WD My Passport Ultra 1tb
N17
N17
Permabanned
20 Jan 2012
I bought a 1tb WD MyPassport Ultra, works fine on my laptop, and picks it up, however plug it into my PC, and it powers up, but does not show the drive.
make sure the drive letter is not being used by anything else on your PC.
can check this in disk management and also change the drive letter if needed
go to start, right click on computer and then go to manage
on the next screen on the left hand side go to disk management, on the right you will see the drives, if you need to change the drive letter of the WD right click on it and go to change drive letter, pick a letter not in use and should be fine after that
The USB port could also not be providing quite enough power to make it actually usable, have you tried plugging both of the usb connectors on the end of the cable in to give it a power boost?
Still does not show the drive.
It's probably a power issue, i use a 2tb My passport ultra on USB2 & USB3 without any problems.
When using USB2 it's plugged in to a mains powered hub though.
