Is 125MB (or so) the fastest speed across a home network?
1gb network is spot on.
10GB is POINTLESS, don't forget most hard drives cannot write the data much faster than 110mb/sec anyway..........which is what a 1gb network will deliver.
If you have ANY sort of RAID as well (other than raid 0 - but no one should run that really), it will be much slower at writing than 110mb/sec anyway.
Just the way it is I Am afraid! No point in faster networks at home until most hard drive write speeds hit at least 500mb in huge quantity (1tb SSD still isnt enough, at least for me)
SSD are on the verge of becoming far more viable. My 1gb links have been fully saturated for years, especially with ssds in the mix and multiple clients.
With NAS drives on the rise too, iscsi drives would tacky benefit from quicker links also.
I dont see the need for all of the complaints directed at gige, any half decent switch will support port trunking/aggregation anyway. :confused:
That doesnt answer my question ;)
Let me bore more specific; how often are you transferring files over the network where 1gbps becomes a viable bottleneck?
A lot of the 'cheap' 10 gig stuff is 10GbaseT as well instead of SFP, which pushes the adapter costs way up.
MB/s or Mb/s?
33MB/s is brilliant for powerline.
Indeed, that's pretty nice.
Switches are the hard part. If you don't mind used, NICs can be had for £25 up or so.
Then don't use a switch, surely you can just cable point-to-point, just setup a separate logical network for fast transfers over 10 Gig interface
