**TODAY ONLY! 29/12/2014** EVGA SuperNova 1200W PSU 80+ Platinum & Zalman HD501 Home Theatre PC Case
OcUK Staff
4 Feb 2013
EVGA SuperNova 1200W '80 Plus Platinum' Modular Power Supply (220-P2-1200-X3) @ £159.95 inc VAT
EVGA adds a platinum series power supply to its full line with the SuperNOVA 1200 P2. This Power supply is 80 PLUS Platinum rated with an efficiency of 92% under typical loads. The new ECO Thermal Control Fan System offers Fan RPM modes to provide zero fan noise during low load operations. This provides improved efficiency for longer operation, less power consumption, reduced energy costs and minimal heat dissipation. Backed by a 10 year warranty, gain peace of mind from the heart of your system and power up with the EVGA SuperNOVA 1200 P2!
Features:-
- 80 PLUS Platinum high efficiency power supply certified – 50% load (92% Efficiency)
- Superior vertical double layer main transformer increases power output
- 100% highest quality Japanese Nippon Chemi-Con solid state capacitors ensure long-term reliability
- Fully Modular to reduce clutter and improve airflow
- Quiet and Intelligent Auto Fan for near-silent operation
- High Amperage Single-Rail Design for maximum power and efficiency
- Over Power/Under Power/Over Voltage/Short Circuit/Over Current protection built in
- EVGA's unparalleled Customer Support
- Ready for 4th Generation Intel Core Processors (C6/C7 Idle Mode)
- An outstanding 10 Year Warranty
- +5v 20A
- +12v 99.9A
Only £159.95 inc VAT.
ORDER NOW
______
Zalman HD501 Home Theatre PC Case - Black - ** FREE BE QUIET! 120mm FAN ** @ £94.99 inc VAT
Available in two different styles, the HD500 series HTPC cases not only look great but they also offer excellent cooling for a HTPC chassis. The minimalist styling, brushed aluminium finish and the rounded corners give these cases a distinctive look. The optical drive, I/O ports and a hot-swappable HDD are all hidden behind front aluminium flaps to maintain the elegant finish.
The HD500 series can accommodate Micro ATX as well as Standard ATX motherboards. This makes it possible to install high performance components without having to worry if a large CPU cooler or graphics card will fit. The cases are compatible with coolers no taller than 130mm. Finally, with the HD500 series you can install long PSUs due to the extra space.
One of the down sides to HTPC case is the fact they can become quite warm due to the size of the chassis'. Zalman have helped to solve this problem by incorporating many ventilation holes. At the rear and the left side of the case you will find that there are two 80mm fans and 120mm fan. These fans are designed to extract the hot air generated inside the chassis. The intake fan is also 120mm which blows the cooler air from outside the chassis over the HDDs
Both the HD501 and the 503 have the facility for one hot-swappable 3.5" hard drive to be installed. This hard drive is installed into a 5.25" drive bay rather than a 3.5". As you would expect the HDD is mounted on anti-vibrational rubber screws. The hot-swappable HDD is accessed by lowering the bottom flap.
For convenience Zalman have also made available at the front of the case several common ports. Two USB, one e-SATA, one headphone and one microphone port are all available. These ports are hidden behind the same flap that hides the hot-swappable HDD.
Features
- 450(W) x 170(H) x 455(D)mm
- GPU Support: Up to 260 mm max length
- 5.25" Bays: 2 (Hot Swap Bay x 1)
- 3.5" Bays: 3 (SSD x 2)
- Front I/O Ports: 1 x Mic, 1 x Headphones, 2 x USB, 1 x e-SATA
- Sleek minimalist design
- Side ventilation for increased cooling
- Tool free anti-vibration HDD installation
- Hot-swappable HDD support
- Accommodates up to two SSDs
- Convenient front I/O ports
Specifications
- Enclosure Type: HTPC
- Dimensions: 450(W) x 170(H) x 455(D)mm
- Weight: 8kg
- Material: Aluminum / Plastic / Steel
- Motherboard Compatibility: Standard ATX / Micro ATX
- Power Supply Compatibility: Standard ATX / ATX12V
- PCI/AGP Card Compatibility: Full Size
- Cooling Components (Fans): Rear: 2 x 80mm fans, Side: 2 x 120mm fans(Optional)
- Expansion Card Slots: 7
- Supports Hot-Swap: SATA I, SATA II
- Available Colour: Black
Only £94.99 inc VAT.
ORDER NOW
only just brought one of these EVGA SuperNova 1200W '80 Plus Platinum few days ago.
Is there chance of getting £40 off or credit note plz ��. If no I just buy another and send the other back... ��;)
Spoffle made me chuckle at least. :)
I can understand your point of view up2nogooduk, but looking at it from the other side I bought one of the refurb 7950's when they appeared, then the next day it went up £5. I am not planning on contacting OcUK and offering them the extra £5, so I wouldn't expect them to pay me the difference if a price drops after I purchase. Price drops shortly after purchase have happened to me a couple of times and I've kicked myself, but mainly I think if I was happy to pay the price I did for the item then I can't be too annoyed. Just my opinion.
Yes i see you're point! sods law i guess :)
