And today I spent a few hours fitting a loobman
http://www.loobman.co.uk/ chain oiler. £20 inc delivery - it's a manual system but not one you have to turn on and off. That big button at the top of the reservoir, you press that for 10-15 seconds which allows oil into the feed pipe, this displaces the oil sitting in the pipe and by a clever system of an oil 'catch' loop with an air hole by the sprocket, only 2-3 inches of oil in the tube actually goes through to the nozzle of the sprocket. So you control the amount of oil - press the button right before you set off, if it's wet, press it more often, if it's dry - less often. I can press it sitting at the lights if I feel my chain needs a little more oil.
So basically, fit and forget apart from pressing the button once every so often. I'll probably do it at the start of my journey to/from work. Once it was fitted I went out for a quick blast up and down the A20 and there was a little bit of oil flicking off but then my chain was dry after the ACF-50 treatment and I pressed it a good 4/5 times in the space of about 30 miles to get the whole chain nice and loobed up again.
Reservoir
Feed pipe and final oil 'catch' - only oil to the right of/downhill of the air bubble will be released onto the sprocket
The delivery nozzle - again you can see the oil that will go onto the sprocket
Compared to the £60+ they want for an automatic Tuturo I thought I'd take a chance on this one, it's made by a London bike courier and has gone through loads of revisions.
On my quick half hour blast out (to test the oiler, of course
) as it was nice and dry I did my first full revs from a few mph/standing start...
The CB400 is deffo quick enough for now.
Also had a little play with a KTM RC8 on the way home for a few miles, didn't know what it was until he passed me as we went into a 30 zone, had a quick chat at a set of lights and he remarked that my bike "goes well enough"
did some proper cornering too, bum shifting off the seat, my god it's fun!!
