently as I'm currently without a proper gaming machine. Reason I'm planning to spend so much so I can game again properly and hopefully for a long while to come.
Going to be using a Bit Fenix Phenom Nvidia Special Edition White so think Blower Coolers will be best in a SLI set up.
