Don't seem that impressive to me.
Much happier with X99? I doubt that very much for the cost outlay.
Better off putting it towards some high end graphics cards.
Me neither considering its cutting edge tech.....someone buy my ram already
Yep, and those you can get have risen in price. I have a p6 x58 de. Terrible board for sli. I daren't test my 780's in it as they will cook. Spacing is too tight. Heck its poor on the uber expensive Z87 board in my sig.X58 mobos are like rocking horse *****
I need to sell the 12 gb patriot viper first....mate..
Will MY Enermax LIBERTY 620W be enough for SLI 970 GTX even?
I personally wouldn't risk sli 970 with x58 on 650w psu. Yes 970's are low power compared to my 780 setup, haswell consumes a lot less power. Id feel more comfy with 850w Ono.
Lol, if you do let me know what its like. Tbh mate I have considered it. Bit not really worthwhile coming from a 4.7ghz 4790k. I'll only ever do dual sli, don't encode video a lot. Bit if blu ray conversion which the current chip copes ok with. Sure it might clock higher, possibly 4.9 but theres a temp trade off on haswell. They run extremely hot under any high oc with certain programs.
to allow sli....if that all goes well....I'll consider sli when I upgrade my monitor in March...In gaming it will net you practically nothing.
Spend the money on GPUs.
Proof please. With a 2 card setup a 5820K will push a pair of 970s a lot better than a 5680
I'm not convinced it would be a huge a difference...
We need a test to take place...
Both run the same bench mark?![]()
I'm not convinced either. Not one bit. Its all crock of ****.
Once your at 1440p and beyond its all about GPU grunt.
While saying things like that is fine I'd like to see some definitive benchmarks to really back up that claim. While a 5680 at 4.5-4.6 is fine for a single gpu in a multigpu setup its going to fall behind to the 5820K even at 4K.
Reason I say this because I was running an SR-2 setup before jumping to the 5820K and I can notice a huge difference especially in Min fps over a pair of 5680's at 4.6Ghz
must have been something serioulsy wrong with your previous setup then.
I'm running a single [email protected] with a pair of 7970's (gfx not overclocked) and my min frames per sec is very good, I play mostly BF4 smooth as silk at 1440p ultra settings. 100-150+fps.
Roll on 390X.
390x will be further limited by the PCIEV2 on your motherboard, since it doesn't support PCI-E v3.
Is the bandwidth even saturated yet? I'm running a gtx 970 in a pcie 2 slot with no loss in performance
