AMD Radeon R9 200 Series
17 Nov 2008
im thinking of adding another graphic card to my pc to run my games better what card would you advise me to get . spec are below thanks
Intel Core i7-4770K 3.50GHz (Haswell) Socket LGA1150 Processor - Retail
Gigabyte Radeon R9 270X WindForce 3X OC 2048MB GDDR5 PCI-Express Graphics Card with BattleField 4 PC Game Included
SuperFlower Golden Silent 500W Fanless "80 Plus Platinum" Power Supply - Black
Samsung 120GB SSD 840 EVO SATA 6Gb/s Basic - (MZ-7TE120BW)
Gigabyte H87-HD3 Intel H87 (Socket 1150) DDR3 ATX Motherboard
Cooler Master Silencio 550 Silent Tower Case - Black
TeamGroup Vulcan ORANGE 16GB (2x4GB) DDR3 PC3-19200C11 2400MHz Dual Channel Kit (TLAD38G2400HC11CDC01)
Raijintek Aidos Direct Contact CPU Cooler... thanks
what game you play with it? It would be nicer to go with a single card solution instead of running Crossfire due to heat, power, compatible, driver,etc... issues.
call of duty advanced warfare with a good frame rate im getting Screen tearing. will the cross fire be in the box or will i have to by one myself .thanks
I'm pretty sure Xfire doesn't need any bridge like SLI.
Edit:
It would appear I'm wrong and the 270X does need a bridge.
The CF bridge comes with the card. Only SLI bridge comes with motherboard. To avoid unnecessary hidden bugs or micro stuttering, I suggest you to run a single card setup instead of Crossfiring it.
Edit:
You are nearly correct, the R9 290 series do need CF bridge anymore. Other than that, you do need the bridge.
