** JANUARY SALE IN FULL SWING & HAPPY NEW YEAR!! **
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
Our January SALE is in full swing, but there is far too many products to forum post, so to find the deals visit the following links:
THIS WEEK ONLY JANUARY SALE - CLICK HERE!http://www.overclockers.co.uk/thisweek.phphttp://www.overclockers.co.uk/thisweek.php
MORE JANUARY SALE ITEMS!!
TODAY ONLY DEALS, CHECK DAILY AT 9AM TO SEE NEW DEALS - CLICK HERE!
HIGHLIGHTS
Sapphire Radeon R9 290X Vapor-X OC 8192MB GDDR5 PCI-Express Graphics Card **OcUK WorldWide Exclusive** @ £359.99 inc VAT
OcUK has a worldwide exclusive on the only 8GB 290X in existence, but this is not any 290X it's a highly fine tuned machine being the Vapor-X edition with near silent cooling solution. Running with a 1060MHz core clock and with memory clocked at 5600MHz makes this card absolutely perfect for a 4K setup, even more so with a pair or three of these in Crossfire. That means you could play games like Skyrim with expansion packs at 4k resolution and still not run out of VRAM.<br /><br />
Based on the award-winning Graphics Core Next (GCN) architecture from AMD with 2816 Stream Processors, the SAPPHIRE R9 290X Vapor-X is an Overclocked edition which boasts 8GB of the latest GDDR5 memory running at 1400 MHz (5.60GB/s effective) and high speed engine clocks of 1060MHz.<br /><br />
SAPPHIRE’s innovative Vapor-X cooling technology allows products to run not only cooler but also much quieter. A Vapor-X product means a virtually silent gaming experience and more headroom to explore performance tweaking!<br /><br />
Choke is an important component of the graphics card. By working with the component engineer, Sapphire’s patent pending choke is 10% cooler and offers 25% more power efficiency than a normal choke. The graphics card will be more reliable and save energy.<br /><br />
Improved reliability and better overclocking are possible by using only high-polymer, aluminum capacitors which posses far superior characteristics than regular aluminum capacitor for a longer product life. When operational temperatures drop by 20°C, the product life span is extended by a factor of ten, when the operational temperature increases by 20°C, the product life span only decreases by 10%.<br /><br />
Along the edge of the card the PCB is extended and one of the copper layers left exposed. An additional heatsink mounted directly to this copper layer allows heat absorbed into the PCB from the GPU and other components to be transferred to the heatsink and cooled by the airflow. This feature alone can reduce core temperature by 2 degree C.<br /><br />
Specification:-
- GPU: Hawaii XT
- Litecoin Hash Rate: 850-1000
- Stream Processors: 2816
- ROPS: 64
- Core Speed: 1030MHz
- Memory Speed: 5500Mhz
- Memory interface: 512-Bit
- Memory capacity: 8192MB GDDR5
- PCI-Express X16 lane required
- 600W or greater PSU required
- Power Connectors: 2x 8-pin required
- Display Outputs: 2x Dual Link DVI, 1x HDMI, 1x DisplayPort
- Warranty: 2yr
Was [£389.99] Inc. VAT
Only £359.99 inc VAT.
ORDER NOW
Sapphire AMD Radeon R9 285 Dual-X 2048MB GDDR5 PCI-Express Graphics Card @ £169.99 inc VAT
The new AMD R9 285 is the ultimate do it all card, great for media streaming, gaming and featuring AMD's new True HD Audio sound for exceptional sound quality and realism. This new 285 version consumes less power than R9 280 and is also quicker at the same time. As a result this is one very cool running card which also operates in near silence and will take the fight for AMD to the NVIDIA GTX 760.
Specification:-
- PCI-E 3.0 Ready: Delivers double the bandwidth per lane of PCIe GEN2 for faster GPU- CPU
- Hugely overclockable
- Core Clock Speed: 918MHz
- Shader Architecture: GCN
- Stream Processors: 1792
- Frame Buffer / Memory: 2GB GDDR5
- Memory Width / Speed: 256 bit / 5500MHz
- Power Connectors: 2x 6-pin
- Display Outputs: 2x DVI + 1x HDMI + 1x DisplayPort
- Power: 190W TDP
- DirectX 12 Ready
- Mantle Ready
- AMD True Audio
- 2yr Warranty
Was [£179.99] Inc. VAT
Only £169.99 inc VAT.
ORDER NOW
Sapphire Radeon R9 290X Tri-X 4096MB GDDR5 PCI-Express Graphics Card (11226-03-40G) @ £259.99 inc VAT
AMD Radeon R9 290X is a new graphics card powered by the latest AMD Radeon™ R9 290X graphics-processing unit (GPU). 4GB of super-fast GDDR5 memory for the best gaming experience at the highest resolutions including 4k and incorporates AMD Eyefinity and TrueAudio technologies to enable expansive multi-display setups and more accurate environmental sounds. R9 290X also includes support for both DirectX® 11.2 and AMD's new Mantle application programming interface (API) for great handling of even the most-demanding PC games.
Specification:
- Radeon R9 290X
- GPU: Hawaii XT
- ROPS: 64
- Core Speed: 1000MHz
- Memory Speed: 5000Mhz
- Memory capacity: 4096MB GDDR5
- Power Connectors: 8-pin + 6-pin required
- Warranty: 2yr
Was [£275.99] Inc. VAT
Only £259.99 inc VAT.
ORDER NOW
Powercolor Radeon R9 290 PCS+ OC 4096MB GDDR5 PCI-Express Graphics Card @ £221.99 inc VAT
PCS+ Version features Powercolor's amazing tri-fan cooler, for much lower noise levels whilst offering superior cooling. Along with a great overclock out the box, this card runs at 1040MHz core and 5400MHz memory.
AMD Radeon R9 290 is a new graphics card powered by the latest AMD Radeon™ R9 290 graphics-processing unit (GPU). 4GB of super-fast GDDR5 memory for the best gaming experience at the highest resolutions including 4k and incorporates AMD Eyefinity and TrueAudio technologies to enable expansive multi-display setups and more accurate environmental sounds. R9 290 also includes support for both DirectX® 11.2 and AMD's new Mantle application programming interface (API) for great handling of even the most-demanding PC games.
Specification:
- Radeon R9 290
- Coil Whine Reduction Technology (Exclusive to Powercolor)
- GPU: Hawaii Pro
- Litecoin Hash Rate: 800-950
- Stream Processors: 2560
- Core Speed: 1040MHz
- Memory Speed: 5400Mhz
- Cooling: 2-Slot Blower Fan
- 750W or greater PSU required
- Warranty: 2yr
Was [£227.99] Inc. VAT
Only £221.99 inc VAT.
ORDER NOW
GALAX GeForce GTX 970 OC Silent "Infinity Black Edition" 4096MB GDDR5 PCI-Express Graphics Card **WorldWide Exclusive** @ £281.99 inc VAT
Since Overclockers UK introduced our Infinity system range, demand for high performance zero compromise systems has exploded. Our Infinity brand represents performance hardware coupled with a unique and stylish aesthetic.
Since the release of high end Maxwell architecture, the hardware game has changed. The new GeForce cards offer revolutionary new technologies and class leading performance alongside low operating temperatures and impressive power consumption.
The GALAX GeForce GTX 970 OC Silent "Infinity Black Edition" is a collaboration of one of the largest Nvidia board partners worldwide, Overclockers UK Graphics Specialist: Andrew Gibson and Overclockers UK Technical Specialist & Overclocking World Champion, Ian ‘8Pack’ Parry.
Originally the Galax 970 EX OC Black Edition was intended as a high performance option for customers looking for the ultimate gaming experience with class leading performance. Our close partnership with Galax allowed us to specify a list of important modifications that would make the GALAX GeForce GTX 970 OC Silent "Infinity Black Edition" a real show stopper.
Primarily, to fit the Infinity aesthetic, we demanded that the external design of our Black Edition card was sleek and stealthy. Adding to the already imposing look of the Galax design, this new, aggressive appearance really highlights the intent behind this product.
Additionally to the colour change, we included a nickel plated I/O plate, heatsink and heatpipes to compliment the premium nature of the product. The already impressive backplate on the card has been accented with a stylish "Infinity: Inspired by 8 Pack" decal.
The imposing looks of the card would be nothing without the ‘go’ to back up all the show.
Building on the already impressive performance of the GTX 970 platform, world class overclocking expertise from 8Pack has been implemented to fine tune the BIOS of this card to achieve maximum safe, reliable performance from the GTX 970.
As an industry leading gaming and high end hardware specialist, Overclockers UK understands the importance of offering a product that meets a customer’s expectation. A major worry for any enthusiast is operational noise under load. We have used this knowledge to reduce coil whine by using higher quality components and also using glue to attach the inductors to the PCB to help reduce electrical vibrations which help reduce whine.
This collaboration with Galax has allowed us to build what we believe to be the finest example of a GTX 970 on the market today.
This product is exclusively available from Overclockers UK and Caseking group throughout UK and Europe. We suggest European customers visit www.caseking.de to purchase this card in Western Europe and Eastern European customers purchase from http://www.kellytech.hu/
Features:-
- OcUK Zero Coil Whine guarantee*
- Samsung memory guarantee
- All Black Design!
- Nickel plated I/O Plate
- Nickel plated heatsink and heatpipe
- All black shroud/cooling design
- Black PCB
- Black Backplate with Inspired by 8 Pack logo
- Inductors placed in higher quality containers and glued to PCB to reduce coil whine
- Extreme factory overclock with huge OC potential
- Anodized aluminum backplate protects components and reinforces the PCB
- All new Silence Extreme cooler reduces temps by up to 10C
- Silence Extreme technology switches to single fan cooling at idle for almost noiseless operation
Quad mixed-gauge heat pipes ensure maximum heat dissipation
- Copper base with solid aluminum cover
- 5 + 2 Phase enhanced power system with 8 + 6-pin inputs delivers up to 50% more power for overclocking
- Voxel Global Illumination Technology (VXGI)
- NVIDIA® Super Resolution technology
- NVIDIA® GameWorks technology
- NVIDIA® GameStream technology
- NVIDIA® TXAA Technology
- NVIDIA GPU Boost 2.0
- NVIDIA PhysX® Technology
- NVIDIA FXAA Technology
- NVIDIA Adaptive Vertical Sync
- NVIDIA Surround
- Support for four concurrent displays including: Two dual-link DVI, HDMI and DisplayPort 1.2
- Microsoft DirectX 12
- NVIDIA® 3D Vision® Ready
- NVIDIA SLI® Ready Technology
- NVIDIA CUDA® technology
- PCI Express 3.0 support
- OpenGL 4.4 support
- OpenCL support
- NVIDIA SHIELD Ready
- NVIDIA G-Sync Ready
Specification:-
- GeForce GTX 970
- GPU: GeForce GTX 970 (GM204)
- Core Base Clock: 1178MHz
- Core Boost Clock: 1329MHz
- Memory Clock: 7010MHz
- Memory Size: 4096MB GDDR5
- Bus Type: PCI Express 3.0
- Memory Bus: 256-bit
- CUDA Cores: 1664
- DirectX 12: Yes
- DVI Port: 2x Dual-Link DVI, 1x DisplayPort & 1x HDMI
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 1x 8-Pin & 1x 6-Pin
- 450W PSU Required
- 150W TDP
- Dimensions: 260mm (L) x 120mm (H) x 40mm (W)
- Zero coil whine guarantee
- KitGuru Review: http://www.kitguru.net/components/g...rce-gtx-970-oc-silent-infinity-black-edition/
- Warranty: 2yr
*If your card emits any coilwhine when used on a decent power supply that is 80+ Gold rated or higher then OcUK will refund or exchange the card. These cards incorporate our exclusive Coil Whine Reduction technology to help reduce and eliminate any whine.
Was [£299.99] Inc. VAT
Only £281.99 inc VAT - FREE SHIPPING!!!
ORDER NOW
XFX AMD Radeon R9 295 X2 8192MB GDDR5 PCI-Express Graphics Card @ £499.99 inc VAT
No matter what the game or the resolution you can now select the maximum settings even at 4k resolution and enjoy fluid ultimate smooth framerates in latest games such as Titanfall, Diablo 3, Watchdogs and even potential upcoming games such as GTA V and Half Life 3 should they surface.
Featuring a pair of 290X Hawaii GPU's fused onto a single PCB with an advanced PLX chip along with only requiring 2x 8-Pin power connectors.
The other major feature of the 295 X2 is its cooling solution which truly does keep the cards temperatures around 60c even after gaming for hours and it also manages to do this in more or less silence with zero throttling of the cores themselves. Making it one of the smoothest, quietest and easily most powerful graphics card on the market today. If you really crave the most powerful and have or are considering a 4k monitor for gaming then the 295 X2 is the card for you.
If your demands are truly the most powerful experience possible then these cards work great in Crossfire (4 GPU's) and you will be able to smash benchmarks to pieces and have no slow downs in games.
Specification:-
- GPU: 2x Hawaii XT
- Hybrid Liquid Cooling
- Litecoin Hash Rate: 1600-2000
- Stream Processors: 5632
- ROPS: 128
- Core Speed: 1018MHz
- Memory interface: 1024-Bit (2x 512-Bit)
- 850W or greater PSU required with genuine 8-Pin PCI-E cables such as Silverstone 1500W
- Case capable of fitting such a long card and support for a 120mm radiator
- Dimensions: Card is 307x111x65mm and Cooler is 153x120x63mm
- Display Outputs: 1x Dual Link DVI, 4x Mini-DisplayPort
- Warranty: 2yr
Was [£509.99] Inc. VAT
Only £499.99 inc VAT - DOWN TO OUR LAST 100 UNITS!!
ORDER NOW
Samsung S27D590C 27" Curved Widescreen LED Monitor - Black @ £299.99 inc VAT
Our new, 27-inch curved monitor takes movie watching and gaming to new heights, from the monitor's unique curved screen and comprehensive entertainment features, to the incredible picture quality and the impressive sleek design," said Phil Gaut, Director of Display, Samsung UK & Ireland. "The S27D590C further emphasises our focus to create a truly immersive and unforgettable entertainment experience.
The curvature of the S27D590C improves the viewing experience in comparison to traditional flat screen monitors, as the screen boasts nearly uniform viewing distances from the centre of the screen to its edges. This curve of the screen matches the natural curve of the human eye and makes it easy for viewers to completely immerse themselves in games and films.
Additionally, the screen's curve creates a wider field of view and greater sense of depth, which enables viewers to enjoy a panoramic experience and gives the screen a 3D-like effect. The 3D effect is particularly apparent when enjoying games, such as racing and flight simulators, avatar-based adventures and shooting games.
With an ultra-wide viewing angle of 178 degrees, both horizontally and vertically, the curved monitor's vertical alignment (VA) panel optimises the viewing experience from any position and minimises picture distortion. In addition, the S27D590C's Mega Dynamic Contrast Ratio technology delivers a high contrast ratio of 3000:1 and 350 cd/m2 brightness help produce life-like images with deeper blacks, pristine whites and brighter colours.
The integration of enhanced entertainment features takes gaming and multimedia content experiences to the next level. The monitor comes fully equipped with built-in 5-watt dual speakers that deliver high-quality stereo sound as well as a game mode function that can be quickly activated with a simple touch of a button. The game mode intelligently detects on-screen changes and corrects blurry images, enhances colours and alters contrast for improved visibility of in-game action.
The monitor has a minimalist design, ensuring viewers enjoy the enhanced viewing experience of the curved screen without any distraction. Users can also easily adjust the screen angle using the tilt screen function to minimise glare and reflection. The monitor also supports 100x100 mm VESA standard brackets for stress-free wall or table mounting.
Specification:-
- Screen Size: 27"
- Panel Type: VA
- Backlight: LED
- Brightness: 350cd/m
- Dynamic Contrast Ratio: 10,000,000:1
- Static Contrast Ratio: 3000:1
- Resolution: 1920x1080
- Pixel Pitch (HxV): 0.2331mmx0.2331mm
- Response Time: 4ms
- Viewing Angles: 178/178
- Colour Support: 16.7M
- Connectivity: DisplayPort, HDMI, Analogue
- Speakers: Yes (2x5W)
- Stand Type: Tilt
- Warranty: 2yr
Was [£329.99] Inc. VAT
Only £299.99 inc VAT.
ORDER NOW
BenQ GW2760HM 27" Widescreen LED Professional Slim Bezel Monitor - Black @ £149.99 inc VAT
Built to bring you the ultimate personal visual entertainment, the BenQ GW2760HM is certainly one of a kind! Featuring the speakers, ultra-high 5000:1 native contrast, 20M:1 dynamic contrast ratio, and true 8-bit panel performance with deep blacks and minimized light leakage, this VA LED monitor refreshes your view with truly fantastic colors and details. And, its HDMI connectivity leads the path to a whole new level of multimedia enjoyment.
After launching the world's first VA LED monitor, BenQ - the world's leading LED monitor brand - is now taking the lead to introduce VA LED to our home & offcie offering: GW Series! Built with the dream combination of LED with VA panel, GW Series is bound to bring a whole new visual experience and enjoyment to you with truly authentic colors, deeper blacks, higher contrast and sharper details.
GW60 Series blends perfectly with any décor, adding a hint of low-key elegance to your living space with its high-gloss frame and base stand streamlined by a curvaceous neck that creates stunning visual fluidity. Beautiful from any angle, the back of the GW2760HM is carbon fiber patterned to recreate the powerful drive of a racing car and energize their whole appearance. Incorporating a 16mm slim bezel display, GW60 Series creates a sophisticated look while keeping things nice and compact. You'll find multi-panel configuration for home entertainment or office viewing use much simpler with less distraction from the monitor frame.
For a more comfortable reading experience, BenQ has adjusted the monitor's color temperature, brightness, contrast ratio and sharpness to create the all new Reading Mode which simulates the look of printed paper to help reduce the eye discomfort typically caused by prolonged and focused use of eyes on computer monitors.
The improved Eco Mode adjusts the backlight brightness level to ensure the highest display quality is presented to you with the highest energy efficiency. This intelligent mode reduces at least 37% of the power consumed by document viewing, Internet browsing and emailing and up to 44% of the power consumed by gaming.
The GW2760HM comes with an ultra-high native contrast ratio of 5000:1 and dynamic contrast ratio of 20M:1 to add color depth and definition to darkened and complex motion pictures, so that everything you see, from the brightest white to the darkest black, is perfectly rendered to deliver the clearest, smoothest picture performance during movies and video games.
Specification:-
- Screen Size: 27"W, VA LED
- Resolution (max.): 1920 x 1080
- Pixel Pitch: 0.311 mm
- Brightness: 300 cd/m2
- Contrast Ratio: 5000:1
- DCR: 20M:1
- Response Time: 4 ms GTG
- Display Area: 476.64 x 268.11 mm
- Display Color: 16.7 million
- Viewing Angle (L/R;U/D) (CR>=10): 178 / 178
- Terminals: D-sub / DVI-D / HDMI / Headphone jack / Line in
- VA LED Technology
- Senseye® Human Vision Technology (plus Senseye 3)
- Advanced Motion Accelerator (AMA)
- HDCP Support
- Speaker: 1W x2
- Dimensions(HxWxD mm): 488 x 641 x 215
- VESA Wall Mounting (mm): 100 x 100 mm
- Warranty: 2yr
Was [£161.99] Inc. VAT
Only £149.99 inc VAT.
ORDER NOW
AOC U2868PQU 28" 4K 60Hz 1MS Gaming Widescreen LED Monitor - Black @ £335.99 inc VAT
The U2868PQU from AOC is designed for gamers as it features a rapid 1ms response TN panel with a staggering resolution of 3840x2160. Your games will never have looked so good, but bear in mind to play the latest games at 4k resolutions you will need a minimum of 780Ti or 290X and ideally a pair running crossfire/SLI to play at 4k with maximum details with 60fps or more. This monitor is also 60Hz at 3840x2160 when connected via DisplayPort.
Featuring great connectivity with VGA, DVI, HDMI and DisplayPorts along with a full height adjust, pivot and swivel stand with VESA 100x100 support. Making the AOC U2868PQU ideal for eye-finity/surround setups. The monitors also includes stereo speakers and USB Hub as well.
Specification:-
- Size with stand (W x H x D ) : 658.9x560.6x245 (mm)
- Without stand (W x H x D ): 658.9x395.8x50 (mm)
- Display Screen Size: 28" (70.8cm)
- Aspect ratio: 16:9
- Panel Type: TN
- Brightness: 300cd/m2
- Contrast Ratio: 1000:1 (Typ)
- Dynamic Contrast Ratio: 80,000,000
- Resolution: 3840x2160 (Only over DisplayPort at 60Hz)
- Response Time: 1ms (GTG)
- Viewing Angle (H / V ): 170 ° / 160 °
- Connectivity: 1x HDMI, 1x DisplayPort, 1x DVI, 1x VGA, 1x USB Hub
- Stand: Height adjust, pivot & Swivel
- USB Hub: Yes
- Speakers: Yes
- Warranty: 3yr
Only £335.99 inc VAT.
ORDER NOW
Samsung 32D850D 32" Widescreen LED Professional/Gaming Slim Bezel Monitor - Black @ £379.99 inc VAT
Samsungs latest flagship monitor ideal for gamers, professionals and photography experts.
Specification:-
- Screen Size: 32"
- Panel Type: VA
- Backlight: LED
- Contrast Ratio: 10,000,000:1
- Resolution: 2560x1440
- Pixel Pitch (HxV): 0.27675mmx0.27675mm
- Colour Support: 1.07b
- Connectivity: Dual Link DVI, DisplayPort, HDMI, USB Hub
- Speakers: No
- Stand Type: Height Adjustable (130mm), Tilt, Swivel & Pivot
- VESA: 100x100
- Set Dimension with Stand (WxHxD): MAX:741.3×630×280, MIN:741.3×500×280mm
- Set Dimension without Stand (WxHxD): 741.3×441×68.5mm
- Review: http://www.trustedreviews.com/samsung-s32d850t-review-image-quality-uniformity-input-page-2
- Warranty: 3yr
Was [£419.99] Inc. VAT
Only £379.99 inc VAT.
ORDER NOW
LG Flatron 34UC97-S 34" WideScreen Super-Wide Curved LED Monitor @ £779.99 inc VAT
21:9 Curved UltraWide QHD (3440*1440) display offers visual comfort with 2.4 times more visual information at one time than a Full HD monitor. And also, the QHD resolution’s 1440p vertical height allows you to use more vertically than a 29 inch 21:9 monitor.
IPS’s 178’ wide viewing angles, close to 180’, allow you to view the screen clearly without distortion. Also, the Curved IPS provides an immersive viewing angle covering the entire viewing angle around your range of vision.
You are guaranteed an immersive artwork by perceiving the same color as a subject on display or print through a sRGB over 99% colourspace and IPS’s accurate colour expression.
34UC97 provides two Thunderbolt2 ™ ports to directly connect a Mac PC and Pegasus2 storage directly to transmit data more than four times faster, than a USB 3.0. As a result, there is no concern of slow transmission from using a USB or HDMI connection. You can connect to various devices with the two HDMI and two USB 3.0 ports, and a Display Port. And, If you have a Mac, you can connect directly to the 34UC97 via Thunderbolt 2™, which transmits data more than four times faster than USB 3.0.
Using MaxxAudio® technology you will experience deeper bass and crystal clear highs. Equipped with two 7w internal speakers and MaxxAudio® technology, the 34UC97 provides cinema surround- like sound, allowing you to enjoy movies without any extra external speaker or sound output equipment.
Specification:-
- Screen Size Class (diagonal): 34" Curved
- Panel Type: IPS
- Aspect Ratio: 21:9
- Resolution: 3440x1440
- Color Gamut (CIE1931): sRGB 99%
- Brightness (typical): 300 cd/m2
- Contrast Ratio(Original): 1000:1
- Response Time: 5ms
- Viewing Angle (CR>10): 178/178
- Colour Depth (Num of Colours): 1.07B (8-Bit+FRC)
- Pixel Pitch (mm): 0.2325
- Surface Treatment: Anti-Glare 3H
- Curve: 3800R
- Connectivity: 2x HDMI, 1x DisplayPort & 2x ThunderBolt
- Speakers: 2x 5W
- Tilt: -5 / +15
- Set with stand: 830.5 x 224.5 x 472.9
- Set without stand: 830.5 x 106.4 x 370.3
- Weight: 8.2kg
- Linus Review:
- Warranty: 2yr (LG On-Site)
Was [£989.99] Inc. VAT
Only £779.99 inc VAT.
ORDER NOW
Samsung 27D850D 27" Widescreen LED Professional/Gaming Slim Bezel Monitor - Black @ £319.99 inc VAT
Specification:-
- Screen Size: 27"
- Panel Type: PLS
- Backlight: LED
- Speakers: No
- VESA: 100x100
- Set Dimension with Stand (WxHxD): MAX: 627.4 x 596.3 x 280 / MIN: 627.4x 466.3 x 280mm
- Set Dimension without Stand (WxHxD): 627.4 x 376.4 x 66.1mm
- Warranty: 3yr (On-Site With Samsung)
Only £319.99 inc VAT.
ORDER NOW
Asus PB287Q 28" 4K 60Hz 1MS Gaming Widescreen LED Monitor - Black @ £359.99 inc VAT
Asus enter the price war with their gaming 28" 4k monitor, just like other models sporting an impressive specification with a fast response 1ms TN panel, 60Hz over DisplayPort. The Asus also has some innovations of its own such as a flicker free backlight to help reduce any flicker along with a fully adjustable stand.
Experience games in such detail and realism like never before at 4k resolution, just ensure you have the lastest graphics cards and ideally in multi-GPU configurations to get the best from your 4k panel.
Specification:-
- Panel Type: TN
- Flicker FREE backlight
- PIP/PBP Support
- Speakers: Yes
- Warranty: 3yr
Was [£407.99] Inc. VAT
ORDER NOW
Asus PG278Q ROG Swift 27" G-Sync 144Hz Gaming Widescreen LED Slim Bezel Monitor - Black/Red @ £599.99 inc VAT
Quite possibly the best gaming monitor ever made and ideally suited to NVIDIA cards with 3D Vision 2.0 and G-Sync technology. This monitor runs at a staggering 2560x1440 resolution with 144Hz technology and a 1ms response, even better this is the latest in TN technology.
The ROG SWIFT PG278Q represents the pinnacle of gaming displays, seamlessly combining the latest technologies and design touches that gamers demand.
This 27-inch WQHD 2560 × 1440 gaming monitor packs in nearly every feature a gamer could ask for. An incredible 144Hz refresh rate and a rapid response time of 1ms eliminate lag and motion blur, while an exclusive Turbo key allows you to select refresh rates of 60Hz, 120Hz or 144Hz with just one press. The ROG SWIFT contains integrated NVIDIA® G-SYNC™ technology to synchronize the display's refresh rate to the GPU. This technology eliminates screen tearing, while minimizing display stutter and input lag to give you the smoothest, fastest and most breathtaking gaming visuals imaginable. Connectivity is simple, yet robust, with a single DisplayPort 1.2 port to enable NVIDIA® G-SYNC™ and dual USB 3.0 ports for convenience.
Conventional 60Hz monitors show extensive motion blur which detracts from your gaming experience. The ROG SWIFT PG278Q Gaming Monitor with NVIDIA® Ultra Low Motion Blur technology* reduces the effects of motion blur by delivering crisp edges in fast-paced gaming environments for perceivable differences in natural movement.
ASUS-exclusive GamePlus Technology enhances your gaming experience further by providing you with crosshair overlays for FPS games and multiple in-game timers for RTS/MOBA games.
The ROG Swift has a super-narrow 6mm bezel that begs this monitor to be used in multi-display gaming set-ups. With VESA wall mount capability and an ergonomic stand designed with full tilt, swivel, pivot and height adjustments, the ROG SWIFT is ready for long gaming sessions in comfort.
The ROG SWIFT PG278Q represents the next generation in gaming displays. This WQHD 2560 x 1440 monitor delivers four times the resolution of 720p, with 109 pixels per inch or 109 RGB matrices per inch. This gives you the benefits of greater image detail and up to 77% more onscreen desktop space than standard Full HD (1920 x 1080) displays. These minor details add up to give you a major in-game advantage.
Unlock the highest frame rates available, decimate lag and say goodbye to motion blur to gain the upper hand in first person shooters, racers, real-time strategy and sports titles. With twice the frame rate of standard LCDs, the ROG SWIFT PG278Q Gaming Monitor encourages you to never blink again.
Response time and ultra-smooth gameplay are the hallmarks of a true gaming monitor. With a 1ms rapid response time – the fastest available – the ROG SWIFT PG278Q Gaming Monitor eliminates smearing, tearing and motion blur, allowing you to quickly react to your game.
NVIDIA®G-SYNC™ display technology delivers the smoothest, fastest and most breathtaking gaming imaginable. G-SYNC™ synchronizes the ROG SWIFT's refresh rate to the GPU in your GeForce GTX-powered PC, eliminating screen tearing and minimizing display stutter and input lag. Scenes appear instantly, while objects look sharper and more vibrant. Gameplay is fluid and responsive too, ensuring a serious competitive edge.
The ASUS Display R&D team works closely with NVIDIA to ensure that everything runs smoothly on ASUS G-SYNC™ monitors. The ROG SWIFT PG278Q gaming monitor with built-in G-SYNC™ delivers super smooth and stunning visuals.
The ROG SWIFT PG278Q is compatible with the NVIDIA® 3D Vision™ 1 and 2 kits* to support up to three WQHD displays for immersive multi-display 3D gaming experience. ROG SWIFT provides the finest 3D gaming and content viewing experience and thanks to the ever-growing library of over 700 3D Vision™ ready game titles, as well as 3D Blu-ray movies and YouTube 3D Playback support. See everything in a new dimension with the ROG SWIFT.
*Requires NVIDIA® 3D Vision™ kit, sold separately.
Features:-
- Crisp 27-inch, 2560 x 1440 visuals combined with fast 144Hz refresh rate, 1ms response time, made smooth by NVIDIA®G-SYNC™ technology
- Exclusive GamePlus onscreen timer/crosshair, 60-120-144Hz refresh rate turbo key and intuitive 5-way OSD navigation joystick
- Complete ergonomic tilt, swivel, pivot and height adjustment with VESA mount capability for optimal placement
Specification:-
- Fully adjustable stand: tilt/swivel/pivot/height
- Screen Size: 27" (68.47cm)
- Pixel Pitch: 0.233mm
- Resolution: 2560x1440 WQHD
- 2D mode: 2560x1440 (up to 144Hz)
- 3D mode: 2560x1440 (up to 120Hz)
- 2D Surround: 7680x1440 (up to 144Hz)
- 3D Surround: 7680x1440 (up to 120Hz)
- Panel: TN
- Refresh Rate: 144Hz
- Contrast ratio: 1000:1
- Colour: 16.7M (Real 8-Bit)
- Connectivity: 1x DisplayPort (Display Cable and USB cables included)
- USB 3.0 Hub
- 3D Vision 2.0 Enabled
- G-Sync Enabled
- ULMB Enabled (NVIDIA Ultra Low Motion Blur Technology)
- Phys. Dimension with Stand(WxHxD): 619.77x362.96x237.9mm
- Box Dimension (WxHxD): 756x456x300mm
- Weight 7.5kg
- Full Specification: http://www.asus.com/Monitors/ROG_SWIFT_PG278Q/
- Warranty: 3yr (28 Day OcUK DOA, Asus After)
- OcUK Exclusive Service: Warranty regarding dead pixels falls under ISO rules and as such dead pixels if very few are not an actual fault. But at OcUK we value our customers especially when spending such a large amount of money on what is a flagship gaming monitor. As such even if you only have 1 dead/stuck pixel and it has not gone after 3 days, we will class the monitor as faulty and exchange it for you at no cost to you. This service is exclusive at OcUK for Asus ROG Swift ONLY or other qualifying monitors! (Valid for 28 days from purchase)!
Was [£619.99] Inc. VAT
Only £599.99 inc VAT.
ORDER NOW
AOC G2460FQ 24" Widescreen 144Hz 1ms Gaming LED Monitor - Gunmetal @ £167.99 inc VAT
The AOC g2460fq display delivers non-stop action for thrill-seeking gamers. The 24-inch Full HD screen provides accurate colors, sharp images and true blacks with a typical contrast ratio of 1000:1. The quick one millisecond response time makes this monitor a real standout, eliminating ghosting and motion blur for fast-paced games and movies. Enjoy rich, full sound with the built-in headphone jack and 2 watt speakers. Integrated VGA, DVI-D, HDMI and DisplayPort connectors let you hook up multiple devices like your computer and game console at the same time. This also display comes complete with a VESA mount, giving you the option to hang it on a wall. The textured black finish and slim profile add a touch of style, whether you’re racing, role-playing or creating a virtual world.
Specification:-
- Monitor Size: 24"
- Visible Screen Size: 61 cm
- Screen Format: 16:9
- Brightness: 350 cd/m² (typ)
- Contrast Ratio Dynamic: 80.000.000:1
- Contrast Ratio Typical: 1000:1
- Pixel / Dot / Pitch: 0.276 (H) x 0.276 (V)
- Display Area: 531.36 (H) x 298.89 (V)
- Viewing Angle: 170°/160° (CR 10)
- Response Time: Up to 1 ms GtG
- Maximum Resolution: 1920 x 1080@144 Hz (DVI Port)
- Recommend Resolution: 1920 x 1080@144 Hz
- Colors: 16.7 M
- HDCP compatible: yes
- Inputs: Analogue, DVI-D, HDMI & DisplayPort
- Dimensions (WxHxD): 565.4 x 393.6 (+130) x 244.58 mm
- Warranty: 3yr
Only £167.99 inc VAT.
ORDER NOW
TeamGroup Elite 16GB (4x4GB) DDR4 PC4-19200C16 2400MHz Quad Channel Kit - Black (TPKD416GM2400HC16QC01) @ £169.99 inc VAT
TeamGroup Elite DDR4 offers great value and great performance with superb looks with all black PCB and heatspreader design,.
Specification:-
- CPU Compatibility: Intel Haswell-E ( LGA 2011-3 )
- Chipset: Intel X99
- Capacity: 16GB (4GBx4)
- Quad Channel kit: Yes
- Tested Speed: DDR4-2400 MHz (PC4-19200)
- Tested Latency: 16-16-16-36
- Tested Voltage: 1.2V
- Registered/Unbuffered: Unbuffered
- Error Checking: Non-ECC
- Type: 288-pin UDIMM
- SPD Speed: 2133 MHz
- SPD Voltage: 1.2V
- Features: Intel XMP 2.0(Extreme Memory Profile)Ready
- Warranty: Lifetime
Was [£199.99] Inc. VAT
ORDER NOW
Avexir Core Red Series 8GB (2x4GB) DDR3 PC3-21000C12 2666MHz Dual Channel Memory Kit (AVD3U26661204G-2CIR) - Red Light @ £71.99 inc VAT
Avexir Core Series is designed specifically for the extreme power users who focus on challenging the excellence in high performance gaming experience. The Core Series is developed by Avexir R&D team with 10+ years’ experience of researching in memory core technology and designed specifically for the power users and gamers who demand ultimate performance and extreme reliability gaming modules.</p>
Mpower Red Series is designed to be a perfect visual match for Asus ROG, EVGA, Asrock Fatality and MSI Gaming mainboards, giving you a look which shall make you the envy of all your friends.
Avexir strictly adheres to quality standards set by JEDEC (the Joint Electron Devices Engineering Council) and ISO9001.
With 100% hand-tested extensively in multiple PC major-brand motherboard environments at its rated speed, Avexir makes sure that both stability and performance of every memory module reach the highest quality criteria.</p>
Features:
- Black PCB
- Black/Red high performance heatspreaders
- Red LED Strobe lighting effect
- SPD programmed at: JEDEC standard 9-9-9-24 values at 1333MHz.
- CAS Timings: 12-14-14-35
- Dual Channel Kit: (2x4GB)
- 100% tested at 2666MHz in Intel & AMD based motherboards
- Lifetime Warranty
Was [£89.99] Inc. VAT
Only £71.99 inc VAT.
ORDER NOW
Avexir Core Red Series 16GB (2x8GB) DDR3 PC3-21000C12 2666MHz Dual Channel Memory Kit (AVD3U26661208G-2CIR) - Red Light @ £129.95 inc VAT
Features:
- Black PCB
- Dual Channel Kit: (2x8GB)
- Lifetime Warranty
Was [£169.99] Inc. VAT
Only £129.95 inc VAT.
ORDER NOW
GeIL EVO Potenza 16GB (4x4GB) DDR4 PC4-24000C16 3000MHz Quad Channel Kit - Red (GPR416GB3000C16QC) @ £197.99 inc VAT
Potenza, the Italian word for “power”, hence the name of GeIL’s latest top of the line DDR4 Gaming Memory – EVO POTENZA. Speed of up to 3200MHz, available in Quad and Dual-Quad Kits, the DDR4 EVO POTENZA is designed for the latest Intel X99 chipset for maximum performance and compatibility.
EVO POTENZA is equipped with the Potenza heat-spreader, designed with GeIL’s MTCD – Maximum Thermal Conduction & Dissipation technology for superior cooling efficiency. EVO POTENZA is the new DDR4 performance benchmark that powers up your desktop.
Specification:-
- Tested Speed: DDR4-3000 MHz (PC4-24000)
- SPD Voltage: 1.2V
Was [£269.99] Inc. VAT
Only £197.99 inc VAT.
ORDER NOW
Aorus X3 CF1 13.3" 2K LED TFT, Intel Core i7-4860HQ, 8GB DDR3, 256Gb M2 SSD, NVIDIA GTX 870M 6GB GDDR5 - Windows 8.1 @ £1,219.99 inc VAT
GTX 870M: Graphic Powerhouse
GTX 870M incorporates 1344 CUDA cores and the latest NVIDIA reg; innovation support, including Battery boost, Shadowplay and GameStream, guarantees the most engaging experiences. Feel the raw power, an unbelievable P7100 in 3DMark 11. X3 has brought an unrivaled performance to the compact form factor!
QHD Resolution: Astonishing Level of Detail
AORUS is never afraid to explore new horizons. X3 Plus boasts a QHD display with 2560x1440 resolution providing stunning and breathtaking picture quality that pushes gaming experience to a new level. The extraordinary high luminance, 350 cd/m2, proves excellent clarity and readability even outdoors!
New Haswell Platform: Power Meets Efficiency
Intel4th gen Core i7-4860HQ processor brings 15% performance gain and 25% less in power consumption than its predecessor. The upgraded battery life creates more convenience as well as fun when you are gaming on-the-go.
IGZO Panel for Cutting-edge Images
The X3 and X3 Plus employs the latest and best IGZO-TFT (Indium gallium zinc oxide) panel, a low-power yet high performance display that minimizes color shift, proving gorgeous image with crystal clarity. Packing 3.68 million pixels into a 13.3 inch frame results in an astonishingly vibrant viewing experience
Clear & Gorgeous from Anywhere
The extremely wide viewing angle display offers a consistent natural color and contrast ratio from any angle within 170 degrees, vertically and horizontally. Perfect for showcasing your gaming moves, a movie night or even sharing a presentation, everyone gets the full visual experience.
4K/ UHD Output Ready
With a built-in Mini DisplayPort, X3 is capable of outputting to an external display for an ultra-high resolution up to 4K at 60Hz. The industry-leading 60 frames per seconds delivers smooth fast-motion scenes free of blur or tearing, promising every gaming moment with X3 is engaging as it is meant to be.
Killer LAN: Zero Latency Is King
Killer LAN ensures 100% packet transmission even under busy network traffic while generic LAN chips manage an average of 14.9% packet loss rate. Waste no more time on buffering for online games, streaming video or live video chat. Explore a latency-free Internet experience with X3!
802.11ac: 45% - 70% faster than regular 802.11n
802.11ac, the next generation of wireless, promises intensified signals and more stable connections. Experience wireless gaming like never before! Enjoy stronger throughput, extended coverage, less speed decline, and above all, freedom to play anywhere with your X3!
One Click Execution, Pure Dominance
Macro Keys rarely available on gaming laptops are now an X3 standard! AORUS exclusive macro keys simplify your killer combos into one-click execution keys. The scissor-switch key structure guarantees lightning response ensuring pure dominance during game play.
Make Every Shot Count
Lightning assault and counter-attack is just what being a winner takes. X3 brings that instinct to your fingertips - snappy and responsive typing. The auto-adjust backlit readies every gamer for upcoming battles despite the limits of dimlit or outdoor conditions.
Macro Engine: Program Your Signature Moves
AORUS exclusive programmable Macro Engine automates and simplifies routine operations. Record your macros and share your killer moves with other AORUS owners. It takes just 1-click to access AORUS official forum, where cloud sharing, hot macro ranking and the latest gaming news are prepared for you.
Fan Control: Customized Stability
Fan Control tailors your fan speed to different users scenarios, striking a perfect balance between performance and system stability. 3 customizable modes are ready for all-condition tweak over your ultimate gaming flagship anytime, anywhere.
LockWin Key: Double Safe Your Game
Disable Windows Key through our gamer exclusive UI to prevent a misclicks during gaming. Be assured your victory is watched over by AORUS. Series gaming deserves full concentration!
Product Specification:
- Product Code: AORUS X3 - CF1
- EAN Code: 4719331919450
- OS: Windows 8.1
- CPU: Core i7-4860HQ (2.4GHz - 3.6GHz)
- Display: 13.3" QHD (2560 x 1440) Wide viewing angle LCD
- Memory Supplied: 1 x 8GB
- Memory Type: DDR3L
- Memory Speed: 1600
- Max Memory Support: 16GB
- Graphics Chipset: NVIDIA GeForce GTX870M
- Graphics Memory: GDDR5 6GB
- Storage: 1 x 256GB M.2 SSD
- Keyboard Type: Backlit Keyboard with Individual Macro Keys
- USB3.0 Ports: 2
- USB2.0 Ports: 1
- HDMI Port(s): 1
- mini Display port(s): 1
- LAN Port(s): 1
- Microphone Jack(s): 1
- Headphone Jack(s) (SPDIF): 1
- Card Reader: SD
- Audio: 2 x Speakers
- LAN: Killer LAN Chip
- Wireless: 802.11ac
- Bluetooth: V4.0
- Webcam: HD Camera
- Security: Kensington Lock
- Battery: Li Polymer, 73.26Wh
- Dimension: 330 x 263.5 x 22.9mm
- Weight: ~1.8Kgs
- Warranty: 2yr
Was [£1299.95] Inc. VAT
Only £1,219.99 inc VAT.
ORDER NOW
Aorus X7 Pro V3-CF1 17.3" LED TFT, Intel Core i7-4870HQ, 16GB DDR3, 2x256 SSD RAID, 1TB HDD, Dual NVIDIA GTX 970M SLI - Windows 8.1 @ £1,939.99 inc VAT
AORUS X7 Pro AORUS X7 Pro delivers unrivaled gaming experience without sacrificing portability and practicality. AORUS products are crafted and engineered from the ground up to signify the timeless legacy of gaming, in which a spirit of ancient gamers is shining above and watching over all gamers, despite the time shift.
AORUS X7 Pro features NVIDIA® GeForce® GTX 970M (3GB) dual graphics and 4th gen. Intel® Core™ i7 processor delivering immense performance, in a slate-like chassis. The exclusive Thermal+ Technology achieves class-leading cooling effect and unparalleled reliability and stability. Its understated design yet dynamic outlook marks this state-of-the-art gaming gear an effortlessly thrilling, technically dominant and precisely tuned gadget. AORUS' exclusive software and top-notch components altogether delivers the ultimate gaming platform with incredible portability. Though uncompromised gaming pleasure is aimed as the first priority, X7 Pro still makes a perfect companion for graphic computing and daily use. Discover X7 pro : a great combination of power, speed, style and agility.
Features:
- Extremely powerful Dual NVIDIA GTX 970M 3GB GDDR5 Graphics (6GB total)
- Vivid Full HD screen with wide colour gamut display
- AORUS Thermal+ Technology - dissipates heat effectively and provides constant stability!
- Superior Anti-Ghost Backlit Keyboard - Never Miss a Shot!
- Features NVIDIA 3D Vision Surround - Supports up to 3 displays for perfect gaming vision!
- AORUS Exclusive programmable Macro Hub simplifies routine operations
- Super Thin at only 22.9mm and extremely Lightweight at only 2.9Kgs
- Killer gaming Lan for seamless smooth online gaming
Specification:
- Screen Size: 17.3"
- Screen Type: LCD Wide Viewing Angle
- Backlight: LED
- Screen Resolution: 1920x1080 Full HD
- Processor: Intel Core i7-4870HQ, 2.4~3.6GHz
- Processor Clock Speed: 2.5GHz ~ 3.7GHz (Overclock)
- Graphics Chipset: 2 x NVIDIA GTX 970M SLI GDDR5 3GB
- Graphics Memory: 3GB each (6GB Total)
- Chipset: Mobile Intel® HM87 Express Chipset
- Hard Drive: 1000GB, 7200rpm
- SSD Drive: 2 x 256GB (RAID 0)
- Memory Supplied: 2 x 8GB 1866MHz
- Memory Size: 16GB 1866MHz
- Memory Socket: 4 x SO-DIMM 1866MHz
- Max. Memory Support: 32GB
- Operating System: Windows 8.1
- Audio: 2 x Speakers, 2 x Woofers, Microphone, AORUS Acoustic+ Technology
- LAN: Killer LAN Chip E2201
- Wireless LAN: 802.11ac
- Bluetooth Version: v4.0
- Webcam: 1.0 Megapixel
- USB 3.0 Port(s): 3
- USB 2.0 Port(s): 2
- HDMI Port(s): 1
- Mini Display Port(s): 1
- Surround Port(s): 1
- Card Reader: SD
- Headphone Jack(s): 1
- Dimension: 392 x 263 x 22.9mm
- Weight: 2.99Kgs
- Warranty: 2 Years
Was [£2099.99] Inc. VAT
Only £1,939.99 inc VAT.
ORDER NOW
HAPPY NEW YEAR !!!!!
Last of all I would like to wish you all a fantastic 2015!
2014 has being a superb year for OcUK and our rate of growth has being far beyond expectations, we are hopeful that by the end of our financial year we would have grown the business by nearly 50%, in just one year which is an absolute record.
So I thank all the OcUK staff who have played a huge part in this, raising our customer service to the highest standards now out there. The forums only continue to get better and are completely unrivalled and of course the last thank you goes out to those who have enabled us to grow like this! OUR CUSTOMERS, so we thank you and best wishes for 2015 and lots of new stuff to come from OcUK in the year ahead! :)
Hi there
Some pictures friends just sent me from Taiwan:
They are seven hours ahead so the fireworks will be going off in approximately 20 minutes when 2015 arrives there.
Happy new year everyone! :)
Aww man, I just ordered the GALAX GeForce GTX 970 OC Silent "Infinity Black Edition" yesterday and due to the backlog of orders it didn't ship, so have to wait until the 2nd. AND now there is even more discount :(
Gibbo,
Will the Zotac GeForce GTX 980 AMP OC 4096MB GDDR5 PCI-Express Graphics Card (ZT-90204-10P) at £439.99 go on a deal soon ?
