1080p 120hz possible on HDMI?
13 Oct 2004
Teesside
hi all,
I have a 970 and a s27a950d monitor. I've always used display port cables to get 120hz at 1080p due to thinking that hdmi cables dont have enough bandwidth. although recently somebody mentioned sometyhingt about the newest 1.4a hdmi cables being able to work on 120hz as they work with 4k...
Is it possible - do i just need a better hdmi cable?
thanks
ive managed to add a custom resolution with 120hz which all works on desktop, but when i launch a fullscreen game it goes back to the default 60
I don't think it's possible with that monitor but it has a DP input anyway so I don't see what the issue is
You may find that the card and a 1.4a hdmi will do this but due to the age/spec of the monitor the hdmi port won't take 120hz through it.
