I bought one of the OcUK Fathom watercoolers when they were being sold, which uses a CoolerMaster Eisberg pump/res block.
The rad was slightly too wide to fit my case at the time, so I saved it for a future build. I totally forgot about it and uncovered it the other day. Going to use it in a mini PC now.
There is quite a lot of air in the tubes, so I guess I need to top it up. I have the bottle of mayhems it came with, but I'm not sure how to do it. The fill port is on the pump block, but surely when I unscrew it the coolant will spill out? The tubes are higher than the port so I'm not sure how this is meant to work.
