Permabanned
- 9 Jun 2009
- London, McLaren or Radical
Hey,
I am sure I am missing something obvious, however my benchmark results are a good 10% lower than I would expect them to be both when stock and overclocked and I am wondering where the bottleneck may be.
- All NVCP settings setup to performance - tried with altering the windows settings to performance too (although that last one was done just for the annoying win 7 performance warning message)
- G-Sync/v-sync disabled for benchmarks
- Tried with various combinations of settings/overclocks... same pattern repeats
- Memory benchmarks seem on-par with expectation (actually exceeding in latency)
- CPU benchmarks seem on-par with expectation
- Appears to only be GPU limitation
- SLI-bridge is connected (I also tried connecting it the other way around just to be sure - no "please connect bridge" message appearing from CP).
- Correct PCI-E ports used according to motherboard manual.
System config:
Asus X99-S
5820k @ 4.5 and 4.625, cache @ 3.5
16GB quad channel ddr4 @ 2666 at timings ranging from 15-15-15-38-2T to 12-13-13-26-1T
2x GTX970 running at 1450/8000 for most of these comparisons... although I have also run a few benchmarks at 1500/8000
Corsair H110 keeping temps well under thermal throttling speeds (sub-80C in all these benchies).
Any recommendations would be greatly appreciated. The system is running everything well at 2560x1440@144Hz - all CPU/memory bound things are exceptional.
But these benchmark scores are showing some kind of GPU bottleneck & I would like to solve it... not because I "neeeeeeeeed" desperately higher scores... it just seems as though something may be missing. You can see clearly it's the GPU score holding back the firestrike total score, physics score looks OK to me.
04-01-2015 18-07-19 by CosmicLogos, on Flickr
04-01-2015 18-07-24 by CosmicLogos, on Flickr
04-01-2015 20-01-35 by CosmicLogos, on Flickr
04-01-2015 20-01-50 by CosmicLogos, on Flickr
04-01-2015 20-18-05 by CosmicLogos, on Flickr
04-01-2015 01-06-36 by CosmicLogos, on Flickr
Thanks
System config:
Asus X99-S
04-01-2015 01-06-36 by CosmicLogos, on FlickrThanks
