BitFenix Ghost Silent Tower vs Corsair Carbide 330R Silent Tower
If the 8pin cable annoys you (even if you cant see it) then a few quid for a braided 30cm 8pin ATX extension will fix it.
Is there such a thing as a thinner or more flexible sata cable? Mine all seem to be quite rigid and tricky to manipulate into position!
I had those also (when I had a blue coloured board).
Cant remember much about them to be honest, they are just a sata cable that were the right colour.
Can anyone recommend me a 120mm front case fan to slot in alongside the one that comes with the P100?
I've never bought a case fan before so have no idea what's good and what's not!
For example, is there any reason I should pay more than a few quid for the Arctic F12 Pro Case Fan - 120mm??
Colours and LED's etc dont matter to me because it will be behind the front cover so I just want an efficient fan that's quiet!
