Permabanned
- 8 Jan 2010
- UK
There is no cure for intolerance unless your friend lets the light of Jesus in his life
100% this!That's quite true. I have met many people who have racist tendencies but are lovely people otherwise.
Unfortunately the basis you're working on is because they're "x" they must be "y". While it may work in small samples if you expand it to the entire of x then the assumption will be wrong(well 9/10). The likelihood is within a small enough sample you can attribute Y to any X.
So... one of the causes of racism is commonly quoted as being ignorance and/or a lack of education... So what exactly is best cure for a racist? Lets say someone knows they are a racist and want to rectify the situation; what would be their best course of action?
The likelihood is that they are racist through ignorance
However to admit that they're wrong on the majority and to still habour such thoughts implies ignorance regardless of their IQ.
.Every dog i have ever met in my adult life has not bit me.
I am still weary when i meet dogs for the first time, by your logic this means i am ignorant, but like the person in your example i choose to be cautious because the outcome of not being on guard is much much worse than the outcome of being proved wrong.
cause that would confirm nearly every negative racist thought they had...
Interesting... one would assume the opposite would be true ie. the more time they spent with other races the more it would confirm we are 'all the same' and any percieved differences would evaporate over time... You seem to think the opposite however?
Ok lets take the Y of knife crime and the abundance of media reports suggesting that men of black(X) decent are the biggest perpetrators. If you were to take the sample from a low income predominantly black area it could easily suggest that the medias representation is correct. However to then suggest that in all areas the same trend would continue would be flawed.
That is where I believe the racist mindset is started. The real racist will happily take their subset of data and apply it to an entire race. Once you realise that it's only your small sample that has caused this view and that it doesn't represent the entire race then you've "cured" yourself.
but the statistics show that black men commit crime at a rate that is massively disproportionate to the segment of the population they make up.
and thats not from a small sample, thats from looking at everyone who passes through the courts.
I suspect that they are also disproportionately subject to stop and search, arrest etc, have a lower economic and social status, have less access to education and support and so on...all of which would account for the disproportionate nature of the statistic you mention.
To attribute it to their skin colour is simply racism in its basic form.
