*** The New Cases Gallery ***
Very impressive WARRIOR, i'm not normally a fan of Red/Black themes but that does look good, it's a very clean and tidy look. By the looks of it you did well to get a push/pull setup on your rad, was their much room to spare ?
yes it fitted fine.
ive took the push fans off now though just got pull
ive also change push fan on graphics rad to pull
gona see about some braided cables soon but i may change the theme up a bit to red white and blue
plus a custom water loop for gpu and cpu
Corsair 900D...Had this case for over a year. Just a Graphic upgrade, tubing replace and a water cooling clean.
Old Setup...
Finished clean build...
Specs.
Intel Core i7-3930K 3.20GHz (Sandybridge-E) Socket LGA2011 Processor Oc @4.6GHz
Asus Rampage IV Extreme Intel X79 (Socket 2011) DDR3 Motherboard
Corsair Dominator PLATINUM 16GB (4x4GB) DDR3 PC3-19200C9 2400MHz Dual/Quad
3 x Radeon R9 290X 4096MB GDDR5 PCI-Express Graphics Card (Tri-Fire)
XSPC RayStorm CPU WaterBlock (Intel)
XSPC RX480 Black High Performance Radiator
XSPC RX360 Black High Performance Radiator
XSPC Twin D5 Dual Bay Reservoir/Pump Combo
Primochill Primoflex Advanced Tubing 19/13 - UV Blue
** No image quoting **
Well got it finished, new EVGA 1300W PSU and a light. This whole posting has made me realise that I need a camera
He is my current build. Only after I have taken some photos do I realise how little it actually looks in comparison to the size of the case.
I will post my old case first, as I have just offloaded the case, Mpower Z77 board and the 3570K to the old man
And here is my new build. Gone has the Antec Kuhler 920 and replaced with the NZXT Kraken X41, I have a 4690K and a ASUS Z97 Deluxe board. EVGA GTX 970 FTW, hoping to pick another one up at some stage, and the neat thing with my new case the NZXT Phantom 630 is my two SSD's bolt on behind the motherboard try and good bye to all the hard drive caddies maximising air flow.
One more thing I need to do is when the CableMod's prebraided replacement cables for my stock Seasonic X-Series come available, get them installed.
Apologises for the quality of the photos, Apple iPhone 6 everyone :rolleyes:
I have a similar green theme, i also use a Seasonic PSU and as you know the cables arn't the most attractive things in the world. Why not use cable extensions, i did that myself. You only need the 24 pin, 8 pin CPU power and the GPU power cables.
They look tidy man.
My problem is tho I don't have that little section you have down the bottom where you can hide the originals. I was thinking extensions to begin with.
Yours looks a nice build, i noticed your using the same Avexir ram. Yeh it does help having that area to hide cables, that wasn't part of the case, i bought it from the coolermaster store, its a Haf X PSU cover.
Thanks man, yeah I noticed that too. Looks great, wish tho the lights were solid sometimes but only a small pointless gripe.
Ah I will have to have a look on there then ta.
Intel 4820K 3.70GHz (still at stock speed)
Asus P9X79 Intel X79
2x MSI R9 290
120 GB OCZ SSD
Superflower 1000w PSU
16GB Corsair Vengeance Blue 1600mhz
Corsair 750D
Don't think i need anything else in my PC now.
