OK I was going for 970 SLI setup but finances are dictating a rethink and its looking like I may need to go X-fire 290x route instead.
Currently using an Antec300 but if I cant get the 970's then it will mean a case change as the AMD Cards I am looking at, (http://www.overclockers.co.uk/showproduct.php?prodid=GX-238-MS), will not fit into the existing one, max GPU length is 27cm.
I have been looking at the H440, (when I say looking at I mean drooling over as I just love the way it looks
) but I am aware of its restricted airflow and potential for over heating problems.
So I am now at a complete loss which way to go.
Any advice gratefully accepted.
Note:
CPU is under a H80i AIO with SP120 fans, and I am unwilling nor able to afford a custom watercooling setup for at least 2-3years so that is not an option unfortunately. Unless it can be done on the cheap without risking killing anything.
Note:
