Recently bought a new monitor with 2560 x 1440 resolution and am having some problems getting it to work with a dvi dual link cable
is my graphics card enough to run this resolution i am using a r6950?
when i boot the PC with only this monitor plugged in i geta a brief windows 8 splash screen then it turns black .
I do not get my normal bios splashscreen appear at all though
it is monoprice zero g monitor if that helps at all
thanks
thanks
