- 2 Jan 2012
- UK.
nvm.
Hi,
Im getting restless of my R9 & AMD, could you please spec me a new GPU
£400-500
System Specification
- Case: Antec 300 Gaming Case
- Power Supply: OCZ ZS 750w PSU
- CPU: Intel Core i5 2500K 3.30GHz @ 4.40GHz Sandybridge CPU
- Motherboard: Gigabyte Z77-D3H Intel Z77 (Socket 1155) DDR3 Motherboard
- Cooler: Prolimatech Panther CPU Cooler
- RAM: 8GB DDR3 1600MHz Dual Channel Kit
- Hard Drive: 500GB HDD
- Intel 330 Series 60GB 2.5" SATA 6Gb/s Solid State Hard Drive
- Sapphire AMD Radeon R9 290 (4096 MB)
Thankyou![]()
I am in the saving up process for 1 maybe 2 970's so have been looking into this a lot lately and I have the same case as you.
Be careful which card you go for as the Antec300 only has room for a max GPU length of 27cm and that's only if you don't have any hard drives in the cage where it will line up with.
I found that the Reference 970/980 will fit with about 1/2cm clearance.
Unless you want to get busy with the Dremel that is![]()
Your not really giving any real info on your problem(s) your experiencing with WoW, you just listed BF4 and said nothing about that game. And said AMD have no support. You tried different drivers? You tried doing fresh install? You done anything or just seen you have a problem then think screw it im going nVidia and putting the blame solely on AMD GPUs?
If i was you i would try and solve the problem your self and save a lot of cash as a 290 card plays BF4 fantastically and can destroy WoW too.
But if you wana blow your cash go ahead and id recommend a 970 with possibility of SLI later.
I am playing WoW on a 290 at 1080p and have not noticed any FPS drops in any zone, instance or anything else. Infact WoW gets bent over backwards by my 290 (as you would expect).
Start looking at doing a format, updating all drivers and bios (morherboard).
I've done that, I've ran out of ideasasked on WoW forums and other people have done the same
Are you turning your pc off at night?
Just a heads up but neither of you can go SLI without also changing motherboards as your current boards don't support it.
On WoW a big majority on both EU/US playing with AMD are experiencing problems and no sort of post has been made yet. (experiencing problems for a bout a month +) So bout time I take my custom else where
Edit: I know it's a quick fix, but I may just build a PC which spares I have. My R9 was working fine all night.. I go to sleep, wake up and log on to WoW and bam lost 80 fps or so in the space of 6 hours
Do you see this issues in other games?
Whats your internet connection like?
Do you have a freind, whose Nvidia card you could borrow for a few days to test it out?
Try lowering the graphics settings in WoW to the lowest they will possibly go (other than draw distance, if there's an option for that) and see whether it affects the framerate or not. If it doesn't then I'm guessing it's your CPU.
Graphics cards do not magically lose 80 FPS performance over night.
WoW is a very CPU intensive game, thats the only thing that will randomly reduce your performance, Changing the GPU will not fix that as it has nothing to do with the GPU.
You can't expect them to fix something that has nothing to do with them and is completely outside of their control.
Throwing £300 at a new GPU will land you exactly the same problem.
Tried already makes a difference of 5-10fps from high-low which is strange (would have expected bigger)
If you are playing with a 290X lowering settings will give you very little gains. The game is mostly CPU bound, which is felt especially hard in raids and BGs. Before 6.0 even a high end machine didn't manage to get more than 50 fps stable in 25 man heroic encounters.
Also keep in mind that performance in LFR and Heroic/Mythic will not be the same due to people slacking in LFR and thus there is less stuff going on.
If i go into my garrison and turn off crossfire and run my card in its low energy profile 500/1000 i got 250 fps, then if i turn my gaming profile 1200/1700 i got 260 fps so it really aint utilising the card much when nothing is going on.
I dont play anything else really, last I went on was Shogun 2 on ultra and BF bad company 2 on max and they ran perfect.
Internet is fine on WoW I run 15ms below
That's what I thought it can't just do that over night, but what makes a CPU do that? I'm stuck for ideas
http://eu.battle.net/wow/en/forum/topic/12989320003
