OcUK Staff
- 26 Nov 2014
- Stoke
The Aeneas is the newest addition to the Raijintek family, offering great aesthetics, a substantial feature set and a wealth of cooling opportunities with 4 pre-installed fans, plus space for a 240mm/280mm radiator on the top/front, or a further 4 fans. In stock now and ready to ship!
Raijintek Aeneas mATX Cube Case - Black Windowed @ £65.99 inc VAT
AENEAS, Raijintek’s special type chassis – Cube Micro ATX, is developed with elegant design, super intake/outtake airflow, and spot catch LED bar. Not only AENEAS brought to you fashion and elegant style, but AENEAS also brings you a sturdy chassis body (0.8mm SGCC) and with surprising function and features.
With awesome fan installation function to provide cooling performing, AENEAS is bale to install Max. 8 fans, 200mm fan optional at front, 2 * 140mm fans pre-installed at rear, 2*120mm fans pre-installed at front, and additional to install 240mm radiator at front or top. Superior features includes Removable M/B plate for easy installation of coolers, Switch off button of LED lighting, Compatible wtih 180mm height CPU cooler, VGA card length to 310mm and Regular ATX PSU compatibility. What a awesome chassis enthusiasm is looking for, it must be AENEAS.
- Elegant LED light bar design (on/off switch)
- User Friendly design – removable M/B frame and tool-free screws
- Classic design with efficient and mass airflow
- Complete black coated interior
- Dust-control filters for all mesh area
- Sturdy and reliable chassis body Chassis body: 0.8mm SGCC
- Accommodate an internal 240 mm radiator at front ; an 280mm radiator at top
- Powerful fan systems pre-installed: two 140mm at rear; two 120mm at front.
- Supports to up to eight fan installation; 200mm fan option at front
- Supports to install four 3.5”HDD (or four 2.5” HDD) and five 2.5” HDD (optional cage)
- Fully supports Tool-free for ODDs & HDDs
- Two high speed USB3.0 and two USB2.0
- Supports VGA card up to 310mm
- Support CPU cooler height up to 180mm
Specfication:-
- Internal color Matt Black
- Dimension chassis body (D/W/H) 352*288*380mm
- Dimension chassis body (D/W/H) 380*288*430mm
- Body Weight (N.W.) Kg
- Material SGCC 0.8mm
- M/B Type MICRO-ATX?ITX
- Graphic Card Support yes
- Power Supply PS-2
- Power Supply Integration Internal Bottom PSU (vertical)
- 5.25" Drive Bays 1
- 3.5" Device 1 exposed +4 hidden
- 2.5" Device (option/removable) 5
- I/O Panel USB3.0 *2 + USB2.0*2
- Hot Swappable n/a
- PCI Slot 5
- PCI Slot Tool-free Yes
- ODD & HDD Tool-free Yes
- CPU Cooler Height 180mm max.
- Graphic Card Length 310mm
- Side Panel Style Flat / Vent
- Cable Management Regular
- Water Pipe holes 2
- Front Cooling Fan 120mm*4 (2pcs pre-installed) ; 200mm fan (option) or
- 240mm radiator (option)
- Rear Cooling Fan 140mm*2pcs (pre-installed)
- Left Side Cooling Fan Option
- Right Side Cooling Fan option
- Top Cooling Fan 140MM*2 (option)
- or 280mm radiator (option)
Only £65.99 inc VAT.
ORDER NOW
Raijintek Aeneas mATX Cube Case - White Windowed @ £65.99 inc VAT
Specfication:-
- Power Supply PS-2
- Hot Swappable n/a
- PCI Slot 5
ORDER NOW
Raijintek Aeneas mATX Cube Case - Black @ £62.99 inc VAT
Specfication:-
- Power Supply PS-2
- Hot Swappable n/a
- PCI Slot 5
Only £62.99 inc VAT.
ORDER NOW
Raijintek Aeneas mATX Cube Case - White @ £62.99 inc VAT
Specfication:-
- Power Supply PS-2
- Hot Swappable n/a
- PCI Slot 5
ORDER NOW
Specfication:-
- Power Supply PS-2
- Hot Swappable n/a
- PCI Slot 5
ORDER NOW
Specfication:-
- Power Supply PS-2
- Hot Swappable n/a
- PCI Slot 5
ORDER NOW
Specfication:-
- Power Supply PS-2
- Hot Swappable n/a
- PCI Slot 5
ORDER NOW
Specfication:-
- Power Supply PS-2
- Hot Swappable n/a
- PCI Slot 5
ORDER NOW
