Gigabyte 1 short beep 1 constant beep.
30 Nov 2011
Hi,
Spec is in signature - I was playing the new dragon age and i got the odd short beep about every 3 seconds. After about 2 mins it turned constant.
I quit game and checked temps - all fine.
Tried to goggle it and seen it might be ram or gfx. So I gave the machine a good clean out and reseated both the gfx and both 4gb sticks of RAM.
Upon connecting back up I now get one short beep followed by a constant beep.
I removed one stick of RAM and tried again - same
Other stick removed - same.
Game was running fine when the beeps occurred no stuttering or anything to indicate a problem.
Any ideas? Gfx ive only had since august (from here)
Thanks
Sean
These are the BIOS beep codes for Gigabyte:
What does BIOS beep sound mean?
1.AWARD BIOS
1short beep :System normal
2 short beep :CMOS Error
1 long beep and 1 short beep:Memory error
1 long beep and 2 short beep:Graphic card error
1 long beep and 3 short beep :AGP error
1 long beep and 9 short beep :Memory Error
Continuous long beep :Memory not correctly installed
Continuous short beep :Power supply unit failed
2.AMI BIOS
1 short beep :Memory Error
2 short beep:Memory parity check error.
3 short beep :basic memory 64K address check error
4 short beep :Real Time Clock malfunction .
5 short beep :CPU error
6 short beep:Keyboard error
7 short beep :CPU interruption error
8 short beep:Graphic card error
9 short beep :Memory error
10 short beep :CMOS error
11 short beep :CPU cache memory malfunction
Ahh thanks. I did find some codes somewhere but they was a total mess and didn't make sense.
So I put both sticks back in again, all good now played 2iah hours with no problem. Strange how it happened in the first place though, machine was not disturbed.
All good now though.
Thanks again
Sean
