Hey lads, if I've got MSI R9 290 4GB GAMING and I want to do CF do I need exactly the same r9 290? or can be r9 290 from any manufacturer?
So I can buy even any standard R9 290 and my gaming card clock will go down to match the worse card ye?
A good 850W (by good it meants not just the branding, but the unit itself have good reviews as well...so avoid Corsair) or ideally a good 1000W depending on the rest of your system.wow really? I thought that has to be exactly the same card.
example
r9 290 gaming 1300 clock
r9 290x 1400 clock
they work both fine and increase my fps sure?
I ve got seasonic 620w I guess that wont be enough for my 2x r9 290. what psu should I buy
example
r9 290x 1400 clock
Okay guys I will buy that 1000w superflow. They are fairly cheap.
Will i5 2500k at 4.5ghz bottleneck 2x r9 290? 4K resolution
Necessary to go for an i5 4690 or smth?
For 4K res, I think the Crossfire 290 would still be the bigger bottleneck than the overclocked i5 2500K.Okay guys I will buy that 1000w superflow. They are fairly cheap.
