- 26 Nov 2014
- Stoke
The NZXT H440 Razer edition has just been booked into stock, currently the only stock available in the UK! This case looks fantastic in the flesh, and despite my leanings toward the Enthoo EVOLV as my next case, this special edition runs it pretty close, especially with the matte black finish and green underglow.
NZXT H440 Midi -Tower Special Editon - Black / Green @ £124.99 inc VAT
NZXT and Razer have formed an alliance to create the ultimate gamer's chassis: the H440 - Designed by Razer™. This completely custom design features Razer’s iconic three-headed snake logo, a custom matte black finish, hexagonal mesh, a tinted window and signature Razer green illuminated LED power button and underglow.
The new H Series Chassis from NZXT features a doorless, ODD-free front panel made entirely of steel while a large, full-view window reveals an interior specially engineered to make any build seamless and beautiful. This case puts a firm emphasis on the ethos of Clean computer builds. Every design characteristic has been considered to assist even novice system builders in creating showcase level systems.
On the inside, an integrated power supply shroud completely conceals cables and increases cable management space up to 80%. Additionally, two attached SSD trays mounted above the shroud allow you to easily showcase a remarkably clean interior.
The H440 comes standard with 360mm of direct CPU/GPU cooling behind its front panel, offering an unprecedented level of cooling right out of the box. Supporting both 140mm and 120mm fans, the steel top and front panels come ready for up to 360mm water cooling radiators to offer comprehensive water cooling performance in a sleek, minimalist package.
With its newly designed interior, the H440 guarantees a streamlined PC-building experience without sacrificing any features that builders demand in a high performance chassis.
Features:
- An integrated power supply shroud completely conceals cables and increases cable management space up to 80%
- The H440 comes standard with 4 of NZXT's newly designed FN V2 case fans.
- Newly designed steel HDD drive trays complement the H440's front and top steel panels
- Liquid cooling support: 240mm 280mm or 360mm (front and top) The only case this small that can support 2x 360mm out of box.
Technical Details:
- Dimensions: 220 x 510 x 476 mm (W x H x D)
- Material: steel (Body), plastic (front cover)
- Weight: about 9.8 kg
- Colour: Matt Black, Green
- Form Factor: ATX, Micro-ATX, Mini-ITX
- Fan Hub: 10x 3-pin fan
- Fan total possible:
- 2x 140 / 3x 120 mm (front)
- 1x 140/120 mm (rear)
- 2x 140 / 3x 120 mm (cover)
- Thereof pre-installed:
- 3x 120 mm (front FN V2)
- 1x 140 mm (rear FN V2)
- Radiator Mountings (partial renunciation of drive and / or fan-Slots)
- 1x max. 280/360 mm (front)
- 1x max. 140 mm (rear)
- 1x max. 280/360 mm (lid)
- Filters: front, power supply
- Drive Bays:
- 6x 3.5 inch (internal; tools)
- 7x 2.5 inch (internal, 5x instead of 3.5 inches)
- Power supply: 1x Standard ATX (optional)
- Expansion Slots: 7
- I / O Panel:
- 2x USB 3.0 (internal connection)
- 2x USB 2.0 (internal connection)
- 2x per Audio In / Out
- Maximum video card length: 305 mm (without any waiver)
- Maximum video card length: 406 mm (without HDD cages)
- Maximum CPU cooler height: 180 mm
Only £124.99 inc VAT.
ORDER NOW
Features:
Technical Details:
- Drive Bays:
- I / O Panel:
ORDER NOW
