EK Water Blocks, Ljubljana based premium computer liquid cooling gear manufacturer, is proud to announce that EK-Vardar, company's first fully in-house engineered computer cooling fan, designed and built primarily for highest-performance computer liquid cooling systems, is now shipping.
This product is the result of one year worth of development, CFD analysis, careful motor selection and anechoic chamber testing.
The key characteristics of EK-Vardar Fx-120 series fans are:
High-static pressure / low noise profile - unlike other general-purpose computer cooling fans, the EK-Vardar family of fans is built specifically for computer liquid cooling systems, namely radiator cooling. The 7-fin fan blade design is optimized for high pressure operation while maintaining the low noise profile throughout the whole operation range of the fan. Vardar's design and construction is also very suitable for high-performance heat-pipe air coolers.
High-quality motor and bearing assembly - Proven electrical design, actively cooled motor windings and Double Ball bearing with 50.000 hours lifespan (MTBF) ensures uninterrupted operation for years to come. Phase-width modulation (PWM) fan speed allows performance on demand.
Sealed-edge fan casing - The classic, yet effective square shape of the fan casing ensures optimal performance in either pull- (suction) or push (pressure) regime without hydraulic losses thus ensuring optimal cooling capacity of your liquid cooling radiators.
Timeless design - the EK-Vardar fan fits subtly into any liquid cooling computer without drawing too much attention. Single- and two-tone colour design with monochrome fan sticker. Less is more.
EK Water Blocks EK-Vardar F1-120 (1150rpm) @ £11.99 inc VAT
Mechanical and electrical specifications:
- Speed: 1150 rpm (+/- 10%)
- Rated Voltage: 12V DC
- Power Draw: 0.55W
- PWM Duty Cycle: 60-100%
- Connector: 4-pin PWM header
- Shaft bearing: Double-ball bearing
- Bearing durability: 50.000 hrs @ 40°C (MTBF)
- Dimensions: 120 x 120 x 25 mm
Performance characteristics:
- Max Air Flow: 40 CFM = 68 m³/h
- Static Pressure: 0.92mm H2O = 9 Pa
- Sleeved cable length: 300 mm
- Noise Level: 23.7 dBA
Only £11.99 inc VAT.
ORDER NOW
EK Water Blocks EK-Vardar F2-120 (1450rpm) @ £11.99 inc VAT
- Speed: 1450 rpm (+/- 10%)
- Power Draw: 0.73W
- PWM Duty Cycle: 50-100%
- Max Air Flow: 52 CFM = 88 m³/h
- Static Pressure: 1.42mm H2O = 14 Pa
- Noise Level: 25.6 dBA
ORDER NOW
EK Water Blocks EK-Vardar F3-120 (1850rpm) @ £11.99 inc VAT
- Speed: 1850 rpm (+/- 10%)
- Power Draw: 1.44W
- Max Air Flow: 63 CFM = 107 m³/h
- Static Pressure: 2.24mm H2O = 22 Pa
- Noise Level: 29.5 dBA
ORDER NOW
EK Water Blocks EK-Vardar F4-120 (2200rpm) @ £11.99 inc VAT
- Speed: 2200 rpm (+/- 10%)
- Power Draw: 2.16W
- PWM Duty Cycle: 40-100%
- Max Air Flow: 77 CFM = 131 m³/h
- Static Pressure: 3.16mm H2O = 31 Pa
- Noise Level: 33.5 dBA
Scope of delivery:
- EK-Vardar series fan
- self-tapping screws (4 pcs)
ORDER NOW
EK Water Blocks EK-Furious Vardar FF5-120 (3000rpm) @ £12.95 inc VAT
- Speed: 3000 rpm (+/- 10%)
- Power Draw: 5.64W
- Fiber-glass strengthened impeller
- Max Air Flow: 107 CFM = 181 m³/h
- Static Pressure: 5.81mm H2O = 57 Pa
- Noise Level: 42 dBA
Only £12.95 inc VAT.
ORDER NOW
- Power Draw: 0.55W
ORDER NOW
- Power Draw: 0.73W
ORDER NOW
- Power Draw: 1.44W
ORDER NOW
- Power Draw: 2.16W
Scope of delivery:
ORDER NOW
- Power Draw: 5.64W
ORDER NOW
